Q-Ball 3D printed ball cage
Josh Crutchley
Post by Josh Crutchley »
I mentioned this in other threads but thought it needed its own. This is one of those knives you should definently try first hand before buying. The only way to unlock a Q-ball is to use your thumb nail to get the ball to move because you can't grip it. The Manix 2 and P'kal use caged BB locks with smaller bearings. The cage gives you something to actually grab instead of a polished smooth ball bearing.
The resin printer came in handy because I went through about 8 versions before it was right. The cage was printed in clear resin but I didn't really like the look so I dyed it black, I guess it should be white so it doesn't look like an 8 ball. I have a bunch of different Rit dyes and red is going to be the first color I try then maybe blue. It still needs some small tweaks to strengthen it in weak areas but as a prototype it works great. With the last version I'm able to operate the lock with one finger as long as you don't fling the blade open with force because it causes lock stick and that could break this resin version. The end goal would be to have it cast in bronze or machined in some other metal for more reliability.
Last edited by Josh Crutchley on Sun Jun 22, 2025 2:16 pm, edited 1 time in total.
Airlsee
Re: Q-Ball resin printed ball cage
Post by Airlsee »
Nice work!! This knife was literally just sitting in it's box for the last 2 years, I'm glad you have given it a new life!! If it had come with a CBB I probably would not have sold it, but then again I only bought it because it had the exposed ceramic ball so...haha!
So it goes.
ChrisinHove
Post by ChrisinHove »
Excellent work!
Josh Crutchley
This is the newest version almost there.
JRinFL
Post by JRinFL »
Are you going to send it out to be printed in metal to some place like Sculpteo or similar? Or do you have access to a metal printer?
Josh Crutchley
JRinFL wrote:
Wed Jun 23, 2021 1:10 pm
That would be the end goal because the resin isn't durable enough for long term.
I would like to go with some place like Shapeways to have it metal 3d printed but bronze casting is a possibility. The last iteration is very strong so I'm optimistic it could be injection molded.
Edit: This is it so far, I think it's ready just need some testing first. The supports were added in fusion because its a pain to get small objects to print without a raft but with supports. I got used to doing it when trying to get clear to actually print clear. The cage will more than likely need fitted to each individual knife so I put a little extra material in the weaker area. In my knife right out of the printer it will work but has a hard spot that only takes a little sanding to get it perfect.
Josh Crutchley
Update
Changed some clearances and added reinforcement in weak areas.
https://www.thingiverse.com/thing:5187245
Makes me wish I still had mine . Great effort on your part being persistent towards your goal . Dan
Bemo
Post by Bemo »
If these become available, I'm definitely getting one. Please keep us updated. And if it fits the Dodo also, well then that would be huge as well.
Josh Crutchley
Bemo wrote:
Sat Apr 30, 2022 8:55 pm
You could always download the file and have someone like Xometry or Shapeways print it for you.
araneae
Post by araneae »
The naked BBL is the reason I never bought what was an otherwise attractive model. It is the one thing Spyderco does that seems to be more about looks than function. Cage 'em up please. I never carry the D'allara for this reason, which is a shame.
-Nick
Last in: N5 Magnacut
zatch
Post by zatch »
Josh Crutchley wrote:
Mon Jun 21, 2021 6:51 am
With the last version I'm able to operate the lock with one finger as long as you don't fling the blade open with force because it causes lock stick and that could break this resin version. The end goal would be to have it casted in bronze or machined in some other metal for more reliability.
Hey Josh, is the blueprint you have on Thingiverse the most updated version? Any updates on this project? Just picked up a Q Ball and found out that my hands are not as tough and dexterous as I thought they were. Trying to find out the best way to get one of your cages printed
If they would ever ball cage this model I would have it back in my collection . MG2
Josh Crutchley
zatch wrote:
Wed May 11, 2022 10:07 am
Yes it is. I'm going to test it today and update any issues. It should be good as is but I did change a few things since my last test print.
Josh Crutchley
Newest revision SLS printed in Nylon 12. It's plain white color will work good since it covers the ceramic ball bearing. The texture is a little rough probably from the SLS process.
Josh Crutchley
Re: Q-Ball 3D printed ball cage
Figured this thread needs an update after 3yrs since we still don't have any new CBBL knives.
This is the latest version printed using HPs Muti Jet Fusion process in raw grey PA12S. Still had to do some hand fitting by sanding the top, bottom, and radius facing the blade.
Red Leader
Post by Red Leader »
As someone who has been modifying their own CBBL locks and such, this effort looks great! Is that printed metal?
Guts
Post by Guts »
After getting the recent Dodo exclusive, I've been thinking of designing something similar, but I see it's already been done. Thanks for sharing the link, might have to print one out later and try it.
zuludelta
Post by zuludelta »
If they ever make a Q-Ball 2 (and I hope they do—I've always wanted a more compact, wharnie version of the Manix), it should have a CBBL similar to this .
My most recent reviews:
Genzow HatchetHawk, Ikuchi, MicroJimbo
Josh Crutchley
Red Leader wrote:
Sun Jun 22, 2025 9:48 pm
Thanks. It's actually printed from nylon. I'm planning on trying Sculpteos cast brass for the next one.
Guts wrote:
Mon Jun 23, 2025 9:11 am
The dodo is slightly different so let me know how it works out.
