Polliwog - BladeHQ sprint
dsvirsky
Re: Polliwog - BladeHQ sprint
Post by dsvirsky »
Notsurewhy wrote:
Thu Dec 30, 2021 1:47 pm
Not sure what makes this worth $30 more than the dodo exclusive . . .
At a guess, two years' worth of Spyderco price increases. :thinking
gspam1
Post by gspam1 »
Any tricks to removing the scales on a ball bearing lock? I dye the scales on every Jade knife I have. Besides being unattractive, they show dirt immediately. I like M4, but wish Blade HQ would drop the jade obsession.
Notsurewhy
Post by Notsurewhy »
dsvirsky wrote:
Thu Dec 30, 2021 2:30 pm
I don't think that accounts for nearly 20% difference. And didn't the dodo exclusive come out this year anyway?
Similar size, same materials, same lock. I think seki g10 prices are the culprit. For some reason it seems far more expensive to use g10 there than Taichung or Golden. Labor costs? Material availability? Who knows, but it's disappointing. It's probably why there seem to be fewer g10 seki models in recent years.
VooDooChild
Post by VooDooChild »
Notsurewhy wrote:
Fri Dec 31, 2021 7:24 am
First is inflation.
Second the dodo exclusive was 2 years ago. Theres been a 10% map increase since then.
I dont like it, but $30 is within the noise.
bearfacedkiller
Post by bearfacedkiller »
I think it is that the Dodo is made in Golden and the Poliwog is made in Seki. That Japanese G10 ain’t cheap.
Josh Crutchley
Post by Josh Crutchley »
bearfacedkiller wrote:
Fri Dec 31, 2021 12:02 pm
Is there a reason some models are made by certain makers? What's stopping them from making the Poliwog in Golden?
dsvirsky
Post by dsvirsky »
Received mine yesterday and I have to say, I'm a little disappointed. Overall fit and finish are fine, but the hollow grind is so shallow it almost looks like a flat grind, leaving it quite thick BTE. My original SS Poliwog has what I would consider Spyderco's standard hollow grind and a reasonable BTE thickness.
Joshcrutchley1 wrote:
Fri Dec 31, 2021 1:47 pm
Maker relationships, factory capacity, maybe even materials availability, and cost.
Danke
Post by Danke »
OK so down the rabbit hole, all below are Blade HQ jade models. I don't have them all but I do have a range.
2016 PM2 M4 steel USA $159.99
2018 Lum Tanto HAP40 steel Japan $219.95
2019 Dodo M4 steel USA $154.95
2020 Rock Lobster M4 Steel Japan $229.00
2021 Smock M4 Steel Taiwan $182.00
2021 Native Chief M4 steel USA $169.00
The pattern seems pretty clear. If anything the Poliwog is a bargin compared to the other Japan models.
I am not sure if MAP applies to the exclusives since those are only sold through the one location. There's no competition.
Exclusives are exempt from MAP. But yes it's clear to see the seki/Taichung models cost more. For a variety of factors. Best value is usually the Golden made exclusives and sometimes they are cheaper than the base model too
Hi Gspam1,
Welcome to our forum.
Mendozamike89
#32
Post by Mendozamike89 »
It's a little pricey but I do like the design just not the jade ..I'm surprised it's not sold out honestly...I might get it for the m4 And design because I don't think it will be back. Honestly
:bug-white-red Mendozamike89 :bug-red-white
51 spyderco knives in 20 different types of steels.
My Top 3 EDC
-1- Smock s30v with black RGT micarta and lynch clip. With Skipp 3/16"1/16"11 ball bearings.
-2- Sage 5 lw (bladehq exclusive) with black m4 steel rit dyed dark green & black lynch clip to match
-3- Shaman with cruwear dlc (knife joker exclusive) with gray micarta RGT scales and long gray lynch clip.
psylence
#33
Post by psylence »
dsvirsky wrote:
Sat Jan 01, 2022 7:16 am
BladeHQ site says it has flat grind.
Current EDC: 135CFP/217GS/152TIP/41PYL5/223PWH/211TIP/244CF90VP
dsvirsky
#34
Post by dsvirsky »
psylence wrote:
Sun Jan 02, 2022 10:39 am
Well, that would explain it. Thanks.
WRB
#35
Post by WRB »
No hollow grind? I don't plan on buying at this price but I'd be pretty upset if I did and missed that detail.
yablanowitz
#36
Post by yablanowitz »
Yep, flat saber grind instead of hollow saber grind. Not that it makes a huge difference at this scale.
VooDooChild
#37
I got mine. I like it. Its a weird little knife but its cool.
Kid
#38
Post by Kid »
Got mine today and I like it. Great ergonomics especially for a small knife, better than my lil native. And it’s definitely cool and weird! Only 3 left!
steelcity16
#39
Post by steelcity16 »
Kid wrote:
Mon Jan 03, 2022 9:03 pm
Post pics!
steelcity16
#40
VooDooChild wrote:
Mon Jan 03, 2022 6:24 pm
Post pics! Want to see the "flat grind". Shows a saber grind on the BHQ page.
