I'm having an issue with US made Spydies
Way too much loctite.
WAY too much.
I've disassembled four US made Spydercos recently. Siren, Chief rex45 and two Manix XL's. All had screws slathered in white loctite.
The Siren had tons of white loctite on all the screws. I had to boil water to soak it to get it to release. It was the most difficulty I've ever had taking apart a knife.
The S30V Manix XL had so much loc-tite it broke my torx bit, completely warping the head. Stripped a pivot screw in the process of trying to take it apart. It was honestly so bad trying to take it apart the first time I thought about selling it for that reason alone. Again I had to boil a pot of water to make the screws even consider the idea of rotating.
Tonight I tried to disassemble my Chief. I couldn't. Not with the tools I have. I managed to get the blade out, but I couldn't remove the stop pin by wrapping rubber around it and pulling it with needle nose pliers. Had to give up with that. Couldn't remove the steel backspacer because the rear body screw stripped as soon as I tried to do anything with it. This was after soaking it in boiling water before even attempting anything, based on my experiences with other US models.
This is starting to become a problem for me. I don't like the idea of breaking my tools trying to take apart my pocket knives. Never seem to have this issue to japanese models. My Police 3 is so easy to service I can take it apart in my sleep.
:unicorn
Re: I'm having an issue with US made Spydies
That sounds really unfortunate...
Wonder what others will contribute, so if this is an universal issue with all /most US Spydies.
Just tried to remember which US Spydercos I ever took apart myself: Very few actually.
I think just a PM2 (no problems, but it is an a bit older one) and a Millie (but that one had custom scales applied not by me, so potentially "too much locktite from the factory" was already removed).
Never took apart my Native 5 LW, and obviously not my pinned Manixes LW.
Perhaps I am forgetting one, but I guess that´s it in my case.
ZrowsN1s
Post by ZrowsN1s »
One of the Pivot screws on my Rex45 Chief was stubborn to the point it started to spin damaging the D hole on one of the scales. Had to put the other side back on to loosen it. But other than that everything else came apart ok.
A possibility here might be the torx set you are using. I find the Wiha Torx drivers fit very well. I never have issues with stripping. To the point where the G-10 strips before the screws do apparently. You might try switching brands.
I did also have trouble with the Chief stop pin. The tolerances there are 'press fit'. I used my lynch pry bar wraped in a micro fiber cloth to get it apart, and had to use a padded clamp to press it back together.
VooDooChild
Post by VooDooChild »
Except the seki spydies have no loctite and the screws loosen and then some person finally has a screw fall out and writes a review about the knife "breaking" even though its because they didnt maintain their knife.
Too much is also a pain though.
CPM-Greg
Post by CPM-Greg »
That's dreadful and I too have faced this challenge, but not to the degree you experienced. Good luck and change can occur when we give feedback. Thanks.
Take care, be safe and stay sharp
CPM-Greg
Thinking about which Taichung blade to get next.......
kobold
Post by kobold »
To be fair, so far I disassembled most of my spyders without any troubles, not even heat was necessary. About three Natives in both G10 and FRN, Para 3 and PM2 in G10, Manix 2 in G10 from Golden. Two Chaparrals and a Sage 5 CF from Taichung.
Speaking of Taichung, my only - as they say - catastrophic failure was with the Caribbean resulting in two stripped screws. For which I half jokingly blame Nick Shabazz for in his video ( https://youtu.be/vwS8h_wF7n0 ) he is using force and I tried to do the same. So that was stupid :o
w3tnz
Post by w3tnz »
Without seeing the screw threads / residual loctite hard to say what’s too much, but if they are using the correct kind (blue or equivalent) then it shouldn’t be too much issue even if there is some excess.
You should consider investing in a quality torx bit set, that would solve most if not all of your troubles and if you really need to apply some heat try a soldering iron directly on the screw.
I haven't even tried to take apart my Shaman..makes me nervous to try. The last US made knives I've bought were all Native 5's and they've come apart fine. I wonder if this is just an individual getting a little over excited during assembly?
My Caribbeans were absolutely caked with white colored thread locker. One of the pivot screws is permanently attached to the pivot. I consider myself to be well above average in being able to get knives apart without stripping screws and overcoming thread locker (just based on all the threads seeing how often people struggle with it while I rarely do) so when I encounter one that's hard to get apart it had to be really bad.
curlyhairedboy
Post by curlyhairedboy »
I usually use Eric’s tip about a sharp hit to the top of the tool to break the bond.
aicolainen
Post by aicolainen »
Don’t take apart my knives very often, but I did take apart the Rex lil’native. It was scary tight, but not impossible to get apart. Made sure to use my very best torx bits though.
