I'm falling out of love with the Compression Lock
At least sometimes. In my day to day use I love it and it's not like I do cutting jobs everyday like the one I just did, but when it really comes to doing hard/extended cutting jobs with any compression lock knife, it's always a recipe for hot spots...
That hot spot on the webbing between my thumb and index finger always forms after a bit of use. The only way I can get around that is by using more of a saber grip with my thumb on the thumb ramp, but sometimes I need a hammer grip. It isn't all the lock's fault, it also has a lot to do with open back/pillar construction, but there's always that spot where the lock cutout is where only half the handle is there to take the pressure of your cut. This is an area where back locks and CBBL's are vastly superior locks.
This is one reason I'm really interested to try out the Rock Jumper, because the back lock will solve this issue for me and if I can get the same performance and ergonomic results from a back lock knife then I'm all over it. I'll miss the drop shutty goodness but I would rather have to fold a blade closed against my thigh than have hot spots.
And before any of you jokers say "get tougher hands", I don't plan on creating a callous just to compensate for a lock design :rolleyes:
How about a back lock, no-choil Shaman that keeps the same rounded handle scales, in LC200N/SE? That would pretty much solve all of my knife issues and answer just about all of my knife wishes. A Shaman with a back lock/full back spacer and rounded handle scales is probably the closest we'll get to a folding fixed blade.
Re: I'm falling out of love with the Compression Lock
The compression lock is okay but I very much prefer the CBBL.
- Connor
I understand what you're describing and have experienced it with some models more than others, fortunately I don't experience it with the Shaman, which may be one of the reasons it's my overall favourite knife model... that said, it's at the bottom of my top 3 fave locks
#1 Bolt Lock
#2 CBBL
#3 Compression Lock
:D
#1 Bolt Lock
#2 CBBL
#3 Compression Lock
:D
- curlyhairedboy
I'd say 90% of my compression lock use is with the thumb on the back of the handle or blade. I can definitely see how the webbing of your hand can get irritated without that bracing.
Get well soon, hand! :)
I wonder if it's possible to make a fully enclosed compression lock with a full back spacer and use the button like the Smock uses? My only concern there would be getting crud inside the handle and potentially blocking the movement of the lock.
- curlyhairedboy
The Yojimbo has one of the smallest cutouts for the lock tab next to the ikuchi or Hanan. Do you think the Yojimbo would give you the same issues?
D, I’m hearing you and I won’t bang on cause this isn’t the first time I’ve posted the same but it never ceases to amaze me reading how beautifully ergonomic such and such a folder is … how it fits the hand like a glove, etc. etc. while waving it around the lounge room. :rolleyes:
From where I’m standing slab sided, locking folders, particularly with clips, described as ergonomic is a contradiction of terms.
About the only folders I’d consider “ergonomic” would be Case Sod Busters and the like. :)
curlyhairedboy wrote: ↑Thu Jun 18, 2020 6:12 pmI'd say 90% of my compression lock use is with the thumb on the back of the handle or blade. I can definitely see how the webbing of your hand can get irritated without that bracing.
I use the spine of the blade more often than not but when carving hardwood I usually default to a hammer grip.
To be fair I get the same hot spot from a lot of folders, I even got this from the Manix 2 LW but that had more to do with the square handle shape. At some point I do think this is crossing over into "you should be using a fixed blade" territory, but it's still less of an issue with other locks. It's also an issue for me with thinner than average handles, and why I greatly prefer thicker/rounder handle designs.
Yeah, they could employ the button lock feature on about any design. Risk is the accidental closure from pressing it.
Like a river flows
Surely to the sea
Evil D so it goes
Back locks are meant to be
Surely to the sea
Evil D so it goes
curlyhairedboy wrote: ↑Thu Jun 18, 2020 6:14 pmThe Yojimbo has one of the smallest cutouts for the lock tab next to the ikuchi or Hanan. Do you think the Yojimbo would give you the same issues?
