Why don't they chrome plate carbon steel?
I bought a small Cattaraugus cleaver at a swap meet about 20 years ago. Cattaraugus Cutlery went out of business in 1963, so this cleaver is at least 57 years old.
The cleaver is made from "high carbon vanadium steel" which is chromium plated.
It's been sitting in a drawer in its original cardboard sleeve for the past 20 years. The blade is immaculate, like it was made last week. There is no trace of corrosion or any other degradation to the chrome finish. It shines like a '55 Chevy's front bumper. (The Bakelite handle is excellent too.)
Why don't they chrome-plate carbon steels nowadays? It seems like you could take Rex 45 or K390 or whatever and make it almost completely stainless. I used to have a ZDP Caly 3.5, so I know what cladding is, but chrome plating would be much harder than 420J.
Re: Why don't they chrome plate carbon steel?
That’s an interesting question that I would also like to know more about. Cladding is much thicker than plating, but the comparison to DLC is much closer.
Probably cost. The EPA practically shut down chrome plating, and where it can be done it's extremely expensive.
How durable is it?
- Connor
- The Mastiff
Gerber used to do it in the 70's on some. There was a famous maker that used O1 and he chromed his knives. Personally I don't think it's necessary. I couldn't think of any reason I'd want it done to my knives. For me corrosion isn't an issue. If it was I'd deal with it any of a number of ways other than chrome plating. When it finally goes bad chrome plating looks worse than regular corrosion.
- bearfacedkiller
I think that if you start to get corrosion at the bevel it will work under the plating and then start flaking off. Interested to see what other input we get from those with more knowledge.
:mad: **** it! Now I want to make a knife from a 57 chevy bumper
Mule Team Army 001
MNOSD 008
MNOSD 008
Marks on the blade are just reflections from some trees. There was no attempt to keep this blade dry - it has been stored in a cardboard sleeve for 57+ years. I wish I looked that good at 57!
- Deadboxhero
It seemed interesting.
I was able to find the guy that did the hard chrome for Gerber and he was nice enough to chrome some 4v blades for me for testing.
The problem now is that CPM MagnaCut exists,
Stainless 4V with the same toughness and finer carbides too.
So no reason to pursue in my mind.
I have a wonderful fixed blade D2 gerber that is CromeThe Mastiff wrote: ↑Wed Apr 14, 2021 11:45 amGerber used to do it in the 70's on some. There was a famous maker that used O1 and he chromed his knives. Personally I don't think it's necessary. I couldn't think of any reason I'd want it done to my knives. For me corrosion isn't an issue. If it was I'd deal with it any of a number of ways other than chrome plating. When it finally goes bad chrome plating looks worse than regular corrosion.
“”Think of an edge as a living thing that comes and goes, born, get's old, is reborn.””
SAL :spyder:
“ The best laid schemes o’ Mice an’ Men”
SAL :spyder:
Thanks BBB. What is that video showing exactly?Deadboxhero wrote: ↑Wed Apr 14, 2021 12:08 pmIt seemed interesting.
Mrs. Iron just brought home a box full of parts that she had chromed for the old Coca-Cola Machine she's restoring. They also did all the chrome on her old Mustang, and some trim parts on our old truck. The shop is about two miles from here. Doing chrome isn't easy. The surface has to be polished perfectly. Then it gets copper plated. Then it gets nickel plated. Then it gets the chrome. Maybe knife makers have more economical, more durable, and prettier alternatives. Personally, chrome isn't my favorite. I like brushed, tumbled, DLC, blasted...
This was my thinking as well.
Mule Team Army 001
MNOSD 008
MNOSD 008
Several years ago Strider had some models that were hard chromed by a company named Armoloy.
- VooDooChild
From the makers perspective it doesnt seem worth it.
Carbon steel is nice because its cheap, easy to heat treat, easier to work with, etc. But if your now going to add a whole process of chroming it, then it seems like you could have just bought a stainless steel and put up with the more difficult heat treat.
San Mai?
It was the solution from Japan around 1300AD.
Mule Team Army 001
MNOSD 008
MNOSD 008
I have an old Kabar J. Bowie that is chrome plated.
This was my first thought as well. Not all chrome plating is equal in quality, but I bet we've all seen some of it flake.bearfacedkiller wrote: ↑Wed Apr 14, 2021 11:53 amI think that if you start to get corrosion at the bevel it will work under the plating and then start flaking off. Interested to see what other input we get from those with more knowledge.
- araneae
It looks like they never put an edge on it...LarryInLex wrote: ↑Wed Apr 14, 2021 12:05 pm
-Nick
Last in: N5 Magnacut
-Nick
