Buying my first PM2: S30V or S110V?
plshelpme
Postby plshelpme » Sat Aug 08, 2020 12:11 pm
Hi all! Was playing with my buddies PM2 the other day and I really liked it a lot. I’ve owned a smock and a Manix 2 and thought those were pretty nice too, though I wasn’t super fond of the compression lock since my fingers got tired after fidgeting with it for a while.
Anyway, I want to buy a PM2. Should I get S30V or S110V? The price difference is about $25. I mostly just fidget with my knives and cut tape on packages so I’m not a hard user or anything. I’m ok at sharpening but not great. Mostly so freehand but would probably buy a guided system for pocket knives so I make sure not to screw up the finish. Thanks for your help!
JRinFL
Re: Buying my first PM2: S30V or S110V?
Postby JRinFL » Sat Aug 08, 2020 7:36 pm
Hello and welcome. I can’t really help with your question, but this old thread might help: https://forum.spyderco.com/viewtopic.p ... 0&start=20
Not every choiless knife needs a choil, not every knife with a choil needs it removed. Not every big knife needs a Lil' companion. Wharnie for the whin! Friends call me Jim. As do my foes. Used to be JR in CT with a much earlier join date.
BornIn1500
Postby BornIn1500 » Sat Aug 08, 2020 7:38 pm
seems like s30v would be better for you.
Spydergirl88
Postby Spydergirl88 » Sat Aug 08, 2020 7:50 pm
S30V
dvsdev
Postby dvsdev » Sat Aug 08, 2020 7:51 pm
Most of the Spyderco knives have standard S30V. Once you have enough S30V knives, you'll want something "nicer". If it's only $25, I would go with the S110V.
araneae
Postby araneae » Sat Aug 08, 2020 7:58 pm
If you're only cutting tape S30V is more than sufficient and probably overkill.
-Nick
Just got: Zcarta Shaman
Dazen
Postby Dazen » Sat Aug 08, 2020 9:05 pm
I would seriously consider the M390 and K390 options still available at Bento Box Shop.
anycal
Postby anycal » Sat Aug 08, 2020 9:54 pm
It is not always about what you need. Sometimes you may want to impress :p
Not sure which model your buddy has, but the ranger green K390 from Bento Box Shop is a looker; never mind the steel.
Hope you like the one you get. And keep practicing your freehand sharpening!
Peter
Postby Sharp Guy » Sat Aug 08, 2020 9:57 pm
Of the two choices you specified I recommend going with S30V
SubMicron
Postby SubMicron » Sat Aug 08, 2020 10:15 pm
K390 from Bento Box is also my recommendation unless you're convinced that you need stainless. If you live near saltwater, you might need stainless unless you're diligent with maintaining and lubricating your knife.
While the intended usage is light, who knows what the future holds. Its comfortable in the pocket and a PM2 is a powerful working tool if you need it to be.
If stainless is necessary, M390 balances properties better, otherwise K390 is simply superior by a lot. Its even better than S110V for edge retention.
plshelpme
Postby plshelpme » Sat Aug 08, 2020 10:22 pm
I do have some M390 knives and love those. I only have S30V and S110V at the place near me so the other ones are out of the picture. Also I dont want to spend a ton of money. I'm sort of inclined to go towards the S110V since I don't particularly enjoy sharpening and kinda like the blurple handle. But in all honesty I'll probably get an aftermarket handle at some point haha. I dunno.
Basically S110V holds and edge longer than S30V but is more prone to chipping, right? I really appreciate everyone's help!
Ankerson
Postby Ankerson » Sat Aug 08, 2020 10:59 pm
Actually it's not better than S110V given the same hardness range, blade thickness, thickness behind the edge, edge finish etc.
Based on actual testing of more than a few different knives over the years, both production and custom.
They are fairly close in reality.
CPM 10V now that is a different story... There is a difference there... I think CPM 10V is one of the best steels available for knife blades. The properties of the steel are really THAT good..
Still waiting for that CPM 10V Military..... ;)
Would be the only steel in a Military that would displace my current S110V Military.
