Rock Jumper comparison thread + general info
PStone
Re: Rock Jumper comparison thread + general info
Postby PStone » Wed Sep 30, 2020 11:34 am
grubetown wrote:
Wed Sep 30, 2020 7:51 am
I am left handed and switched the clip over for left side carry. My artistic sense is urging me to switch the scale and pivot screws so that the show side has the buttons instead of the screw heads. Any reason I shouldn't do this? My plan would be to do one at a time so I don't run into any reassembly issues. TIA.
You might have an issue with the lockbar screw/post. Once that is removed, the lockbar will come out. Getting it all back in can be tricky. So up to you if you want to start with that one, or save it for last. Skip to 21:30 to see how to reinstall that lockbar easily.
https://m.youtube.com/watch?v=MERI8A17jjM
grubetown
Postby grubetown » Wed Sep 30, 2020 11:46 am
Thank you!
grubetown
Postby grubetown » Wed Sep 30, 2020 11:47 am
Postby Wartstein » Wed Sep 30, 2020 12:20 pm
Concerning the only tiny critizism I could possibly have on the RockJumper after reading Davids posts (mentioned already by him and me):
There would fit more blade and by that cutting edge in the handle: Now, quoting directly from the newest Spyderco byte (September 2020):
"One of the primary design goals of the RockJumper was to pack as much cutting edge as possible into its pocket-friendly size, " https://mailchi.mp/spyderco/spyderco-by ... 25e010da72
Given that: Why not make the blade as long as possible, especially as it exceeds the in some places legal length of 3" anyway already?!
Again, just a very minor con in a generally great design and not a deal breaker of course.
Top three going by pocket-time (update July 21):
- EDC: Stretch 1 in VG10, Tenacious LW in S35VN, Endela SE in VG10.
- Mountains/outdoors: Pac.Salt 1 SE in H1, Endura in VG10 (Micarta scales), Salt 2 SE in LC200N
grubetown
Postby grubetown » Wed Sep 30, 2020 12:53 pm
I'm not a knife designer and maybe this is way off, but could the yet to be revealed leaf shape blade having anything to do with the design and therefore length of this blade?
JRinFL
Postby JRinFL » Wed Sep 30, 2020 2:13 pm
JRinFL wrote:
Tue Sep 29, 2020 7:58 am
The upcoming leaf shaped blade option will likely fill that space in the handle that looks like wasted space currently.
Repeating myself... :o
Not every choiless knife needs a choil, not every knife with a choil needs it removed. Not every big knife needs a Lil' companion. Wharnie for the whin! Friends call me Jim. As do my foes. Used to be JR in CT with a much earlier join date.
Postby Wartstein » Wed Sep 30, 2020 2:20 pm
I hear you! But still the wharnie blade could be made totally handlefilling already too, right? (And not only (and potentially) the leaf blade)
Anyway, not a big deal! :)
Just something not 100% consistent with the dedicated design goal "to pack as much cutting edge as possible into the handle". Still a perfect design for me.
JRinFL
Postby JRinFL » Wed Sep 30, 2020 2:24 pm
Ah, I see what you saying now, Sorry. I'm sure Sal his reasons, but I do not know what they are. Maybe once I have it in hand it will be obvious?
Postby Wartstein » Wed Sep 30, 2020 2:27 pm
Yep,let's wait till we both have one in hand! Hopefully soon! :)
StuntZombie
Postby StuntZombie » Wed Sep 30, 2020 2:31 pm
I guess I couldn't care less about the .3" of blade that it would take fully fill out the handle. Seeing this one in the wild, I have to admit that my interest has been piqued again.
The one dimension I'm curious about, and one I haven't seen mentioned yet, is how wide is this thing when it's closed? Are we talking Manix or Delica width?
