Mini Chef chop
Mini Chef chop
Chopped her down yesterday - cutting edge is now 3", handle is 4.12". Also removed the finger guard for more grip area, added a clip from a Kizer mini Sheepdog.
Re: Mini Chef chop
Very cool!! As always... :)
Re: Mini Chef chop
Beautiful work! Your mods always look like they were just meant to be.
- Julia
Re: Mini Chef chop
This is just.....awesome. I really, really hope this gets Sal’s attention and would buy a “mini” Chef in a heartbeat. Very nice job as always!
- Cambertree
Re: Mini Chef chop
Outstanding! That looks great. :spyder: :cool:
Re: Mini Chef chop
It looks designed that way. Well done!
- Connor
Re: Mini Chef chop
Looks a lot like the MD/Reate Prism, aside from the glaring differences in the scales. The dimensions are even pretty much spot on.
Nice work!
Nice work!
Currently testing: M398, D3, SLD-Magic
Favorites: 10V, s90v
Wishlist: S290, Vancron, S125V, K890
18 Spydies, 15 steels
13 Maxace, 9 steels
13 Maxace, 9 steels
Re: Mini Chef chop
Lovely work! I like this way much than the Shaman chop, for some reason, it just looked a bit off ( but the work was outstanding).
I always want to ask, how do you chop the blade? Grinding it all off with belt sander is kinda time consuming. Saw is out of option on hardened steel. Angle grinder generates too much heat. How do you do it? If it is not a trade secret :D
Re: Mini Chef chop
Thanks for the kind words Spyderco familia!
I just use a dremel w/ the thin metal cut-off wheels. Douse the blade w/ water every couple seconds while cutting. Then shape w/ a belt grinder, also dousing constantly. Planning on upgrading to a bandsaw for the chopping though!
Re: Mini Chef chop
Random question, but what tap and die set do you use?
13 Maxace, 9 steels
13 Maxace, 9 steels
Re: Mini Chef chop
Very nicely done.
'The future is already here;it's just not evenly distributed'
William Gibson
William Gibson
Re: Mini Chef chop
Fantastic!
Re: Mini Chef chop
For clip redrilling/tapping I use a #50 bit and 2-56 tap, except for ti handles - works better to use a slightly bigger bit, like a #49 or 5/64". The ti gets all 'gummy' and binds/breaks taps like craze (for me at least) w/ the standard #50 hole. With the larger bit/hole, the threads are still deep enough that they hold well w/ too.
Thanks so much!
Thank you, I really appreciate it!
