The Meat man
#24721
Post by The Meat man »
The axe was a Christmas gift from my very special wife. :)
- Connor
aicolainen
#24722
Post by aicolainen »
The Meat man wrote:
Sun Jan 10, 2021 11:42 am
That looks like fun. :cool:
Sure was!
Having kids and bringing them along in the outdoors, passing on the appreciation and skills, has really reopened my own eyes to the pleasures of simple outdoor life.
Used to be chasing the highest mountains, the longest trails and other extremes, but that’s really no requirement to have a good time.
The Meat man wrote: Image
That doesn’t look like to bad if a day either!
And of course enhanced by a good axe. I’ve got to admit, the Swedes know their axes. Have a couple from the Hultafors premium line, and consider getting the Gransfors Outdoor axe.
The Meat man
#24723
aicolainen wrote:
Sun Jan 10, 2021 4:27 pm
Sure was!
The Meat man wrote: [Img]https://i.imgur.com/OduIL3z.jpg[/img
There is something about going out into the cold winter woods and starting a fire. :)
I don't have a ton of experience with axes, but this one is by far the best I've ever handled. It is so sharp, and thin. The axes you buy at department stores today are a joke - they're so thick and obtuse it's like trying to chop with a splitting wedge. Not so this! It really bites in. I was cleanly slicing 2" branches in one blow.
- Connor
mtb2104
#24724
Post by mtb2104 »
lorgar
#24725
Post by lorgar »
Really nice knife.
My last but not the least spyderco folder :
Pancake
#24726
Post by Pancake »
aicolainen wrote:
Sun Jan 10, 2021 10:23 am
That’s very interesting, can you explain whats been done to it?
In my experience the factory grind works well for batoning, but leaves something to be desired with regards to whittling and carving. I’m not really impressed by how it’s processing fish either, but that’s probably just a sharpness issue. It wasn’t typical Spyderco sharp out of the box, and I haven’t gotten around to resharpen it yet.
I don’t expect it to shine in every discipline, but a wee bit better for wood would make it a near perfect all rounder for my use.
This is the message that I send to Wartstein earlier
,,The main reason I did the regrind was that the secondary bevel was going bit too high for my taste.
I have a simple belt grinder at home, so I took the knife to the grinder and basically I blend the secondary and primary bevel into one slight convex bevel. And while doing so, I also thinned it out a it, I would say it is like 20-30 % thinner as out the box. Of course, while doing so, the blade was cooled in water.
Spine of the knife is still more or less the same thickness as it was, but the distal taper is a bit more pronounced.
Then I hand sanded it to I guess 220 grit. One problem that I found is the plunge line. It has hard 90 ° corner and it is pain to finish nicely. So after some handsanding and cursing I call it good enough and leave it with those some scratches. So what I had after doing so was one slightly convex bevel to almost zero edge.
After that, I hand sharpen it to around 17° with 20° microbevel. Not sure how much time I spend with it, but I tell you, the difference was there. When cutting something like a onion, the knife goes into it much smoother and efficient, probably because there is no real hard transition from secondary to primary bevel.,,
I just want to point out that my belt grinder is not a ,,pro,, grade and it cuts in a slight convex way, so its near impossible to get a straight primary bevel. It will be convex no matter what.
Main bulk was done with 60 grit ceramic belt, rest was hard manual handsanding. As I wrote, the main problem area is the plunge line, because of that hard 90 ° corner, which is hard (for me) to finish.
Can you do it without the belt grinder? Maybe, with like 60 grit diamond / silicon carbide stone and a TON of time....but I would not do it for any money in the world (well, ok....maybe). You have to take some metal away when you want blend primary and secondary bevel to one convex, and it will be quite long process without power tools.
I am happy that Wartstein is happy with this knife. Waterway is great desing, Lance Clinton did a great job on it.
To be not 100 % off topic, I am carrying a Manix 2 REX 45 G10 today.
aicolainen
#24727
Pancake wrote:
Mon Jan 11, 2021 12:47 am
Thank you, pancake!
I don’t believe neither my confidence or equipment is up to the task just yet, but I’ve saved your instructions for when that day comes.
I might even do it, or something similar, in steps as things progress
M Sea
#24728
Post by M Sea »
GiftedMisfit
#24729
Post by GiftedMisfit »
:cussing
Featherblade
#24730
Post by Featherblade »
#24731
Manix Monday!
VashHash
#24732
Post by VashHash »
So no one complains it's not in my pocket :cool:
#24733
Mon Jan 11, 2021 12:53 pm
Manix Monday!
Very nice pic (composition and colors)!
Another one of those I´d really like to see in a larger size...
#24734
Mon Jan 11, 2021 1:02 pm
Manix Monday!
I believe if you click the image, it shows up a bit larger and more detailed.
Enactive
#24735
Post by Enactive »
GiftedMisfit wrote:
Mon Jan 11, 2021 10:27 am
Nice one.
#24736
CruWear Delica
Cat
Ti Squarehead
The Meat man
#24737
mtb2104 wrote:
Sun Jan 10, 2021 7:56 pm
That's a great photo! :thumbsup:
- Connor
PStone
#24738
Post by PStone »
Battlestation
Sumdumguy
#24740
Post by Sumdumguy »
Mon Jan 11, 2021 5:11 pm
King Crimson! I love me some Tony Levin.
-Thomas Jefferson