To answer the original question there is nothing wrong with S30V, it's a good choice to start with.
GarageBoy
Postby GarageBoy » Sat Aug 08, 2020 11:58 pm
I thought k390 and cpm 10v were very similar/interchangeable?
Guess I'll have to wait for more 10v... The K2 was a steal at blow out prices ($150!), but way too big for me
Ankerson
Postby Ankerson » Sun Aug 09, 2020 12:00 am
They really aren't from what I have seen over the years. I doubt one would see any real difference in real world use however. S110V, CPM 10V and K390 will all be very similar in real world use.
In testing the differences become apparent really, I can't unsee those differences once I knew they are there.
Just keeping things real here.
If you own a knife in one of the 3, you are fine.
They are interchangeable for industrial uses however as far as I know, but that is a whole different world.
I have a very special place in my heart for CPM 10V to be completely open and transparent about it.
rabbitanarchy14
Postby rabbitanarchy14 » Sun Aug 09, 2020 12:27 am
i would agree with that seeing as how i love m390. it takes slighty longer to sharpen than s30v but holds an edge longer and just as stainless. i do like k390 as well but it is a tool steel and has to be maintained, another is rex 45.
192.168.0.1 -Para 3 G10 M390 Red, Dice XHP,, Lil Native Rex 45 comp, Manix 2 M390 G10 BR, PM 2 M390 DLC BL, Cat BD1N, Dragonfly 2 k390
Saving for - D'allara 3, Brower
Instrument- Kimber EVO, SA Hellcat, SW Shield .45
Postby Wartstein » Sun Aug 09, 2020 1:37 am
Welcome! :)
I personally would got with S30V. I really like that steel and would not need anything with even more edge retention, but taking longer to sharpen in return (so I never even tried S110V myself). I´d say from a practical point of view, when I read how you use your knives, S30V is more than fine.
That being said: If you are like many on this forum and want to get deeper into and try different steels: You know S30V already from your Smock and presumably Manix (if it was the "base" model) and so S110V would be something new. Though I figure you´d probably not take your S110V blade to the sharpener a lot less often than an S30V blade, since I´d certainly recommend touching up the former rather frequently in order to never let get it dull. This touch ups should go quick though, at best just a few strokes to maintain a microbevel.
I am not an expert though, others here do know a ton more about sharpening than I do.
For quick touchups, regardless on which folder or steel, I´d recommend getting a sharpmaker anyway.
araneae
Postby araneae » Sun Aug 09, 2020 5:46 am
It's hilarious that you all are pushing super steels to someone who says they only cut tape and is just okay at sharpening. 420HC would suffice.
-Nick
Albatross
Postby Albatross » Sun Aug 09, 2020 6:01 am
S30V would serve you best. S110V can be difficult for less experienced sharpeners. I haven't heard it in a while, but people used to complain about not being able to get S110V sharp, or not sharp enough. It's got a tricky burr, when compared to more simple steels, which gives some people a lot of trouble.
sal wrote:
Fri Nov 09, 2018 3:01 pm
...But in general, I'm all about high performance, Ergos, safety. That's why I've been accused of "deigning in the dark"...
prndltech
Postby prndltech » Sun Aug 09, 2020 6:35 am
I gotta go with em the OG steel on this one... S30v.
- Shannon
RustyIron
Postby RustyIron » Sun Aug 09, 2020 7:17 am
I'll have to go with the other's suggestions of K390 or M390.
But of the two you asked about, S110V is definitely the way to go. You said yourself that you're a fidgeter. You need to be entertained. An edge that can become super sharp and last a long longer is MUCH more entertaining. And figuring out how to put the keenest edge onto it will keep you busy for a while. But after that, you might find that maintaining the edge on the S110V is actually quite easy.
Users browsing this forum: AHarbuck, Bing [Bot], buckleys, Google [Bot], Granoo Fink, Henry_P, ladybug93, Leksy, PeaceInOurTime, przemekspce, RandomNick, rangefinder, SpydieFlicker, Supacede, Team Sick, Zive and 61 guests
