Help a N00b. Recommend a backpacking knife
Hey Guys, self admitted knife n00b here looking to get my first quality knife. I want it for ultralight backpacking and am primarily considering the Delica 4, Para 3 Lightweight, or Native 5. I'd like to keep the knife around 2.5oz and a 2.5-3" blade which is how i landed on those models.
My main question is about steel. What alloys are considered best for back country use? I do not 'bushcraft' anything. My knife will mostly be used for cutting rope or webbing, the occasional steak (on a tiny plastic cutting board), or making a skewer out of a stick.
For the most part I want a blade that doesn't require much care and is moderately to highly corrosion resistant. I am targeting a premium steel as I like to Buy one Cry once. I see the Native 5 is regularly available in S30V while others seem to have lower grades in the non-special series?
What are the pros and cons of the commonly available steel grades of those knives?
Thanks in advance!
Thanks in advance!
Re: Help a N00b. Recommend a backpacking knife
Hi, ovgcguy:
Welcome to our forum. We hope you enjoy your time with us!
Kristi
Kristi
Whenever I go camping with the Scouts (I'm a scoutmaster) I always bring my S30V Manix 2. The knife is a tank and performs awesome at any outdoor task I throw its way. The Manix 2 also comes in a lightweight version that is only 2.9 ounces. I have never had any issue with the S30V steel. But given the choice I would go with the new SPY27 steel. It was not available when I got my Manix 2. Plus it is only $20 more than S30V.
Make time for the important things in life, and learn to enjoy the little things more.
ovgcguy wrote: ↑Thu Apr 22, 2021 4:18 pmHey Guys, self admitted knife n00b here looking to get my first quality knife. I want it for ultralight backpacking and am primarily considering the Delica 4, Para 3 Lightweight, or Native 5. I'd like to keep the knife around 2.5oz and a 2.5-3" blade which is how i landed on those models.
Welcome to the forum! :)
Aside from the steel choice (I know, you main question!)
For what you describe you want ((ultralight backpacking): Imho Salt 2 ffg, without any doubt! Basically a linerless Delica
Detailed reasoning see here viewtopic.php?f=2&t=88925
First impressions see here viewtopic.php?f=2&t=89256
In a nutshell:
- You get a 3" blade in a weight of 1.9 oz
- You get a totally corrosion resistant steel
- You get a lock that is safe in pocket, totally ambidextrous and perfectly usable with gloves / wet, cold hands
- You get the choice between wharnie and droppoint, PE and SE (I´d go with droppoint serrated)
Out of the choices you listed: For me Delica any day of the week
- Thin, slicey, but still strong bladestock at 2.5mm (Native 3mm, Para 3 even 3.7)
- A tad lighter than a linerless Para 3 while still offering solid liners
- More cutting edge than a Native
- Backlock always a win for me, especially in the outdoors
As far as steels go:
I think LC200N (totally corrosion resistant) and VG10 (very corrosion resistant) are perfectly fine for outdoor- and general EDC use! So is the BD1N of the Para 3 LW
S30V (Native) will hold an edge longer, but takes a bit more effort to sharpen and is a bit less rustproof.
- dj moonbat
Mule Team. With paracord wrap.
And see here viewtopic.php?f=11&t=88927 should you wonder why your posts don´t show up
Will change soon!
Will change soon!
I'd look at the Salt 2 LC200N. Right now it looks like it's only available in a wharncliffe blade but I'd expect it in a regular blade shape eventually. You could also just get the Pacific in LC200N, it's a bit bigger than 3 inches but only 2.9oz for a very good size knife and it's rust proof and will hold an edge well.
Evil D wrote: ↑Mon Apr 26, 2021 7:59 amI'd look at the Salt 2 LC200N. Right now it looks like it's only available in a wharncliffe blade but I'd expect it in a regular blade shape eventually. You could also just get the Pacific in LC200N, it's a bit bigger than 3 inches but only 2.9oz for a very good size knife and it's rust proof and will hold an edge well.
What?! viewtopic.php?f=2&t=89256
I like the Native ergonomically the most, so I would go with the Native Salt in rustproof LC200N steel. I would pick the serrated edge version, which will outlast a plain edge, so you don't need to carry a sharpener on a longer trip.
