Manix Rust?
Lil Timmy
Manix Rust?
Post by Lil Timmy »
I recently purchased a Manix, and am concerned that it may be rusting. The part of the blade that hooks up with the lock back has a red-rust colored look. I tried wiping it with a q-tip dipped in oil, but the q-tip came up clean. So I am wondering if maybe this is some kind of protective coating for that area of the blade? Anyone else have this on their knife? :confused:
Mr Blonde
Post by Mr Blonde »
It's not rust, but the bare finish left by laser cutting the parts.
Wouter
Last website update: 11-30-2025 Instagram
greencobra
Post by greencobra »
I don't know guys. dani was posting of the same thing not to long ago but all his pics showed the discoloration on the lock, not the blade. And Lil Timmy, you can always get rust off
Wouter, what's this discoloration on the bare part of the blade? :confused: Rust, I would guess cause I've never seen the color of steel to be rusty red.
I wish someone from Spyderco would comment on this, cause I just searched the forum for rust and it's rarely mentioned until recently.
Some say rust, some steel discoloration, some lube, or fluids from the cutting process. Come on Spyderco, it's a concern enough that people keep bringing it up. Clue us in on what it is.
Post by The Deacon »
Given its location, on the part of the blade where the lock bar engages, and the fact that it does not rub off on your Q-tip it certainly sounds like discoloration from the laser cutting process rather than rust. I have never encountered rust that would not stain a piece of cloth or paper towel rubbed across it.
TazKristi
Post by TazKristi »
Hopefully, this will clear this up. I ran Dani's pictures down to our Shop Foreman just to be sure... it is discoloration caused by heat treating. It is not rust. No need for concern.
Thanks for your inquiry.
Kristi
Lil Timmy
Post by Lil Timmy »
Here's a couple pics of it. Does your Manix look like this?
Manix Rust 4.jpg (38.63 KiB) Viewed 2093 times
Manix Rust 2.jpg (47.41 KiB) Viewed 2128 times
greencobra
TazKristi wrote:Hopefully, this will clear this up. I ran Dani's pictures down to our Shop Foreman just to be sure... it is discoloration caused by heat treating. It is not rust. No need for concern.
Kristi
Thanks so much, Kristi.
dani
Post by dani »
Lil Timmy wrote:Here's a pic of it. Does your Manix look like this?
Yes, something similar.
dani
Post by dani »
Kristi
Thanks very much for the interest and the response! :)
TazKristi
Post by TazKristi »
No problem, sorry it took a while. Things get pretty busy here, so we don't always get to be in the forums as much as we might like. We promise though, we do our best to get your questions answered.
Take care and have a great weekend!
Lil Timmy
Post by Lil Timmy »
TazKristi wrote:No problem, sorry it took a while. Things get pretty busy here, so we don't always get to be in the forums as much as we might like. We promise though, we do our best to get your questions answered.
What about my knife? Is that rust?
Mr Blonde
Post by Mr Blonde »
Thanks for the answer Tazkristi! BTW, My manix looks the same, although a steady buildup of lube residu has made it pretty much invisible. Back to cleaning!
Wouter
TazKristi
Post by TazKristi »
Lil Timmy,
Yes, it is the same thing, not rust. Sorry, should have been more clear.
Kristi
