DLC coated Mule, would you be interested?
So I was looking at my new Z-Max mule, on which I currently wrapped the blade part with thick black tape so I can paracord-wrap the tang risk-free. The first layer of PC is bright neon orange. I must say this looks quite nice, the black and bright combined. :)
Two questions: would you be interested in a black blade Mule? And do you think Spyderco would do that - or rather why they wouldn't?
The DLC Mules could be like milestone Mules, like only every 10th Mule release could be a DLC run. Spyderco could time these runs to be with steels that have a known low rust tolerance. Just an idea...
So what do you think?
Michael
- WilliamMunny
Re: DLC coated Mule, would you be interested?
It could be cool for a steel like z-max but in general I don’t like the look of a blacked out blade. When you start using them it generally gets worn and scraped off.
Endura AUS-8, Manix 2 S30V, Alcyone BD1N, PM2 Micarta Cruwear, Native 5 Maxamet (2nd), Para 3 Maxamet (2nd), Magnacut Mule, Z-Wear Mule, BBB 15V Manix 2, REC PM3 10V Satin, Dragonfly Salt 2, GB2 M4.
WilliamMunny wrote: ↑Fri Jun 18, 2021 3:09 amIt could be cool for a steel like z-max but in general I don’t like the look of a blacked out blade. When you start using them it generally gets worn and scraped off.
Evidence of use, widely considered as good here on this forum.
Michael
- standy99
I like to see blade patina :cool:
Here's a little thread I made a couple years ago. DLC isn't anything like the cheap coatings you see on a lot of knives.WilliamMunny wrote: ↑Fri Jun 18, 2021 3:09 amIt could be cool for a steel like z-max but in general I don’t like the look of a blacked out blade. When you start using them it generally gets worn and scraped off.
viewtopic.php?f=2&t=85386&p=1379135&hil ... c#p1379135
15 's in 10 different steels
Mules are not meant as EDC knives or collectables. They are for using and testing the various steels on an identical platform. Adding DLC or other coatings changes a variable and as such the test results become less useful. Hard no to changing the Mule program in this way.
You can send your own blades out to be coated if you wish. When Spyderco releases the SPY27 "kit" knife blade, that's the time to ask for coatings, serrations, etc.
Valid point, didn't really think of that.
How much does it costs to have a blade coated by a specialist company, has anyone done that yet? Just out of curiosity, I'm sure the costs are in no good relation to the super affordable price of a Mule (even outside the current $50 sales push price).
Michael
- defenestrate
I think it would make sense, assuming that a standard, larger production Mule eventually comes out (SPY-27 was discussed IIRC), to also do a DLC version for a little more just to be able to compare the two. I would rather have new steels come out without a coating unless there was a new unique coating being tested, which again would most likely make more sense being added to a common Mule that most people could get to.
I would buy one, but it would be a lower priority than steels I haven't used before.
I could see offering the 'kit knife' mule in Spy 27 in variants, like SE, CE, DLC, etc. I don't really think that offering DLC adds much to the Mule Team project overall though.
I've looked into having Mules coated, and it's expensive, but not prohibitively so if you are making a long term user knife for yourself.
Then it's probably not DLC. It will get worn and scratched a bit, but in my experience it takes a lot to wear the dlc off of a blade. Not sure if Spyderco will do it, because of cost and production, but I'd love to test it.WilliamMunny wrote: ↑Fri Jun 18, 2021 3:09 amIt could be cool for a steel like z-max but in general I don’t like the look of a blacked out blade. When you start using them it generally gets worn and scraped off.
- spydie-fan
The mule team is meant to test new steels at a decent price. Adding DLC would increase the cost, and doesn't seem inline with the vision of the program.
TomAiello wrote: ↑Fri Jun 18, 2021 3:15 pmI could see offering the 'kit knife' mule in Spy 27 in variants, like SE, CE, DLC, etc. I don't really think that offering DLC adds much to the Mule Team project overall though.
How much roughly? A ballpark figure would do.
I wouldn't be asking for DLC becoming standard for all Mules. It could be a rare special edition of some kind. Like suggested, every 10th Mule or so?
Michael
Maybe sell a 2 knife set for this one. A simple steel like 1095 with dlc coating and without. Same HRC, same edge geometry and all, but one dlc and one without. I'd pay 125-150 for this experience, even more if the steel is better quality. Maybe up to 200 if it's the right steel. You know the ones. Thanks for the thought exercise.
For just one blade, in the $50 range. I also saw single blade DLC in the $100 range, but I was able to find cheaper places by looking around. If you are doing big batches the price comes way down (to something around $5 per place). I just never wanted to do more than one or two blades, personally, so the volume discount didn't matter to me.archangel wrote: ↑Fri Jun 18, 2021 3:22 pmTomAiello wrote: ↑Fri Jun 18, 2021 3:15 pmI could see offering the 'kit knife' mule in Spy 27 in variants, like SE, CE, DLC, etc. I don't really think that offering DLC adds much to the Mule Team project overall though.
DLC prices were a lot like heat treatment prices. Super expensive for just one blade, but much, much less expensive for 10+ blades, and downright cheap for 100+.
Thanks, Tom.
Michael
Voted no. But I *WOULD* buy a black blade mule if some of my favorite tool steels were re-issued...just to get the steel...
DLC Maxament?
Spyderco and Tops enthusiast
Obsessed with DLC Cruwear for some reason
Knives, Guns, and Watches, yes please
- Tom aka NotFixingIT
I voted for the last option, but I'm probably closer to no. 2. I think it's a neat idea, but would add too much cost to a project that already is probably a net loss for Spyderco.
- Connor
I didn't select any of the poll choices. I wouldn't *not* buy a Mule because of a blade coating, but I wouldn't buy one just for a coating, either. Whether it "looks cool" or not is totally irrelevant to me. I buy them to use, not to look at.