Oloung1
Post by Oloung1 »
On the subject of torx bits (can't help with the dreaded locktite situation), I've read on another forum that some screws are "torx plus" IP6 or IP8.
So I bought new Wiha IP6 and IP8 bits, seems like there are some tolerance differences between some clip screws versus body screws for the t6/ip6. On some screws the IP6 fit tighter, then on other screws they are too tight to fit (on an endura and cara cara).
ThomC
Post by ThomC »
That's unfortunate. I've taken apart 4 U.S. Spydies of different years, both with red and blue loctite.
Not one of them was particularly difficult to disassemble.
PM2 and Millie in S30V, Manix 2 XL in S90V, and the Rex45 Shaman. And I was the first owner/user for all of these.
Maybe the problem comes from the white loctite ? I never saw that type on the U.S. Spydies I took apart.
European amateur knife enthusiast
Hikes and outdoors galore
🏍️Motorcycle enthusiast
In the knoife box : M4 Millie, Spyderco Perrin Street Bowie, TOPS Tanimboca
In the future : CE/SE/Rex45/MagnaCut Millie, K2, Slysz Bowie, linerlock Sage
JohnDoe99
Post by JohnDoe99 »
Why are you taking them apart? There is a warranty process in place.
I prefer Spyderco keep doing what they are doing, like securing the product at the factory so I don't have to. The idea that we need to disassemble them later on and tinker with them is part of the overall, weird obsession over what are no more than pocket tools, similar to the steel bs. If we could kill that obsession, maybe the massive price inflation would come back down.
Rp5
Post by Rp5 »
Pivot on my recent Shaman purchase (Cutlery Shoppe orange) was also pretty heavy with white threadlocker. I wouldn't say it was caked on, maybe 3 or 4 threads up, but it was very tough to disassemble. Worried quite a bit that I would strip the screw, but in the end managed to get it unscrewed. Thankfully only on the pivot.
ThomC
Post by ThomC »
JohnDoe99 wrote:
Thu Apr 08, 2021 5:49 am
The warranty process has been altered so that disassembly doesn't void it anymore.
Maybe some of us are interested in learning and understanding firsthand how our tools work, or just like to do basic maintenance without sending the knife back or being able to do so (like overseas Spydie fans).
You've never taken apart a tool to clean it before ?
I won't even touch on the "steel bs".
M Sea
Post by M Sea »
ThomC wrote:
Thu Apr 08, 2021 6:13 am
With you 100 %. I live on an island in a highly humid/corrosive environment. I have to get in to my knives just to properly lubricate/care for them. Not to mention if I ever wanted to change scales, adjust pivots etc. I am sure there is a valid perfectly good reason why they didn’t use screws on the Manix LW’s but my Maxamet one gets gritty monthly and just hitting it with blue lube/ballistol/rem-oil etc., eventually gunks it up. It should be easy to disassemble for cleaning. Very frustrating. All that said I just bought another one in SPY27 so it speaks for how much I enjoy the knife but disassembly shouldn’t be so difficult.
:confused: :confused: :confused: Some of us like to use our knives, which then require care and disassembly to make sure the moving parts still move and function properly. Maybe you're scared to do so, so look down on others that like to tinker?? No different than your vehicle needing an oil change, some people like to pay for someone else to do it, others like to do it themselves.
As others said, disassembly doesn't void the warranty. Also, "the steel bs" again...some of us use our knives, or work in environments where stainless or tool steel is better for the job at hand. Sounds like you've got a lot to learn...
The Meat man
Post by The Meat man »
If you're a member of this forum I don't think you're in a position to criticize other people's weird obsessions. :rolleyes: ;)
- Connor
The Meat man
That's a bummer, vivi!
Personally I haven't had the same trouble, although I've only acquired one Golden-made Spyderco recently - the Z-Wear Shaman. That one disassembled fine without any tricks. Hope you can get that stripped screw out. :(
- Connor
Eliteone2383
Post by Eliteone2383 »
You're wrong. It's not to tinker it's to maintain. Just like a firearm. You don't take it apart just for fun. It's required in order to maintain. Nothing wrong with wanting to make sure things you paid money for are in good working order at all times.
Stay sharp!
