HRC Database
Abyss_Fish
Re: HRC Database
#161
Post by Abyss_Fish »
would love to see someone poke a SpyOpera, I've heard horror stories about Lionsteel's heat treatment...
Lightly insane.
ZrowsN1s
Re: HRC Database
#162
Post by ZrowsN1s »
Steeltoez83 wrote:
Sat Aug 08, 2020 6:41 am
Here are the results of 48 knives I had tested for Rockwell hardness. Some were poked once, some 3x but I'm listing the overall average in order of softest to the hardest. In my pocket there is a rex45 pm2 that tested 66 from previous owner. So 49 in total.
Who did the testing out of curiosity?
Steeltoez83
Re: HRC Database
#163
Post by Steeltoez83 »
ZrowsN1s wrote:
Sun Aug 09, 2020 2:12 am
Kurt did the testing.
Steeltoez83
Re: HRC Database
#164
One of my test videos on kurts channel. Sorry I'm not tech savvy on how to link videos.
racerx454
Re: HRC Database
#165
Post by racerx454 »
For what it is worth, SteveMidwest reported 64.2 HRC for his K2 10V.
viewtopic.php?t=86268
EngDevGr3
Re: HRC Database
#166
Post by EngDevGr3 »
I just got a Delica k390. The results were a bit surprising. It was poked twice, with the results of 66.4 and 66.5 HRC
JuPaul
Re: HRC Database
#167
Post by JuPaul »
EngDevGr3 wrote:
Tue Sep 01, 2020 6:06 pm
Wow! That's significantly harder than other k390 Spyderco has put out. I'm curious to see how people like it.
- Julia
dan31
Re: HRC Database
#168
Post by dan31 »
66 HRC, that’s tempting. I thought I was done.
Karl_H
Re: HRC Database
#169
Post by Karl_H »
I am also curious. If these results are accurate, it makes me wonder about the heat treatment and toughness. I believe the previous K390 results were about 65 HRC, which is more in-line with Bohler data sheet.
EngDevGr3
Re: HRC Database
#170
Post by EngDevGr3 »
I will definitely be using and testing it this week. I may have one of the other guys re check it to make sure.I have had 2 different police 4s and one was right at 66 and the other 64.2. Most of the Police 4s were right in the 65 range from what I have seen. The PM2 I had in k390 was 63 something, which seems to be standard for that batch.
EngDevGr3
Re: HRC Database
#171
Post by EngDevGr3 »
The Manix 2 Xl dlc in M4 was tested as well. 2 hits both at 63.3.
Re: HRC Database
#172
dan31 wrote:
Tue Sep 01, 2020 8:17 pm
...I thought I was done.
Ha! I've said that a few times before
The Meat man
Re: HRC Database
#173
Post by The Meat man »
The Meat man wrote:
Sat Jan 11, 2020 9:03 pm
Don't know how I forgot Larrin's excellent article on H-1. In the article he had a Spyderco Salt measured and found it to vary from about 55-57 HRC. Might want to add that to the list.
Bump. I think this is important information.
From Larrin's website:
I was sent an analysis of H1 in a Spyderco Salt by Sandvik. They did not find an increase in hardness at the edge, in fact they found a decrease. The plot below is what I was sent, where the value at about 55 Rc was 0.4 mm (0.16″) from the edge. Unfortunately I was not provided an x-asis to see the distances between the measurements. However, the ~57 Rc of the steel is comparable to the value reported above from Crucible.
https://knifesteelnerds.com/2019/06/24/ ... -it-works/
- Connor
Naperville
Re: HRC Database
#174
Post by Naperville »
This is an excellent effort, but I do not think that it is up to date. Is the current up to date spreadsheet?
Accutron
Re: HRC Database
#175
Post by Accutron »
Naperville wrote:
Wed Sep 16, 2020 7:40 pm
That's the 'official' spreadsheet for the group centered around the HRC testing efforts of Kurt (jcoolG19). The table is periodically updated, but the spreadsheet lags behind the testing by some number of months. I'm not sure, but I think LTK may maintain the spreadsheet.
AlexRus
Re: HRC Database
#176
Post by AlexRus »
EngDevGr3 wrote:
Tue Sep 01, 2020 9:58 pm
Not bad)
EngDevGr3
Re: HRC Database
#177
Post by EngDevGr3 »
The DLT Delica OD green DLC cruwear tested at 62.1 HRC.
Cambertree
Re: HRC Database
#178
Post by Cambertree »
EngDevGr3 wrote:
Tue Sep 29, 2020 10:21 pm
Good stuff. :cool:
Are you getting any readings for the rest of the current K390 Seki series, besides the Delica?
EngDevGr3
Re: HRC Database
#179
Post by EngDevGr3 »
Cambertree wrote:
Wed Sep 30, 2020 12:06 am
Good stuff. :cool:
I plan on getting the k390 endura when it is released. I may get the k390 endela as well. I am going to test everything I get now, so I will keep posting them as I get them.
Cambertree
Re: HRC Database
#180
EngDevGr3 wrote:
Wed Sep 30, 2020 10:41 am
Good stuff. :cool:
Great, thanks for your contributions. :)
It would be interesting to eventually have data points for the whole array of different sized blades in a Seki release in a single steel grade. I wonder if there is much difference between the smaller blades like the Manbug and Dragonfly, compared to, say, the Endura, Stretch and Police?