Welcome to the forums! :)
Wartstein wrote: ↑Mon Apr 26, 2021 8:07 amEvil D wrote: ↑Mon Apr 26, 2021 7:59 amI'd look at the Salt 2 LC200N. Right now it looks like it's only available in a wharncliffe blade but I'd expect it in a regular blade shape eventually. You could also just get the Pacific in LC200N, it's a bit bigger than 3 inches but only 2.9oz for a very good size knife and it's rust proof and will hold an edge well.
I couldn't find it anywhere :confused:
Even better, there's the 3 inch -2.5oz knife he's looking for.
The Spyderco Salt 2 (same basic knife as a Delica) in H1 or LC200N is what you are looking for. They are only 2.1 oz. They will not rust, period. If you get H1 you will want the serrated edge. It is easy to sharpen. knifeworks.com has all the models in stock, leaf blade and wharncliffe. I'd go with the leaf/clip point blade.
Doc Dan wrote: ↑Mon Apr 26, 2021 8:20 amThe Spyderco Salt 2 (same basic knife as a Delica) in H1 or LC200N is what you are looking for. They are only 2.1 oz. They will not rust, period. If you get H1 you will want the serrated edge. It is easy to sharpen. knifeworks.com has all the models in stock, leaf blade and wharncliffe. I'd go with the leaf/clip point blade.
1.9 oz in ffg (LC200N)...
That is very light and is the perfect solution. LC200N Salt 2 it is.Wartstein wrote: ↑Mon Apr 26, 2021 8:24 amDoc Dan wrote: ↑Mon Apr 26, 2021 8:20 amThe Spyderco Salt 2 (same basic knife as a Delica) in H1 or LC200N is what you are looking for. They are only 2.1 oz. They will not rust, period. If you get H1 you will want the serrated edge. It is easy to sharpen. knifeworks.com has all the models in stock, leaf blade and wharncliffe. I'd go with the leaf/clip point blade.
- steelcity16
Salt 2 in LC200N PE (model C88FPGR2) as has been recommended a few times already
in stock at dealers below and many others. Google model number C88FPGR2
https://www.bladehq.com/item--Spyderco- ... ht--121029
https://www.dlttrading.com/spyderco-sal ... 200n-blade
https://knifejoy.com/spyderco-c88fpgr2- ... n-3-satin/
https://www.knivesshipfree.com/spyderco ... -c88fpgr2/
SE edges cut like a buzz saw, but they're not as good at things like whittling and are arguably harder to sharpen in the field.
While a Sharpmaker doesn't weigh much, it takes a fair amount of space in a pack, where a credit card sized M/F diamond hone is no extra space at all. I guess you could just bring a medium SM rod with you, but any reprofiling would be slow going.
I like the Manix 2 LW suggestion, it's only a little heavier than your original picks and comes in BD1N (or SPY27/S110V), plus the extra size will probably come in handy out on the trail some day and with the choil and long FFG grind it still allows delicate detail cuts.
If you really can't go that big, the N5LW Salt and Salt 2 are good calls.
I absolutely love the Para 3, less so the P3LW, but that one is a great pick as well. Lots of people reference its thick blade stock, but the reality is that the long grind and thickness behind the edge make it a great slicer anyway, better than the S30V N5 (the N5 Salt seems to have a thinner grind).
-David
For a new Spyderco fan who wants a functional, affordable tool to take backpacking you can't go wrong with any of the models out of Spyderco's SALT SERIES.
But if none of those appeal to you then just carry whichever Spyderco model you find to be comfortable. To me comfort goes a long way toward having confidence in the tool you're working with.
Wartstein makes the best case, IMO. Go with a Salt 2 in LC200N.
And welcome to the forum! :)
- Connor
I replaced my Delica with an LC200N Salt 2 for my backpacking and trail running needs.
I echo the recommendation of others!
SE will maybe be harder to sharpen in the field (but really? On the corner of a small stone?), but it will STAY sharp a lot longer than PE and still "cut" / separate matter when dull, while PE is pretty much useless then.
Spydercos SE is also very good at whittling, as long as one just wants to make a pointy stick, carve a notch or the like.
For me better than PE - not due to the serrations themselves, but due to the chisel grind Spydercos SE comes in.
- cabfrank
Most people are saying PE, and maybe it is better. I would go with a Pacific Salt H1 SE for my choice though.
