You can have a stop pin along with the backlock. I know that configuration has tested well. Surely the Triad lock is encumbered with patents, so the PowerLock is a way of approximating its behavior. I started this thread because I was hoping to see some shots of the lock itself and maybe a video of how the locks functions when engaging and disengaging. The thread took an unexpected turn when Sal asked which model would be a good candidate for the lock. I am mostly just curious about the mechanics of the lock and not necessarily advocating its return.
Power Lock
Re: Power Lock
Re: Power Lock
I am sorry you are offended. I have an honest question regarding this lock. I have no experience with it and I have yet to see a test on it, except the one done by Cold Steel, of course.yablanowitz wrote: ↑Mon Oct 26, 2020 8:11 amYep. And using lugnuts to hold the wheels on your car instead of welding them on could lead to wheel loss on the road. The gap is closed when the knife is closed or open. If wiping your thumb down the spine of the handle to the lock release is too much effort for you, by all means avoid this lock.Doc Dan wrote: ↑Sun Oct 25, 2020 11:03 pmYes, that gap between the toggle and the lock bar concerns me. That well could be blown out, but this joint at the toggle/lockbar seems to me to be a potential problem. I am not saying that it is, but it looks like getting gunk in there could pose a problem with lockup.yablanowitz wrote: ↑Sun Oct 25, 2020 12:11 pm
Get enough sand and grit in that gap and it could prevent the lock from locking by jamming the toggle.
The gap is closed when the knife is open and locked, so a simple wipe with your thumb before working the lock would be enough to prevent problems.
- curlyhairedboy
Re: Power Lock
I'd be curious to see this on some of the more defense-oriented knives. I know many of them already have the sturdy compression lock, but stuff like the civilian/matriarch line still relies on a conventional lockback. I could see the added strength of the power lock doing a lot to assure peace of mind - the matriarch is not a knife you want closing on you.
Re: Power Lock
The ricasso will protect your hand if the lock fails been there done that.
What are lockbacks not strong enough for?
The debris in my area consists of course sand and clay based dirt it f**** up compression locks liner locks and ball locks. Mostly it locks the knife open so it is unclosable. Lockbacks are the easiest to clean out and easiest to close in this environment
Axis locks are terrible in debris also. Never use one for food prep either while you're camping as botulism is only a day away..... Very difficult to clean the debris from food out of the mechanism without disassembling.
If perceived lock strength is more important than steel and ergonomics and quality then go get a cold steel
A $35 Phil Wilson copy made by Spyderco is stronger than any folder out there and safer.
Tools for the job.....
Re: Power Lock
The way the reverse-S blades are meant to be used (slashing cuts) doesn’t place a heavy burden upon the lock. These are not for thrusting cuts. The simple mid lock seems totally adequate on these models.curlyhairedboy wrote: ↑Mon Oct 26, 2020 9:59 amI'd be curious to see this on some of the more defense-oriented knives. I know many of them already have the sturdy compression lock, but stuff like the civilian/matriarch line still relies on a conventional lockback. I could see the added strength of the power lock doing a lot to assure peace of mind - the matriarch is not a knife you want closing on you.
Re: Power Lock
I'd still like a Manix XLPL.
Re: Power Lock
I'd buy that so hard. If this lock really is that strong it's the perfect current model for it.
Re: Power Lock
If a backlock can’t fit into a Shaman, I tend to think a power lock couldn’t either. At least not without some significant redesign.
-Nick
Re: Power Lock
In the same way a mid-lock found its way into a Manix2, I’d be all for a power-lock, or even a mid-lock, in a Shaman, just to own the difference and to have the ambidexterity. But the standard lock is likely the stronger, and is no challenge to my left-hanbedness.
