New Knife Steel Ratings by Knife Steel Nerds
Re: New Knife Steel Ratings by Knife Steel Nerds
Karl_H wrote:
Tue Oct 19, 2021 11:49 am
Tue Oct 19, 2021 10:48 am
I am - again - surprised how relatively "bad" REX45/HAP 40 fares. Especially how really not spectacular its toughness actually is. Of course I don't doubt the results at all (!), but this is different to what - also experienced - knife users always tend to say and also different to my own experience.
M4 seems to be the clearly better choice here: About the same edge retention, noticeable tougher.
I think Spyderco ran their Rex 45 too hard. Larrin tried to replicate the Spyderco heat treatment, which basically means that it wasn’t tempered for long enough to achieve an more optimal level of toughness. Tempering REX45 to 65 HRC would have resulted in a better balance of properties, in my opinion.
I think most Japanese knife makers that use HAP40 (Hitachi equivalent of REX 45) temper it down to about 65 HRC.
As far as I know (just what I heard) HAP 40 is run "softer" than REX 45 indeed. They say HAP 40can´t be as hard due to the cladding with SUS410 (again, just repeating what I read).
Now, from what you say, being a bit softer could actually be an advantage.
Still: My REX 45 Manix LW seems to be really tough in my use (just like my HAP40 knives). Not a scientific measurement at all of course, and perhaps in the typical pocket knife use extreme toughness is of not much relevance anyway... unless it allows for more acute edge angles!
Fireman
Post by Fireman »
Been preaching the LC200N for quite some time. My first intro to it was my Zwilling Cronidur 30 (aka lc200n) chef knife a decade ago. Never chipped it. I really only need to tune the edge and it is quite thin BTE. I now have the whole knife set but it is pricey at about 3k https://www.zwilling.com/us/zwilling/cutlery/twin-1731/
I hope Spyderco makes a kitchen set from LC200N so more people can enjoy this steel in the daily in the kitchen.
:winking-tongue Mule Team Army 001
MNOSD 008 :usflag
Image Stable Mules; Z-Max, Z-Wear, Magna Cut, SRS13, Rex 76, Rex T15.
Naperville
Post by Naperville »
3V's placement in the charts takes the luster off of A8 Mod.
Vanadis 8, and CPM 15V look interesting.
Another great read. Thank you!
Always fun to read and compare to my own experiences over the years.
Larrin
Post by Larrin »
metaphoricalsimile wrote:
Tue Oct 19, 2021 11:11 am
Am I missing something or is K390 not included in the ratings?
I haven’t tested the toughness of K390 so I decided not to rate it. It is in between Vanadis 8 and 10V for edge retention, closer to Vanadis 8.
metaphoricalsimile
Post by metaphoricalsimile »
Larrin wrote:
Tue Oct 19, 2021 12:37 pm
I wonder if spyderco fans can crowdsource funding for K390 testing? I know we're all thirsting for it, and I'm wondering if the reputation for relatively high toughness for its edge retention holds up to actual testing.
Larrin wrote:
Tue Oct 19, 2021 10:50 am
The ratings for Rex 45 are brought down some by the fact that it is used at high hardness only. But even if it was 62 Rc CPM-M4 would be both more wear resistant and tougher.
Thanks for the explanation!
GarageBoy
Post by GarageBoy »
Rex45 being ran super hard also results in the edge stability, no? That's how it earned it's reputation
That's why deadboxhero was carving brass rods with it etc
AlexRus
Post by AlexRus »
Thank you Larrin!
metaphoricalsimile
I'm curious about ease of sharpening/grinding ratings for all the steels too, as I think that is a very important criteria for knife purchases by end users. Is it a simple inverse linear relationship with edge retention/wear resistance, or is it more complex than that? I know that some steels have a reputation for being relatively easy to sharpen for their edge performance, but I don't think reputation means much without data, but AFAIK there is no good testing methodology for this aspect.
Radetzky
Post by Radetzky »
Thanks Dr. Larrin for this article!
Same feelings here.
I think it all comes down to personal preferences in use. REX45 is one of my favourite steels because I can get it scary sharp with very little effort and I really enjoy it in everday carry (I also don't care very much for corrosion resistance in most cases).
Larrin
#32
Post by Larrin »
Tue Oct 19, 2021 1:12 pm
The article has a paragraph discussing that
Cycletroll
#33
Post by Cycletroll »
Thank you Larrin!
Definitly some food for thought :)
Larrin
#34
Post by Larrin »
Tue Oct 19, 2021 12:43 pm
The limitation has been that I don’t have any in an appropriate size. Need 1/8” stock.
blues
#35
Post by blues »
Entertaining...and...educational. Fantastic work, Larrin. Thank you for sharing with us.
- Retired from the chase -
DrHE
#36
Post by DrHE »
My problem is I use them but I also love sharpening (or at least stropping to keep them keen) so I could likely have pot metal and it would hold up between touch ups. That said, I have been very happy with my ZDP189 and I am looking forward to using the M4 and CruWear PM2s I just bought. My trusty VG10 endura has been the most “chippy” steel thus far so we shall see how the harder ZDP189 is over time.
I have to admit my fixed blade hard use field knives tend to be O1, 1095 or 52100 so haven’t had much issue with getting and keeping them sharp.
M.N.O.S.D. 0031
Fireman
#37
Post by Fireman »
With how tough LC200N is, you would think we would see more large knives and choppers from that steel. I think I need a LC200N machete.
Magna Cut will hopefully be ubiquitous come next year. I only have one knife on order in it right now.
MNOSD 008 :usflag
metaphoricalsimile
#38
Fireman wrote:
Tue Oct 19, 2021 3:42 pm
I wonder if the difficult heat treating regimen makes larger blades more difficult than other steels.
z1r
#39
Post by z1r »
zuludelta wrote:
Tue Oct 19, 2021 11:21 am
z1r wrote:
Tue Oct 19, 2021 10:56 am
What actually surprised me was how well 8Cr13MoV faired. It gets so much crap talked about it but it holds an edge so much better than many HC steels and is definitely more corrosion resistant. And, in the Spyderco lineup, it's very affordable.
I think otherwise decent, affordable steels like AUS-8/8Cr13MoV and 440C develop a bad reputation partly because the market is flooded with cheap knives in those steels that have been poorly heat-treated or have really terrible edge geometry.
Spyderco does a good job with its 8Cr13MoV knives, but there are so many companies out there that regularly pump out 8Cr13MoV knives with edges that are ground terribly, & therefore not giving the steel the chance to perform anywhere close to its potential.
I have to agree, the 8Cr13NoV in my Byrds and Tenacious are head & shoulder above the same steel in another maker's knife I own. Night and day.
z1r
#40
Post by z1r »
TomAiello wrote:
Tue Oct 19, 2021 10:03 am
z1r wrote:
Tue Oct 19, 2021 9:54 am
Me too, thanks. A cursory look and it seems that I was right in questioning whether I needed an S110V N5 since I already have an S90V.
Spyderco's s110v has been substantially more stain resistant than Spyderco's s90v, in my uses. I prefer s90v for general use, but if I'm doing something where corrosion resistance is also important, I might opt for s110v.
Great point. One that doesn't apply to me since S90V is more than corrosion resistant for my needs and I'd prefer the toughness & edge retention of S90V or S110V. But other may find that additional corrosion resistance beneficial. Thanks for pointing that out!