Honestly I don't know if I've ever used a Yojimbo 2 as hard as this but I'll dig one out and see what happens and let ya know.
- curlyhairedboy
When I'm using the shaman in a hammer grip for really bearing down, I notice that I'm choked up in the choil getting my hand closer to the work, and the web of my hand rests on the fully supported area above the compression lock cutout.
Bloke wrote: ↑Thu Jun 18, 2020 6:15 pmD, I’m hearing you and I won’t bang on cause this isn’t the first time I’ve posted the same but it never ceases to amaze me reading how beautifully ergonomic such and such a folder is … how it fits the hand like a glove, etc. etc. while waving it around the lounge room. :rolleyes:
There are definitely different interpretations as to what "ergonomic" truly means, and as you mentioned there's a stark difference between casual use ergonomics and going out carving up a stick ergonomics. This is why I can't understand why people obsess so much over thin knives when thicker/rounder is so much better in use. I understand the argument that a knife spends more time in your pocket than in your hand, but adding ~4mm to the overall width of the handle just to round out the scales a bit doesn't exactly turn a knife into a brick and the gains in ergonomics are so worth it to me. I think there's a place for both thin and thick handles, but the lack of full figured options is a downer.
I’ve never been a fan of it for this exact reason. I own exactly one PM2... just cuz...
- Shannon
MNOSD 0006
MNOSD 0006
I can see that being an issue.
I'm usually using a saber, Filipino or pinch grip. Not a huge issue on those.
How about a G10 block on the lock bar, that when the blade is opened, fills the cutout and is flush with the scales?
-Thomas Jefferson
-Thomas Jefferson
Agree on the pinch grip keeping the hand in good shape. I still think the Stretch is the most comfortable folder for hard work.
ROCK JUMPER! Can't wait.
The Tropen has the worst ergos of any Spyderco I've ever had because of the compression lock tab and lack of anywhere else to put your thumb
Said it before: For me personally the comp. lock has always been more for smaller, more "office-type" folders (I think I´d love the Sage 5 LW), but not so much for bigger, more "hard use" models. One reason being the one David / Evil D describes (there are more, but that´s another story).
On the Stretch: For me nothing beats a backlock knife in comfort (and generally), due to the smooth, closed back. The backlock-handle-feel is as "fixed bladish" as it gets (no one would design a comfortable fixed blade deliberately with an "open back" = gap on the spine of the handle or a random cutout in the place where a comp.lock tab would sit).
It has been discussed extensively in the dedicated "Military 2" -thread, but Davids findings illustrate just one of the reasons, why a comp. lock Millie (another big "hard use" folder) just for me definitely will not be an improvement over the current, very comfortable both in ergos and in operation great linerlock-model.
Generally concerning the comp. lock: For me this is a great, ingenious design, BUT just ONE alternative among the four, main lock types Spyderco offers, which all have their specific pros and cons (comp., back, liner, CBB - lock).
I sometimes get the feeling that people with little real-use-experience (so rather not members of this forum!) reflexively think, a comp.lock knife must be absolutely the best always and for anything, cause they heard "this is just the best and coolest lock, period". While in reality, a comp. lock knife very well MAY be the best choice for a certain person and certain scenarios, but it could as well be a liner-, back-, or CBB-lock knife, if people just tested in real use what works best.
Also, there sometimes seem to be some "myths" out there, that ONLY a comp.lock can do certain things well. It CAN, of course, but other locks as well:
- "Fingers never in the blade path": No problem with backlock or CBBL either (and for me personally not important anyway, especially when a folder has choil or Ricasso);
- "Quick to open close"; Starting from an realistic user grip, all other locktypes (including backlock) can be operated as fast or faster than a comp. lock.
And so on...
Since the "comp.lock vs other locks" -discussions can get heated, as I have learned I want to make clear:
This is NOT a comp.lock bashing (I LIKE that lock type), but I am just trying to put it in a realistic perspective!
And so on...
