Siren in the dish washer?
I've been using my siren quite a bit for food preparation. Recently I brought it along for a fishing outing with my son. Now feel like I need to sterilize it. Is it dishwasher safe? I just used soap and hot water and called it good, but just checking a novel idea. :eek: :D
- VooDooChild
Re: Siren in the dish washer?
Something about dishwashers ruining edges.
I wouldnt. Seems like there would be easier ways to clean and sterilize it.
I wouldn’t. The soap and hot water should be good enough.
- Surfingringo
I doubt anyone gets theirs grosser than mine. I wash with hot water and soap and that’s plenty. I’m only semi domesticated though so that may not be good enough for everybody. I figure if I miss a couple of germs that’s just good training for my immune system. In all seriousness I’ve never felt the need for a dishwasher or disassembly to get mine clean.
- bearfacedkiller
If I need to get a knife really clean I will clip it to the inside of a cargo pocket and run it through the washing machine with a full load of clothes. It comes out squeaky clean. :) Found this out by accident.
If you really feel the need to sterilize it, after washing it with soap and hot water you can wipe it down with rubbing alcohol but unless you’re splinter picking, it’s a little overboard.
The best reason I've come across on why NOT to use the dishwasher is that the dish machine soap contains a slight amount of abrasives. Imagine spraying your knife with a coarse slurry, a nice edge doesn't appreciate that.
I used to worked in a kitchen doing dishes and I can guarantee you that hit water and dish soap works well enough for any health inspection.
/ David
Signalman1
JohnAPA sir in the past when I wanted to clean anything very well I would use a can of "Break Clean" the spray will evaporate in a few seconds...I have used it on firearms for years. You can spot clean with the little tube that comes with the can, It will blow out anything stuck in your knife. BC will clean out all the lube in the pivot and I would wash it out with soap and water when done especially if your using your knife for food and then blow out any water left in your knife with one of the compressed gas cans people use for their computer keyboard or electronic parts...then lube it up. The old tooth brush and "Dawn" dish soap should do you good if you have stuff that been in there for months and just won't come out. Just a suggestion...but that is the way I would do it. :)
Signalman1 :mad: :) :D
How about cleaning the blade with rubbing alcohol?
- marshmallow
- steelcity16
Not saying you should but I sometimes run my Salt knives through my dishwasher with no I'll effects. And most of my knives have been through the washing machine a few times on accident with no noticable (to me at least) effects.
You could wash with soap and water then rinse. Fill a pan with an inch water and get it boiling. Place the knife in a vegetable strainer and place it in the pan above the water so just the steam hits the knife and cover for a minute or two. Or just dip in a solution of 1 Tbs of bleach to 1 quart of water and rinse. That would also destroy any DNA evidence. :eek:
Dry thoroughly and oil the pivot.
- araneae
I hand wash the utensils that I use for food prep and they are always clean when I finish. If you feel your hand washing is substandard enough that you don't think the knife is clean when you're done, I guess you could dishwasher it. I just haven't met the crud that couldn't be defeated with dish soap and a scrub brush. And I know how to get a knife dirty. Just seems like the dishwasher is a harsh place to send a nice knife.
-Nick
Last in: N5 Magnacut
-Nick
Soak it in very hot soapy water (not boiling) and then just scrub it down. If you're really concerned about germs you can always do a bleach/water soak too.
Thanks for all the responses Spyderheads!