Chris
Haves: Lava, Delica 4 Sante Fe Stoneworks, Spy-DK, Wharncliffe Delica, Squeak w/micarta scales, Wharncliffe Dragonfly, LC200N Pacific Salt 2, Rockjumper, Wharncliffe Manbug, Astute
JRinFL
Postby JRinFL » Wed Sep 30, 2020 2:40 pm
Good question. Looks like it will be close to the Manix in that dimension. Maybe @EvilD can take a picture of both closed?
Postby Evil D » Wed Sep 30, 2020 3:40 pm
I didn't measure but holding it up next to my Stretch it's the exact same width. I'd say since the blade stock is 0.5mm thicker than a Delica it'll come in at 0.5mm thicker than a Delica. The scales and liners don't look any thicker to me.
grubetown
Postby grubetown » Wed Sep 30, 2020 3:56 pm
I think he probably is looking for the height when closed from the spine of the blade to the back of the scale.
Postby Wartstein » Wed Sep 30, 2020 3:56 pm
I think what he meant was the height of the closed knives.
Postby Evil D » Wed Sep 30, 2020 4:15 pm
Yeah I completely missed the "while closed" part. The RJ is no doubt wider, it's pretty much exactly as wide as a Caribbean at the top of the thumb ramp/widest point.
StuntZombie
Postby StuntZombie » Wed Sep 30, 2020 9:27 pm
Got it. I kind of figured as much just going by the pics. I might have to wait until I get the chance to handle one. I like the design, but I'm not a big fan of the models that are pocket hogs.
Chris
JRinFL
Postby JRinFL » Thu Oct 01, 2020 8:06 am
Thank you.
grubetown
Postby grubetown » Thu Oct 01, 2020 8:36 am
Thank you.
I can't figure out how to get a good picture so I will try my best to compare PM2/RJ closed. They are very similar.
  • RJ is 10mm shorter lengthwise when closed
    The spines of the blades when closed line up almost exactly at the Spyderhole. However, the RJ has the hump vs the PM2 straight spine.
    On the RJ scales the two ramps on either stick out more aggressively. These aren't noticeable in the pocket
I would say in between PM2 and Manix on the pocket hog scale.
JRinFL
Postby JRinFL » Thu Oct 01, 2020 8:46 am
Thank you.
More good info, thanks. I also like the PHS, pocket hog scale!
soulspy
Postby soulspy » Thu Oct 01, 2020 9:42 am
I've carried mine for a few days so I'll add:
I'm unconcerned if they could fit more blade in the handle. I find that on some knives, clothing or anything else can snag the tip of a blade that isn't recessed deeply enough into the handle. Being an adventurers knife, you would not want to be snagging anything on a closed knife.
It's not as pocket-hoggy as it looks. Since the blade spine tracks the pocket seam and the handle is smooth where your hands makes contact in the pocket, it doesn't feel large.
I know the backlock is something Sal is playing with as a design element. I've tried to read and understand all of the concerns the Sal has and how he's addressing them. It is really tedious that so much is going on around the pivot/ricasso that effects the overall blade length. As a note, I also have the Siren. I can use the RJ without hitting the lockbar. On the Siren, every time I grip it, I depress the lockbar slightly enough to feel the blade rattle. The Seki backlock is not as nice (allows a little bit of up/down movement when locked) as the Golden made Siren. Still not my favorite lock style, but I'm giving backlocks a chance again.
Serrations are amazing. My first Spydercos were rescue blades in the 90's. The difference between serrations and a straight edge on something like a zip-tie is night and day. Serrations need almost no pressure, they just grab and pop.
Overall ergos feel great. There is a lot of cutting force concentrated on the tip. It feels light, slightly handle heavy, but also really solid.
So far, it feels like a really solid first iteration. I would not be surprised to see some slight CQI's in a future version, but I think the overall feel and utility is going to be appreciated by most users.
Users browsing this forum: bbturbodad, FK, Freediver, Google [Bot], JD Spydo, Kale, skeeg11, Tgmr05 and 20 guests
