Oil stain in Micarta on PM2
jacala
Post by jacala »
Does anyone know the best way to remove an oil stain from micarta.
I somehow managed to get a 1/2 dia oil stain on the pivot end of my new PM2 Crucarta.
Thanks for any help and please refrain from giving criticism .I've already done 10 push-ups :cheap-sunglasses
Big_Tex
Re: Oil stain in Micarta on PM2
Post by Big_Tex »
I’ve found a drop of two of dawn dish soap and a toothbrush will do the trick. Alcohol may also work. Hope this helps!
Bryan
Atlanta, GA
IG @BryanCBailey
Current pocket rotation:
Z-Wear/Micarta Shaman
Magnacut Native 5 LW
k390 Endela
:bug-red : 73 Spydies in the collection
JRinFL
Post by JRinFL »
Many people would just oil the entire scales to even it out. I’ve done it with mineral oil on a couple of knives. Someone will come along and post what they used to remove the oil. I remember a post from a while back with a couple of methods.
Edit: Big Tex beat everyone on the draw. :cowboy
jacala
Post by jacala »
Thanks Big_Tex,
Already had a try with Isocol-will try again.
If still no good-will try dish soap and my wife's toothbrush :-)
jacala
Post by jacala »
Thanks JRinFL.
I will do the oil solution as a final fix.
ZrowsN1s
Post by ZrowsN1s »
This is why I prefer G-10. I've tried both methods btw. Oil the whole thing, and clean the whole thing with alcohol. Both work. And both are only temporary fixes. Oil it, the oil will dry out. Clean it with alcohol and it will eventually pick up oils :zany
In my experience with Micarta: The handle color will even out anyway over time (and/or get a uniquely used look anyway) if you really use the knife, just from the oils of your skin and whatever else the material will pick up.
Toucan
Post by Toucan »
if dish soap doesn't work, maybe some baking soda left on the stain over night?
If you're really brave I bet brake cleaner would do it, but may also do other things to the micarta. There's surely some kind of degreaser that will work.
curlyhairedboy
Post by curlyhairedboy »
Dawn dish soap will definitely work.
Phil Wilson
Location: Northern California in the heart of the Gold Country
Post by Phil Wilson »
Use the orange pumice hand cleaner and a tooth brush for both handle and blade. I have found that that works best for getting the gunk off after field dressing game and fish cleaning work. Phil
skeeg11
Post by skeeg11 »
Phil Wilson wrote:
Mon Nov 15, 2021 10:21 am
So good to see you posting on the forum. Now about that Spyderco collaboration you're working on............
Gtscotty
Post by Gtscotty »
99% iso worked to get ink off, as well as unintentionally took the oil off of my Micarta Neutron scales. I'd just rub oil over the rest of it.
Bemo
Post by Bemo »
If you're going to oil it, I would recommend a combo wax/oil. Most woodworking stores have a large variety of them. They typically are a combo of carnuba wax and either BLO or Tung Oil. I would caution you it changes the color. My blue Micarta still looks greenish.....
Post by Doc Dan »
I always oil my micarta, unless it is polished smooth and shiny.
However, if Dawn will take oil off of a duck, it will take that little bit of oil off of your scales.
jacala
Post by jacala »
I'm thinking about melting some (pure) beeswax and brush it on .Pros and Cons ??
I have a couple of blocks of the stuff. Used when I make projectiles for IPSC.
Superflex
Post by Superflex »
I oiled my PM2 micarta scales and 3 days later, they looked like the day I received them.
Just hit them with a light coat of mineral oil and it will even out.
