Sumdumguy wrote: ↑Sat Jul 18, 2020 11:41 amIt's called metal fatigue, Mike.MichaelScott wrote: ↑Tue Jul 14, 2020 1:07 pmWhat constitutes “time” is the rub. I doubt if a human could stress that spring (really a thick steel bar) enough in a lifetime to wear it out, or in.
Repetitive bending force on a piece of metal causes it to weaken over time, due to the development of micro cracks.
You would probably never be able to actually fatigue it enough, under normal use, for it to actually seperate. But it will, most certainly, become weaker and easier to flex over time.
It has nothing to do with the lockbar rubbing on the spring. That's a different kind of wear.
I just do know for sure that the backlock on my particular Chap got significantly easier to operate over the course of time (though I personally did not mind it having a rather hard to press lockbar in the beginning)
