Long Term Knife Storage Corrosion Protection
steelcity16
Postby steelcity16 » Thu Sep 17, 2020 6:15 pm
For those who have safe queens, are you using anything to help prevent corrosion while in storage? Especially on steels like M4 and 52100 which rust if you look at them wrong.
What would be the best oil/lube that won't dry out and get all gummy/gunky and is safe for scale materials like FRN, Micarta, FRCP, and G10? I assume most oils should be safe for the scale materials and safe for coatings like TiCN, PVD, and DLC, right?
Anyone have any experience with Eezox?
:bug-white-red CRU-CARTA THEM ALL! :bug-white-red
driftingfir
Re: Long Term Knife Storage Corrosion Protection
Postby driftingfir » Thu Sep 17, 2020 6:27 pm
Typically I'll use mineral oil. It does a fairly good job of protecting against corrosion. From what I've found it doesn't turn into a gel, and doesn't gunk up the pivot.
Postby Evil D » Thu Sep 17, 2020 6:28 pm
Most of my knives probably qualify as "long term storage" so I have a silica gel packet in all their boxes in hopes that it'll absorb any moisture that may find its way into the boxes. I also leave all my knives in their original bags when they come in them. I have a couple knives like my 52100 Military that are more prone to rust, I'll wipe them down with a very thin coating of Vaseline before putting them away. I haven't found any rust yet and most of my knives go several years without being touched. One important thing to note is, if you've handled a knife you should probably thoroughly wipe down the blade and remove any fingerprints/oils/etc from the blade before storing them (or before coating them/storing them).
JRinFL
Postby JRinFL » Thu Sep 17, 2020 6:42 pm
You may want to check out Zerust VCI products. They have broad range of corrosion inhibitors and can easily be found at Amazon or other retailers.
"...it costs nothing to be polite." - Winston Churchill Not every choiless knife needs a choil, not every knife with a choil needs it removed. Not every big knife needs a Lil' companion. Friends call me Jim. As do my foes. Used to be JR in CT with a much earlier join date.
Abyss_Fish
Postby Abyss_Fish » Thu Sep 17, 2020 6:51 pm
Combination of edc-i and silica packets. I had a maxamet native stored that way for months without corrosion. Just in a knife roll too.
Patiently waiting for… MagnaCut?
Or you know. Smallfly and Watu sprints. Whatever comes first.
Current spydie collection: Watu, Rhino, UKPK Salt PE, UKPK HH red g10 sprint s30v, Manix lw “mystic” sprint 20cv, SmallFly 2, Waterway, Ladybug k390, Caribbean
Current favorite steels: sg2/R2, lc200n/Z-FiNit, 3v, s90v, 20cv/m390/204p, cts-xhp
Cambertree
Postby Cambertree » Thu Sep 17, 2020 7:47 pm
Collectors of carbon steel knives that will be stored for long periods without being used, generally use a thin coat of Renaissance Wax, after making sure the blade is cleaned properly.
It was formulated for the British Museum in London, and I understand it is what they generally use on metal, leather and wood items.
Bloke
Postby Bloke » Thu Sep 17, 2020 8:02 pm
Eezox is your friend! ;)
I’ve used it for well over a decade on guns, knives, reloading press, tools, chrome wheels …
It’s not much of a lubricant but I doubt you’ll find a better rust inhibitor.
SubMicron
Postby SubMicron » Thu Sep 17, 2020 9:26 pm
I use Rem Oil if it doesn't need to be food safe or mineral oil if it does. In all scenarios I'll apply a couple of drops of Nano Oil or KPL into the pivot.
Sometimes I'll use EDCi but but now prefer products that dont need to be rubbed in... with oils I can just wipe it on and then wipe it off, it's easier.
I'm always looking for better options.
This looks interesting:
Sumdumguy
Postby Sumdumguy » Thu Sep 17, 2020 10:37 pm
I can't speak for it on knives. But, I use Eezox on all of my guns.
It's the best.
For knives, I keep it simple with mineral oil.
-Thomas Jefferson
Bloke
Postby Bloke » Fri Sep 18, 2020 3:31 am
It's the best.
Fellas, I use it solely for rust prevention. For example when my Rex45 Military arrived before using it I pulled it apart and gave the blade a good wet coat of Eezox and hung the blade in the sun to “dry” for a bit, I wiped it down then did the same again and reassembled the knife with a ultra light smear of grease in pivot and on washers.
After that I just use the knife. What Eezox is forward of the pivot (on the blade) wipes off but leaves what blade I can’t see coated and protected.
Vivi, if you’re reading this you should give Eezox a go on your liners at least ... going on pictures you’ve posted in the past. :)
Granoo Fink
Postby Granoo Fink » Fri Sep 18, 2020 5:04 am
Japanese Camellia oil for the blade and a small drop of Caramba for the pivot.
Storage in zipper bags with silica.
nerdlock
Postby nerdlock » Fri Sep 18, 2020 8:32 am
Clean with WD40 and wipe down with mineral oil, then store. If I want minty fresh blades, I'd use Froglube. Mineral oil's way, way more cheaper though and works well in our tropical humid climate for storage. I'd love to try EDCi but getting one is a hit and miss these days.
VG10:S30V:S45VN:SPY27:LC200N:XHP:204P:M390:20CV:Cru-Wear:Z-Wear:M4:Rex-45:K390:S90V:Z-Max:Maxamet
Albatross
Postby Albatross » Fri Sep 18, 2020 9:27 am
Silica packs and a wax-based product are probably the best options, but I've had good luck with long-term storage of my woods blades, using tuff glide.
sal wrote:
Fri Nov 09, 2018 3:01 pm
...But in general, I'm all about high performance, Ergos, safety. That's why I've been accused of "deigning in the dark"...
samdasnake
Postby samdasnake » Fri Sep 18, 2020 3:27 pm
I used to live right by the Pacific ocean - it killed my motorcycle engine FYI, but to keep my knife collection rust free I purchased a water-tight storage case and put a container of dessicated epsom salt in it (basically put epsom salt in the oven till it turns into a dry powder. Much cheaper than damp rid). I then coated each of my knives in tuffglide and the ones I was particularly worried about I wrapped in mineral oil soaked cloth. Then put them all in my dry box. A little overboard maybe but it worked in a room where there was ocean spray coming in the window sometimes.
Users browsing this forum: ATS-55, kurt_r, Majestic-12 [Bot], Matus, Mdrgn79, Metz77, Mushroom, p_atrick, Peacedivision, tangent, tonijedi, troutinCO, VipeX and 31 guests
