Spyderco CQI Military washers size
Hi guys,
Anyone know the exact specs/size for the original phosphor bronze washers on the CQI Spyderco Military? The one produced since 2017 and after
Re: Spyderco CQI Military washers size
It didn't occur to me that they even changed? Is the diameter of the pivot different or did they just switch to a double screw bushing?
To be honest I don't know whether the are changed or not, but I'm almost sure the are. I don't have the older pre-CQI Millies to compare in person. I just want to get replacement washers for the current CQI Military S110V, but got no calipers to precisely measure the specs...
Maybe someone knows?
Hey Alex, I'll measure mine tonight and let you know.AlexRus wrote: βThu Sep 17, 2020 10:35 amTo be honest I don't know whether the are changed or not, but I'm almost sure the are. I don't have the older pre-CQI Millies to compare in person. I just want to get replacement washers for the current CQI Military S110V, but got no calipers to precisely measure the specs...
- Connor
Thank you!The Meat man wrote: βThu Sep 17, 2020 10:39 amHey Alex, I'll measure mine tonight and let you know.AlexRus wrote: βThu Sep 17, 2020 10:35 amTo be honest I don't know whether the are changed or not, but I'm almost sure the are. I don't have the older pre-CQI Millies to compare in person. I just want to get replacement washers for the current CQI Military S110V, but got no calipers to precisely measure the specs...
By the way, if you have the precise calipers, could you please along with the CQI Military washers , also measure the CQI Military standoffs? I saw many titanium standoffs in the online stores and on Ebay, but don't know which ones would precisely fit the CQI Military :)
Yeah I have ISO certified calipers. They're accurate to within 0.0005".AlexRus wrote: βThu Sep 17, 2020 10:42 amThank you!The Meat man wrote: βThu Sep 17, 2020 10:39 amHey Alex, I'll measure mine tonight and let you know.AlexRus wrote: βThu Sep 17, 2020 10:35 amTo be honest I don't know whether the are changed or not, but I'm almost sure the are. I don't have the older pre-CQI Millies to compare in person. I just want to get replacement washers for the current CQI Military S110V, but got no calipers to precisely measure the specs...
I will see what I can do.
- Connor
Cool! Thanks again, man!The Meat man wrote: βThu Sep 17, 2020 11:07 amYeah I have ISO certified calipers. They're accurate to within 0.0005".AlexRus wrote: βThu Sep 17, 2020 10:42 amThank you!The Meat man wrote: βThu Sep 17, 2020 10:39 amHey Alex, I'll measure mine tonight and let you know.AlexRus wrote: βThu Sep 17, 2020 10:35 am
Okay Alex
Phosphor bronze pivot washers:
Thickness: 0.26mm or 0.010"
OD: 12.72mm or 0.500"
ID: 5.84mm or 0.230"
Standoff:
Diameter: 5.07mm or 0.200"
Length: 4.23mm or 0.166"
Hope this helps. Let me know if you need any more measurements, while I have the knife disassembled.
Standoff:
- Connor
Thank you!The Meat man wrote: βThu Sep 17, 2020 4:23 pmOkay Alex
Standoff:
