S30V DLC Corrosion?
cletusvandamme
S30V DLC Corrosion?
Post by cletusvandamme »
I recently purchased a blacked out yojimbo 2 on the secondary market that came like this.
Has anyone had any success with polishing something like this away?
:spyder:: PM 2, Manix 2, Dragonfly 2, Bradley 2, Yojimbo 2, P'kal, Caribbean, Kapara, Province
prndltech
Re: S30V DLC Corrosion?
Post by prndltech »
It doesn’t wipe right off with some oil? DLC coating is absorbent. Try a heavy coat of some oil/lubricant and see what happens. You’ll notice it soaks it up.
- Shannon
MNOSD 0006
cletusvandamme
Tried soap, solvents and oil while scrubbing with a toothbrush. It doesnt come off
cletusvandamme
No. I have tried scrubbing it with soap, alcohol and oil and it still looks the same
Hi Cletusvandamme,
Welcome to our forum.
Where are you?
cletusvandamme
Hi. Thanks Sal
Im from sweden
Fred Sanford
Post by Fred Sanford »
I bet it comes off with Flitz (metal polish). There are folks here who have Flitz'd coated blades with great luck. I have never done it.
Hi Cletusvandamme,
I would try the Flitz metal polish and let me know if that works? Put it on and let it stand for about 15 minutes, then wipe it off.
JRinFL
Post by JRinFL »
Vivi has a related post about a DLC coated blade that will be of interest to you. He had similar stains on his DLC M4 Manix XL.
https://forum.spyderco.com/viewtopic.php?f=2&t=87786
JRinFL wrote:
Thu Oct 15, 2020 1:37 pm
I might have to try Sal's cleaning suggestion on it. This weekend I plan to reprofile that knife and step up my cleaning attempts.
:unicorn
Fred Sanford wrote:
Thu Oct 15, 2020 12:26 pm
sal wrote:
Thu Oct 15, 2020 12:49 pm
Hi Cletusvandamme,
I've used Flitz on DLC quite a lot and it works great.
jpm2
Post by jpm2 »
cletusvandamme wrote:
Thu Oct 15, 2020 8:48 am
Is it sitting on top of the coating or is it depressions? How does it feel when you run a fingernail across it?
curlyhairedboy
Post by curlyhairedboy »
i've seen this before on my DLC coated blades, in both s30v and 4v. It does come off with liquid Barkeeper's Friend cleaner.
cletusvandamme
jpm2 wrote:
Thu Oct 15, 2020 7:08 pm
It can barely be felt. But here is another picture with different lightning and it looks like rust.
I will try the flitz polish once it gets here
jpm2
Post by jpm2 »
Fri Oct 16, 2020 11:37 am
Maybe it's just the light but it looks like a lot of pitting. There's also a lot of white specks on the blade, even in the spots that look like rust. Any idea what the white is?
I usually use fine steel wool to clean up minor corrosion.
Hi Cletusvondamme,
I am following the thread. From an R&D perspective, we need to know.
Welcome to the forum and greetings up to Sweden (I am in Austria) :)
/ I´m a bit confused: In this pic the blade does not look "blacked out" and coated - ?!
cletusvandamme
sal wrote:
Fri Oct 16, 2020 9:46 pm
Hi Cletusvondamme,
Applied the flitz and this is the result
The spotting isnt as visible as before but the DLC has a slight sheen to it now. Guess i rubbed it too much
tonijedi
Post by tonijedi »
On my experience, with other brands coatings, when the rust develops there is permanent damage on the coating.
Post by JD Spydo »
I like your advice>> I would use the FLITZ first off and then I would also use BALLISTOL to give it a good bath with. I've had so many good results with BaLLISTOL over the years.
And if it's really stubborn you might take a soft bristle toothbrush will some "Bar Keeper's Friend" cleanser that you can get at your local grocery or hardware store. Out of those three products you should be able to remedy the problem.
