"Your IP has been blocked because it is blacklisted"??
Re: "Your IP has been blocked because it is blacklisted"??
Test
Seems I'm getting it nearly everyday now.
Talked to my ISP and they were no help. I guess they weren't seeing any unusual traffic on their end.
I don't really know what else to do at this point.
Chris
Just say NO to lined FRN
Chris,StuntZombie wrote: ↑Tue Aug 04, 2020 10:46 amTalked to my ISP and they were no help. I guess they weren't seeing any unusual traffic on their end.
Have you tried rebooting your modem? That usually triggers a new IP address. I'm sorry it's such a pain.
To give some context, between just two of the measures we have in place to battle spammers, nearly 2,000 spam attempts were blocked in just the past seven days.
Let me know if rebooting your modem works (or is an option). If not, message me your IP once more.
Kristi
Hey Kristi, I've tried rebooting and resetting a couple times now. Still no go.
Chris
Actually, disregard. Seems it's working again.StuntZombie wrote: ↑Tue Aug 04, 2020 5:30 pmHey Kristi, I've tried rebooting and resetting a couple times now. Still no go.
Chris
It's really odd that I didn't have an issue with this for a year and a half and now out of nowhere I get it pretty much everyday. Switching airplane mode on and off does shuffle the IP and gets it fixed but the next day I'm back to being blocked again.
Just got it again, only a couple hours later and this is the only site I've been to all day.
If you are using a VPN to increase your security and to help prevent your ISP from snooping, then you are more likely to see this block. It’s because some spammers use the same VPNs to do their spamming. The same applies to Tor.
If you are placing an order on our website, yes, this is very true. But the Forum is a little different. Our tools don't block VPNs, but rather IPs that have been blacklisted by trusted sources. Some VPNs are on blacklists, but a majority of the IPs that I've seen with this issue aren't VPN.
It's unfortunate that we have to go to such lengths to protect the forum, but for some additional perspective, our tools have blocked another 1,655 spammers since I posted above.
Kristi
test...first time to encounter this today. I browse the forums on 3 devices, my phone, my Macbook Pro at home, and my office PC right now - this one happened on my office PC. Second time I tried posting the same content to one of the threads here, it worked. Weird.
- Buddafucco
Yep... I also got the Blacklist message. On my phone. I cleared the cache but that didn't work. Then i did the airplane mode on then off. If you see this, it worked.
•• Beau
I had that issue several times in the past. Then not at all for several month.
But right now, right since people start to post about it here again, I do have it all the time. Very annoying. Contacted spamhouse (not for the first time), did everything they told me (ran a security / cleaning program and so on).
Did not make anything better.
Most times I can´t post from my laptop anymore (even if I change the VPN adress), and just somtetimes from my phone - even when doing the plane mode on/off thing.
Had a professional IT-guy whom I know check my laptop and cellphone. He could find and do nothing.
I have and never had any problems on the internet or with being blacklisted whatsoever and ever on any other site.
This is really weird and also annoying I have to say.
Kristy, I totally understand that this forum has to be protected and I am gratefull that you do so.
But sometimes I have a feeling that those spamhouse-guys, while certainly doing a great job in keeping spammers away, somehow do also have a too coarse grid.
It seems to be a bit like using an insect spray that totally reliably kills all the pests, but ALSO many of the creatures you DON`T want to kill.
Maybe you can talk to those guys?
I'm actually having the same issue again. I've run scans on everything possible, reset my router several times, all to no avail. It appears to be due to the IP address issued by my ISP, but they haven't seen any suspicious activity and it seems they won't issue a new IP address to me because of the plan we're under.
I can't even contact the folks at Spamhaus because they won't accept messages from unpaid email accounts.
Pretty much the only way I can post on here now is by using my phone as a hotspot. I'm guessing other forums don't use Spamhaus, because this is the only one I have issues on.
One question I had, is do you get to see where spam attacks are originating from?
Chris
Ran into the same problem on my phone. Had to turn my data on and off until I got assigned an IP that wasn't blocked
UUUUUUUUUUUUUUGGGGGHHHHH
Kicking my arse today
Same with me today and yesterday. Really annoying, especially since I don´t know what to do anymore.
IT guy can´t find nothing, did what the spamhouse people told me, still having the issue.
I wonder how many people perhaps experience the problem and just silently leave the forum eventually - ?!
Wartstein wrote: ↑Thu Sep 03, 2020 5:27 pmSame with me today and yesterday. Really annoying, especially since I don´t know what to do anymore.
Good question. Fortunately I have only had this issue on my phone, my PC at home I don't think has ever done this that I remember (at least not in a long time and not recently). On my phone I just turn on airplane mode for a few seconds and switch it back off and that usually does it. Sometimes I've had to do that a few times before the issue went away.
This does it.Evil D wrote: ↑Thu Sep 03, 2020 5:37 pmWartstein wrote: ↑Thu Sep 03, 2020 5:27 pmSame with me today and yesterday. Really annoying, especially since I don´t know what to do anymore.
Plus clear the cache and you're all set.
Since the pandemic started, there are a lot more hacking attempts, because a lot of people started working from home.
When you connect from either LTE/4G/3G or Wifi, you are assigned with a random IP address (DHCP does it).
If this address has been blacklisted because someone/bot used it for listed above, it will cut you off.
Just use plane mode on phone, or reset router from home on computer so the network assigns a new IP address
pantagana23 wrote: ↑Sat Sep 05, 2020 3:57 amEvil D wrote: ↑Thu Sep 03, 2020 5:37 pmWartstein wrote: ↑Thu Sep 03, 2020 5:27 pmSame with me today and yesterday. Really annoying, especially since I don´t know what to do anymore.
This does it.
Sadlly, I don't have that option with my home internet provider. Our plan only allows for a static IP. So I basically have to wait until my IP address is cleared, or use my phone as a hotspot. Which I just had to do to post this.
Unfortunately, neither my service provider nor Spamhaus has been of any help.
It's pretty much put me off from even coming here any more, because I'll never know if I'll be able to post anything.
Chris
StuntZombie wrote: ↑Thu Sep 10, 2020 8:26 pmpantagana23 wrote: ↑Sat Sep 05, 2020 3:57 amEvil D wrote: ↑Thu Sep 03, 2020 5:37 pmWartstein wrote: ↑Thu Sep 03, 2020 5:27 pm
This does it.
That´s bad! ... again, I am a bit afraid that per anyone who posts about that problem there could be ten others who experience the same, but don´t try to post but just leave. (I might be too pessimistic in that case, don´t know... )
