Yes - I normally love micarta - but I think wood would fit well with the ethnic series design behind this knife. I was dreaming of spalted maple
I was thinking of a hole delete. Honestly, I think this one is going to end up being carried clipless in the back pocket. The detent on mine is quite stiff, but it has the smoothest action of any comp lock I've ever had out of any factory.
That's awesome.Sumdumguy wrote: ↑Fri Jun 12, 2020 8:57 pmI was thinking of a hole delete. Honestly, I think this one is going to end up being carried clipless in the back pocket. The detent on mine is quite stiff, but it has the smoothest action of any comp lock I've ever had out of any factory.
Maybe on my next one, this one was Shanghaied by my wife. Haha
She didn't even fiddle with it. Just saw it and stuck out her hand.JuPaul wrote: ↑Fri Jun 12, 2020 9:09 pmThat's awesome.Sumdumguy wrote: ↑Fri Jun 12, 2020 8:57 pmI was thinking of a hole delete. Honestly, I think this one is going to end up being carried clipless in the back pocket. The detent on mine is quite stiff, but it has the smoothest action of any comp lock I've ever had out of any factory.
Maybe on my next one, this one was Shanghaied by my wife. Haha![]()
Sometimes sacrifices to the spouse gods must be made!Sumdumguy wrote: ↑Sat Jun 13, 2020 3:58 amShe didn't even fiddle with it. Just saw it and stuck out her hand.JuPaul wrote: ↑Fri Jun 12, 2020 9:09 pmThat's awesome.Sumdumguy wrote: ↑Fri Jun 12, 2020 8:57 pmI was thinking of a hole delete. Honestly, I think this one is going to end up being carried clipless in the back pocket. The detent on mine is quite stiff, but it has the smoothest action of any comp lock I've ever had out of any factory.
I am tempted to try and make my first set of scales - and was debating between "holey" and "non-holey"
I'm honestly thinking about deleting the clip altogether. If the detent on the next one is as strong as this one, I will.Spydergirl88 wrote: ↑Sat Jun 13, 2020 11:12 amLimits aftermarket clip options bc some clips "fall" into the hole
Good point. As much as I love my wire clip - it's the milling for the wire clip that is giving me the most pause about making my own scales.Spydergirl88 wrote: ↑Sat Jun 13, 2020 11:12 amLimits aftermarket clip options bc some clips "fall" into the hole
Good point. As much as I love my wire clip - it's the milling for the wire clip that is giving me the most pause about making my own scales. Also, the scales are so thin that I worry the wire cip would crack the grooves the first time it got torqued (if using wood). g10 would be safer.Spydergirl88 wrote: ↑Sat Jun 13, 2020 11:12 amLimits aftermarket clip options bc some clips "fall" into the hole
Users browsing this forum: Baron Mind, Bing [Bot], ChrisinHove, Daniel, Enactive, holeshot, Notsurewhy, Ric, SLOSpyder, Sumdumguy, Wright.88, zemogKA and 32 guests
