vivi wrote: ↑Wed Oct 07, 2020 10:34 amInteresting post, thanks for sharing! Most of those I've never tried.
I might as well post a video with the ones I've tried.
https://streamable.com/bfd2pw
I always use the first method, and have since I bought a Pkal back around 2008, which was the first CBBL knife Spyderco made.
Previously I had to use the two finger pinch I show in method #3 on non caged ball lock knives like the Dodo and D'allara.
Method #2 is just for fun. Sometimes it bounces back open a bit so I don't find it as reliable as #1.
Added to my post above: YOUR first method actually is one I never used in that exact same way... but it works great right from the first try on.
Thanks for the vid!vivi wrote: ↑Wed Oct 07, 2020 10:34 amInteresting post, thanks for sharing! Most of those I've never tried.
I'm the same with backlocks, I've never seriously used that method either. The only reason I even tried it was seeing it done here.Wartstein wrote: ↑Wed Oct 07, 2020 11:09 amThanks for the vid!vivi wrote: ↑Wed Oct 07, 2020 10:34 amInteresting post, thanks for sharing! Most of those I've never tried.
It´s funny with what a plethora of closing methods people come up with if they just try for themselves..(and don´t limit themselves right from the start to what they saw others do)
At least in my case I "discovered" all the methods I show in my vids BEFORE I even knew how other people close their CBBLs (and that seemingly many think there would be basically only one method with a CBBL).
I was even more oldschool some years ago than nowadays, did never watch any knife vids and literally knew (and still know) absolutely NO knife people in my "real life" and so over time just figured out myself how to operate locks just while using and carrying the knives.
The above is even more so true with backlocks, which I am a lot more familiar with than with the CBBL.
Funny thing also: I almost never use the "common" drop-the-choil-on-the-finger"-method with BACKLOCKS, but very often with CBBLs...![]()
Oh yes, definitely. I mean that the blade drops shut freely when the lock is fully disengaged.Wartstein wrote: ↑Wed Oct 07, 2020 7:45 am
You mean "free swinging" when the blade is partly closed and the lock is released, right?
Cause for me one of the good things of the CBBL is exactly, that when the blade is partly closed, but then you put the fingers away from the lock (so it engages partly again), the blade stays in place where it is and does not get "floppy"
Compare the Manix XL in my hands to a Delica or Para 2 in JuPaul's and its pretty obvious why the models we each like work well for us. I've said it before but I'm jealous of people with smaller hands that work for a wider range of Spyderco models. The XL looks a little small in my hands evenWartstein wrote: ↑Wed Oct 07, 2020 11:09 amAdded to my post above: YOUR first method actually is one I never used in that exact same way... but it works great right from the first try on.![]()
/ PS: And your vid showing the Manix XL in your hands makes clear why you call the regular Manix 2 "Mini Manix"![]()
Ha Ha ... thought I heard someone order up fingers for Halloween props???
I'm a #6 guy too. Only way that makes sense to me.
Users browsing this forum: Bing [Bot], Brock O Lee, Salty Dog, Sumdumguy, ThomC and 44 guests
