Most Ideal PE Or Spyderedge
curlyhairedboy
Re: Most Ideal PE Or Spyderedge
#41
Post by curlyhairedboy »
Well, I do have some of the H1 serrations to compare to, and those are pretty pointy as well. Guess we'll see when my Tenacious arrives!
marshmallow
#42
Post by marshmallow »
is the Salt 2 basically a Pacific Salt 2 mini?
"stay puft."
#43
marshmallow wrote:
Thu May 28, 2020 7:30 am
Yes it is. Actually the Salt 2 is a linerless and totally rustproof version of the Delica 4, the Pac Salt 2 of the Endura 4 (true evem for blade stock: Salt 2.5mm, Pac Salt 3mm, as it is with Delica vs Endura)
#44
Post by JD Spydo »
Evil D wrote:
Tue May 26, 2020 5:57 pm
PeaceInOurTime wrote:
Tue May 26, 2020 4:13 pm
I've found that unless I'm cutting on a surface (i.e. cutting boards), I really have no use for "positively" curved and/or angled blades on my pocket knives. Wharncliffes and hawkbills work better in my day to day cutting tasks. Make it SE and it's even better :)
Negative blade angles or at the very least a neutral angle is where it's at. As you mentioned, unless the knife is something I really plan to use in cutting board type situations I have no use for upswept blades/bellies/angles. The vast majority of stuff I cut I'm holding in my off hand.
That said, a sheepsfoot CAN do food prep if you just keep your fingers out of the way. It isn't ideal, but then no folder is ideal for food prep IMO. This is another one of those "grasping at straws" arguments that I used to make against serrations (food prep I mean).
#45
It's the same as an Endura to a Delica.
Monty
#46
Post by Monty »
I believe the salt 2 has a slightly thicker handle than the delica.
tonijedi
#47
Post by tonijedi »
Monty wrote:
Thu May 28, 2020 3:25 pm
Yes, it does.
#48
tonijedi wrote:
Thu May 28, 2020 3:27 pm
Yes, it does.
Interesting! They also said this about the Pac Salt 2 (handle thicker than on the Endura), but in that case it's seemingly not true someone who measured the thicknesses said.
bbturbodad
#49
Post by bbturbodad »
Thu May 28, 2020 4:11 pm
Yes, it does.
I just checked...
Delica 10mm
Salt 2 (Tasman) 10.9mm
Lockbar is thicker too.
Delica 2.50mm
Salt 2 (Tasman) 2.75mm
Measured across where the top screw would be if clip was set up for tip down carry (just above pivot)
-Turbo
#50
bbturbodad wrote:
Thu May 28, 2020 4:37 pm
Yes, it does.
I just checked...
Delica 10mm
Delica 2.50mm
Thanks! :)
But the actual bladestock of the Salt still is just 2.5, or 2. 75 like the lockbar?!
bbturbodad
#51
Thu May 28, 2020 4:41 pm
Yes, it does.
I just checked...
Delica 10mm
Delica 2.50mm
Thanks! :)
Yes bladestock is 2.5. I never noticed this until today?
Here's a pic...
-Turbo
#52
Post by JD Spydo »
One thing that drives people from ever using one of Spyderco's models with Teeth. One must consider that not all serrated blades are created equal. But once a person actually tries and uses a true-blue SPYDEREDGE they immediately change their way of thinking.
There are many Spyderco models that I love just as much in SE and I do in PE. One model that immediately comes to mind is the C-60 Ayoob model. That model is awesome on both edge types.
I do think that David and I both agree that the ULIZE model would be a much, much better folder in SE. And why Spyderco doesn't at least offer up one "Recurve" model in SE. The ULIZE or SPYKER in SE would be a "Dream Come True".
curlyhairedboy
#53
I'd be down for a ulize in s30v and spyderedge...
#54
Post by JD Spydo »
curlyhairedboy wrote:
Fri May 29, 2020 11:37 am
Hey "curlyhairedboy" I'm just curious? Being you like S30V in SE I'm wondering if you ever tried it's predecessor 440V in SE?. Because I love 440V in SE and that I think would be even a better pick for a serrated ULIZE model.
But on the other hand I wouldn't let an item like a blade steel selection bother me if they did decide to go ahead and do that for us.
curlyhairedboy
#55
I'll be honest, I haven't tried 440v!
#56
I'd buy a SE Ulize in 8CR if that's what it takes to get one into production. I'm in for literally any steel Spyderco has ever used, doesn't matter.
#57
Post by JD Spydo »
Like EVIL D pointed out quite some time ago that serrated blades in full flat grind make for a really aggressive cutter. The Stretch immediately comes to mind as well as the big C-54 Calypso which is one of my all time favorite serrated blades. Also serrated edges with a belly or even a slight belly like the one on the original C-44 Dyad. Also the first run serrated Ayoob model is a very agressive cutter as well.
But EVIL D is right>> we need more Spyderedges on full flat grinds.
James Y
#58
Post by James Y »
I’ve had my eye on the SE Endela, as I’ve always had good luck with SE VG-10, plus it’s FFG. Up to now, I’ve never owned a Spyderco that is both SE and FFG. Maybe someday, when the income starts flowing again. :)
#59
JD Spydo wrote:
Sun May 31, 2020 12:01 pm
It was the SE Stretch that opened my eyes to it. It's a fairly thin blade especially towards the tip. It was really the SE Stretch that brought me to love SE, despite the fact that my very first Spyderco was a SE Native, it just didn't click until I got that Stretch.
#60
Post by JD Spydo »
Evil D wrote:
Sun May 31, 2020 3:09 pm
If you ever get a chance to get your hands on a first generation C-54 Calypso in SE. If you liked that Stretch in SE then you'll love that big Calypso. It was one of the biggest regrets I've had to this day when I traded mine away.
I'm still just baffled why Spyderco doesn't at least do one "recurve" model in SE >> My first pick would be the ULIZE but the SPYKER would be great in SE Too
