Serrata use?
Serrata use?
Hi, I was wondering for anyone who has actually used (not just own or owned) a Serrata what your experience is like (such as camping, using it on wood, etc.)?
- Manixguy@1994
Re: Serrata use?
I would like to hear comments myself from users of this fixed blade . . MG2
- VooDooChild
Re: Serrata use?
I havent used mine yet since I havent been able to go camping.
But I can say the handle and ergos are amazing!
Re: Serrata use?
Ergos are amazing indeed. So far I've used it only in the kitchen. Cuts like a beast. Not so good for thin slices, obviously. But meat and stuff like that is perfect food.
Michael
- Manixguy@1994
Re: Serrata use?
I really like your modification . When looking at the knife that is exactly what I thought was missing . Thank you , great pictures . MG2yablanowitz wrote: ↑Tue Dec 14, 2021 7:47 amNot sure any of my experience would be helpful since mine has been modified. I had to grind in a finger choil to make room for my hand and I thinned out the blade quite a bit. I haven't been camping in many years (other than Seconds Sales) so all I've done is a bit of aimless whittling.
Re: Serrata use?
Great! So, what kind of aimless whittling have you done, how does it cut?
Re: Serrata use?
Mostly making short sticks out of long sticks. It cuts well, and the edge stands up very nicely, but I've been using 440C for a very long time, and I like it. I don't know if it will last longer than other 440C, but it seems that it might. But remember, mine is about half as thick behind the edge since I thinned it down.
Re: Serrata use?
Great, ty. That is helpful. How much did you end up thinning it out (and was it the full width of the blade or just partially)?
Re: Serrata use?
Not quite the full height, the spine is still pretty close to original thickness. It was a factory second and had the Spyderbug ground off on a coarse belt. Not being any kind of grinder wiz (and working on a cheap Harbor Freight 1" belt sander not intended for metal) I cleaned that up as best I could and continued on until it felt more like a knife than a splitting wedge in my hands. At a guess, I'd say I took off between a fourth and a third of the thickness, and it is quite a bit flatter than it was.
Re: Serrata use?
Sounds like a mistake from manufacturing helped put it in a more useable state.
Re: Serrata use?
I can kinda understand the blade thickness using dendritic 440C in an outdoor fixed blade as I suspect its impact resistance is not exactly stellar.yablanowitz wrote: ↑Tue Dec 14, 2021 3:57 pmNot quite the full height, the spine is still pretty close to original thickness. It was a factory second and had the Spyderbug ground off on a coarse belt. Not being any kind of grinder wiz (and working on a cheap Harbor Freight 1" belt sander not intended for metal) I cleaned that up as best I could and continued on until it felt more like a knife than a splitting wedge in my hands. At a guess, I'd say I took off between a fourth and a third of the thickness, and it is quite a bit flatter than it was.
That being said, I completely agree with your decision for a thinner regrind and I think David Boye would too.
Many moons ago I visited Francine's engraving studio which was David Boye's primary outlet. I purchased a 10" Chef's custom by Smith out of Escondido, CA. He was one of the few authorized to use David's dendritic steel at the time. After using it for awhile, I felt it was way too thick for a Chef's knife. David Boye was hosting an event at Francine's one weekend and I couldn't make it so I sent it up there with my brother to voice my concerns. My brother overheard David mumble something like, I told him................" In any event David reground, re-etched and signed it at no charge.
In the kitchen, this knife edge is grabby and excels going through silver skin, gristle and proteins.
- Stuart Ackerman
Re: Serrata use?
My Serratas have 5mm spines and very thin edges, but the makers battled to replicate my grind.
The thicker versions are what you folks see in the Spyderco collab.
If I could afford to do it, i would buy up all the unsold Serrata seconds and regrind the profiles my way...and sell them on...
Re: Serrata use?
So, Stuart, what exactly did you design the serrata to be? A general knife for camping bushcraft, outdoors, or just a general knife that can do a little of common tasks?
- Stuart Ackerman
Re: Serrata use?
After reading about David Boye and his Dendritic Steel knives, I wanted an aggressive toothy edge in my knives.
After a lot of investigation, I designed a knife which looked nothing like the Serrata, and made it from N690.
Testing in the outdoors, batonning and cutting anything that was standing still, I made another knife, more ergonomic, which looked almost like the Serrata, and saved up to do an investment cast of a batch of 12 knives.
I made another blank to take a mold of, and did the deed.
I wanted a knife that could be used hard and hold a toothy edge, to be used in the kitchen, to quarter and skin any sort of animal and for fishing.
It is not a flexible blade, but you can almost fillet a barracuda neatly enough if you are careful.
I have made smaller versions, and narrower thickness blades and these are more suitable for for kitchen use, and skinning deer and wild pigs.
I did warn against batoning, as one fella broke the tip off. He claimed he was heavy handed, and not the fault of the knife, BUT I did not want folks to have a a blade that might fail in a serious situation. Maybe I am too cautious, but I had to say something.
BTW, I have batoned Spyderco Serratas and my own lighter and thinner versions, and never had a break of any sort.
Another BTW... I always have a folding saw with me...
Re: Serrata use?
So, it sounds like it can do a little bit of everything and baton, but wisely (not thick or hard knotted wood).
Re: Serrata use?
Hmmm, I'll be watching the sales when they happen.
Re: Serrata use?
I got one when they first came out (mine has a collector's number). Haven't used it a lot but did use it to partially skin and process a couple deer. I like the dendritic 440c. It holds up very nicely for use on meat, silver skin, tendons etc. It really does run circles around vg-10 in that role.
The thing is the Serrata is sort of heavy and I got tired of using it both times I used it for processing. I kept reaching for my Bill Moran or Temperance 2. It's just so heavy it's "slow" to make the cuts I needed to make. Maybe it's something to do with the balance too. I am not sure. I wish the stock were thinner. Anoth issue I have is it's thick behind the edge. Like 0.035 inch if I remember correctly.
The handle is well contoured and feels great. I like the knife and am keeping it. But it's an odd duck.
- Stuart Ackerman
Re: Serrata use?
My ones are 0.2mm behind the edge, on average...
Re: Serrata use?
I've used mine for campsite wood processing - making kindling and tinder from bigger pieces of wood when starting a campfire, carving tent stakes, etc. and food prep. Works great; cuts better than a thick heavy blade like it is really should. Love the thing. Probably my favorite Spyderco fixed blade.
(And I still want a tool steel version that can *really* be pounded on. Not that there's anything wrong with 440C, but Cruwear or 3V or, heck, even good old A2 or O1... mmm.)
