K390 IS "The M4 Killer"
jpm2
Re: K390 IS "The M4 Killer"
Postby jpm2 » Sun Sep 06, 2020 5:53 pm
GarageBoy wrote:
Sun Sep 06, 2020 1:10 pm
I'm tempted by something tool steel as a work knife...
Good choice...
All my work knives for the last 35 years are high speed tool steel blades.
The k390 delica I just got might break the trend.
Postby Doc Dan » Tue Sep 08, 2020 8:57 am
I think K390 is a Maxamet killer. It is for me.
blues
Postby blues » Tue Sep 08, 2020 9:10 am
"Alas, poor Maxamet..."
- No FOMO -
5-by-5
Postby 5-by-5 » Tue Sep 08, 2020 1:32 pm
I have zero interest in K390. I might find more interest in other Seki models.
The Meat man
Postby The Meat man » Tue Sep 08, 2020 4:16 pm
You like CPM M4 don't you? What's not to like about K390?
- Connor
5-by-5
Postby 5-by-5 » Tue Sep 08, 2020 5:26 pm
Nothing really. I don't have any and am not excited to get K390. Im not compelled to get 52100 either. Something interesting will need to get one of these in my collection.
Albatross
Postby Albatross » Tue Sep 08, 2020 5:48 pm
I don’t have any Maxamet to reference, but from the testing I've seen, I don’t feel like I'm missing enough to worry about not having any. I do know that K390 doesn't seem to be giving people as much trouble as Maxamet has/does. I've also seen edge retention testing that puts K390 not far behind Maxamet. The added toughness and more forgiving nature of K390, makes it hard to beat.
sal wrote:
Fri Nov 09, 2018 3:01 pm
...But in general, I'm all about high performance, Ergos, safety. That's why I've been accused of "deigning in the dark"...
5-by-5
Postby 5-by-5 » Tue Sep 08, 2020 6:16 pm
It took me a while to get a Maxamet too. The right price landed me a Manix LW.
I've had no problems, and I really like the performance. I don't know if I'll get more though.
Postby Doc Dan » Tue Sep 08, 2020 11:19 pm
Do a comparison between the two and K390 has more of the right things in the mix.
Postby mikey177 » Wed Sep 09, 2020 2:11 am
How about K390 versus Cru-wear? The DLT exclusive Cru-wear Delica interests me somewhat, but being the same price as the K390 Delica, I'm wondering which would be the more advantageous choice for a general EDC folder.
From my understanding, K390 will have better edge retention, while Cru-wear will be tougher in terms of impact resistance (which might not really be important in a small folder).
attila
Postby attila » Wed Sep 09, 2020 3:23 am
Cru-wear is also far more corrosion resistant than K390, Maxamet, M4, and Rex 45. I do not oil Cru-wear and have no fear of cutting meats, acidic fruits, etc. with it, since Cru-wear has yet to patina in my use. K390, Maxamet, M4, and Rex 45 will patina relatively easily in the use I describe above.
Own: Delica, yOld S30V Native, pointy Breeden Rescue, Delica, HAP40 Endura, ZDP DF2, S110V Manix LW,Pakka Delica, Cru-wear Para 3, SE H1 DF2, M4 Manix, HAP40 Caly 3, S90V Native 5, K390 Urban, Pakka DF2, Cruwear PM2, SE Pac Salt, HAP40 Jazzlica, S110V Native, P.I.T.S., DLC Manix, REX 45 PM2, Para 3, XHP Manix LW, SB Caly 3, 20CV PM2, Rhino, SB Calypso Jr., B70P, PMA11, K03, ZDP Stretch 2, Kapara, REX 45 Military, 154CM Manix LW, 204p PM2, Swick, SG Delica, BL Lil'Native, AEB-L Urban, HAP40 Stretch, KC Cruwear Manix,Cruwear Military, M390 PM2, Cruwear Delica, 4V Lil'Native, Mantra 2, CruCarta Shaman, M390 Para 3 LW, M390 Manix, K390 Police 4, RexWood Shaman, DLC Cruwear Shaman, Rex 45 Manix, Native 5, Native LW, 204p Para 3, S45VN PM2, S90V Manix LW, 20CV Manix, Rex 45 Lil’Native, Shaman, C208GP Cruwear Manix
Waiting for: SPY27, K490, Swick 5, and something purple
Albatross
Postby Albatross » Wed Sep 09, 2020 5:06 am
K390 has better edge retention, as well as better edge stability, which means the edge won't deform as easily as Cruwear, but it's not as tough and not as stain resistant (as mentioned above). K390 is also more time consuming to sharpen.
Postby mikey177 » Wed Sep 09, 2020 7:45 am
Thank you for those insights. I think I'll try out the K390 Delica, as I already have a Mule in PD1, which is similar to Cru-wear. I don't mind the formation of a patina, and I'll take steps to guard against corrosion.
Postby Doc Dan » Wed Sep 09, 2020 9:06 am
You will love K390.
Woodpuppy
Postby Woodpuppy » Thu Sep 10, 2020 12:44 pm
I am quite happy with cruwear. It is so easy to get great results sharpening with ceramics. I have the ladybug in K390 and reprofiling to 15dps was a real chore. The steel seems to perform well, but it’s the most work I ever want to put into sharpening. I do not want to get into new sharpening gear...
:spyder: My other blade is a Kelly Perfect :spyder:
GarageBoy
Postby GarageBoy » Thu Sep 10, 2020 7:16 pm
Does k390 do that sticky sharp edge that m4 is renown for? (Guessing due to its high carbide percentage)
JohnDoe99
Postby JohnDoe99 » Thu Sep 10, 2020 7:48 pm
Carbide content and type has long since been well known as the overriding factor in edge behavior. What "Bigbear" does is demonstrate that both steel types being ultra high carbide are inherently brittle and one particular M4 knife happened to chip a lot (as it of course would), regardless that the sharpness in both blades was totally compromised, all the while admitting that there is a radical difference in tempering between the two but then focusing solely on the rockwell rating.
JohnDoe99
Postby JohnDoe99 » Thu Sep 10, 2020 7:51 pm
If by "sticky sharp" you mean keenness, then a higher carbide percentage can only negatively affect the keenness of a blade as the carbide "clogs up" the edge because of the radical difference between the carbide and the surrounding alloy. K390 would not have an inherently sharper or keener edge than M4 as both are extremely wear resistant, and beyond that the skill of the sharpener and the abrasive used would be at least as relevant.
Cambertree
Postby Cambertree » Thu Sep 10, 2020 9:31 pm
I agree Doc, I much prefer K390 to Maxamet too. :)
Postby Doc Dan » Thu Sep 10, 2020 10:04 pm
K390 is hands down my favourite non stainless steel
Users browsing this forum: Bing [Bot], Enactive, kobold, Larrin, Majestic-12 [Bot], Mushroom, nerdlock, Sonorum, Tgmr05, tyd450, Wartstein and 53 guests
