Xplorer wrote: ↑Tue Mar 16, 2021 5:05 pm
Looks great! I love the way the jimping turned out. Am I seeing correctly that you beveled the sides of the jimping?
As for Kydex..super easy for you. I seriously suggest you should do it yourself and you'll be happy that you will forever have the ability to make yourself a sheath any time, for any knife...in about an hour.
Get a sheet of Kydex or Holstex (I think it's only about $5.00 for 12x12) and get 1 piece of molding foam (11.5" x 11.5" is about $13.00). You can order grommets too but if you don't want to get a grommet setting tool (and don't already have one) you can just drill holes and use sex-bolt type fasteners that are about $1 a piece. In total you can make your own for as little as $22 plus shipping. But if you can spend the extra $10-$15 get a grommet setting tool and some grommets. All of this is available at USA Knifemaker.com and a bunch of other knife supply sources.
Cut the foam in half length-wise, so you have 2 pieces roughly 11.5" x 5.75". This is big enough for most sheaths you'll want to make. Then, sandwich the foam between 2 boards (1"x6"x12") in a bench vise and you're ready to mold a sheath.
Here's an example of the same type of quick and easy set-up...in this case I was making some blue-jean micarta but it's the same simple boards and vise idea.
Or...if you're feeling ambitious...one of the first tools I ever made myself as I started making Mule handles (prior to ever making my own knives) was a kydex press. I made it for free (other than the foam) because I had all of the materials laying around the garage. My point is, that if you decide you want to make a press you can do that as well..
Here's a couple of pictures in case you decide to make one.
It's only these 4 pieces plus 2 door hinges. (the wood in the picture is 3/4" plywood glued double thick so it's 1.5" thick)
A couple of large lag bolts hold the back down to the base and it provids a place to mount the hinges.
As you can see, it's not sexy...but it flat works.
Here's the first sheath I ever made with it..(back in 2015)
It was all kinds of crappy, but I didn't think so at the time..I was stoked to have made a sheath at all.
These are the last 2 sheaths I made on that press (about 10 days ago). One was Holstex for the scuba rig and the other was leather. I use the press to wet-mold leather to the knife prior to making the leather sheath so that is has a permanent custom fitted shape before I add oil to soften the leather.
To heat your kydex/holstex a toaster oven is a perfect solution, but if you don't have one, a regular oven works great too. Heat the oven to 400F and when you see the whitish edges (from cutting) flow to the same color as the rest of the material, it's ready to mold (about 90 sec - 2 minutes in the oven).
I'll give you the rest of the detailed instructions to help you through the little fitment issues and ways to do drain holes and other minutia if you decide you want to take on the project yourself. Just let me know.
Best regards,
CK
