I never thought of ZDP as "easy" to sharpen. Hahaha! It is not as bad as S110V though, for a fact. Plus, it can be done on regular stones, but it takes a while, at least for me.
I have two knives in ZDP-189 and neither have rusted. I have a Caly3 and a Nishijin Dragonfly. Overall, it is a nice steel. It will take a wicked edge, I mean really wicked, but if it gets dull it is a chore to get back. The best option is to never let it get dull.
If you have any sharpening tips, I'm all ears. Light an easy for sure. Anything else?
Ok received my caly 3.5. Some issues though
Re: Ok received my caly 3.5. Some issues though
Doc Dan wrote: ↑Wed Mar 31, 2021 7:51 amI never thought of ZDP as "easy" to sharpen. Hahaha! It is not as bad as S110V though, for a fact. Plus, it can be done on regular stones, but it takes a while, at least for me.
I just have the one ZDP Delica but I really enjoy sharpening it and seem to have found a way to keep a good edge on it. In my opinion, diamond stones are a must have for this steel. To prevent any issues with burrs, I recommend ending each grit with lots of alternating passes on the stone before moving on the the next finest. 1200-1500 grit seems to be a good place to end for this steel. I strop with diamond solution for a bit to finish it off, alternating strokes again.
- Cambertree
If it worries you just use some small pieces of sandpaper to smooth and clean off those surfaces. 800 to 1200 grit would do it.
ZDP189 is a great steel in my opinion and the Caly 3.5 is a superb, underrated model.
I really like the fine edge it takes and it holds it very well.
Patience, correct abrasives and a light touch with your finishing pressure is key.
My ZDP189 Dragonfly is probably my most used Spyderco model.
Rust on a new knife would bother me too, but then I can even stand fingerprints on my blades!