Re: Power Lock
re: sal's question: a strong lockback designed for hard use is immediately attractive for an outdoor folder that could take the place of a fixed blade with less bulk, potentially less weight, and significantly easier portability/carryability. therefore the ideal knife for this lock as I picture it would be designed around, or in concert with, the lock's properties itself, towards outdoor (wood, rope, tough/abrasive natural materials, food) uses.
what about something like a folding version of the bushcraft? I know the wolfspdyer will be re-released eventually, but that's got its niche. maybe a larger version with a somewhat different orientation or design? i'm from central/northern nys, and there is no end of use a good outdoor knife would enjoy here. lakes, woods, farms, yards, camping, you name it. the gb2 is at this point my go to bigger folder that i'd bring for this purpose, above the pm2, stretch, n5 and family, any of them. something like a gb2 or bushcraft in any strong, tough, long-lasting steel would be extremely attractive to me.
Re: Power Lock
+1 for the manix. Tip down carry would be nice.
Re: Power Lock
bleasure wrote: ↑Sat Feb 11, 2023 12:00 pmre: sal's question: a strong lockback designed for hard use is immediately attractive for an outdoor folder that could take the place of a fixed blade with less bulk, potentially less weight, and significantly easier portability/carryability. therefore the ideal knife for this lock as I picture it would be designed around, or in concert with, the lock's properties itself, towards outdoor (wood, rope, tough/abrasive natural materials, food) uses.
We need a Sprint Tatanka in K390!
Re: Power Lock
reading through this thread, it seems apparent to me that any power lock probably needs to be made in Seki, so folks wanting the power lock in US models might be a no go?
Something like a PowerStretch or PowerEndura might be more actionable.
Re: Power Lock
I would buy a drop point PowerStretch! Gray G10 and Cruwear anyone?
Re: Power Lock
I sure hope that's not the case. I think Golden makes the best mid back lock on the market, I feel like they could produce this lock and it would be legendary.
Re: Power Lock
I have read that it was invented by one of the brothers who run G Sakai, so the intellectual property is probably theirs?
I could be flat out wrong about the IP part of that.
https://www.candlepowerforums.com/threa ... 10.403716/
This new lock, the PowerLock, was actually invented by one of five brothers who work at the facility making Spyderco knives in Japan. The design was shown to Sal 5 or 6 years ago, but Spyderco, who already held a patent for a similar lock (the StopLock), were too busy at the time simply keeping up with demand so could not act on it at the time. With the PowerLock being designed in Japan it was decided to have the Tatanka manufactured in the same facility by the designers of the lock.
- apollo
Re: Power Lock
Also +1 on the Manix aslong as they do not chicken out again ( like last time ) and KEEP the darn Liners instead of removing them!!! And while they are at it return to the old blade stock and blade shape ! The new blade stock on the current Manix 2’s and XL’s is not good enough for this purpose build and the old blade shape looks allot better to !
- Manixguy@1994
Re: Power Lock
I could live with any sprint Tatanka run , or a Manix XL with the power lock . MG25-by-5 wrote: ↑Sat Feb 11, 2023 12:42 pmbleasure wrote: ↑Sat Feb 11, 2023 12:00 pmre: sal's question: a strong lockback designed for hard use is immediately attractive for an outdoor folder that could take the place of a fixed blade with less bulk, potentially less weight, and significantly easier portability/carryability. therefore the ideal knife for this lock as I picture it would be designed around, or in concert with, the lock's properties itself, towards outdoor (wood, rope, tough/abrasive natural materials, food) uses.
Re: Power Lock
I guess the Spyderco back lock it's a lock type very secure and well made and enough for almost all users.
About all the models I read I guess Military for obvious reason is an open back construction folder, and one closed or semi-closed with a power lock or back lock model would lose the sense of the project, and would be better call it different, and not military. The military in my opinion is one of the best knives I ever seen around and of course is the best one I own, as I told is not interesting with the back lock, and the Military 2 with the CL will be not the same.
Power lock it's for heavy duties so the sense would be making a Tatanka 2 (I would pass as the original, because I don't work with knives)
If i would suggest two new-old models where power lock would be nice they are Chinook 4, and a second model for relatively heavy tasks, but pocket and social friendly, equipped with RINO lil' temperance 2 blade and handle based on a model as lil' native.
