- bearfacedkiller
Been carrying this knife for about two weeks. Doesn’t get much better than this one!
Yeah, I’m still bummed I didn’t jump on that one like a chicken on a June bug...
Well, the lynch clip arrived, but sadly it's too short to help with my grip when closing the knife. If they made a longer one, I think it'd make a big difference. Luckily I like the lynch clip a lot on the para3 lw, so it won't go to waste. As it is, I like the manix lw enough to keep it around and see how much I carry it this summer. It definitely fills a niche in my collection for a bigger lightweight knife, and I do want to give s90v a fair go.Wartstein wrote: ↑Sat May 16, 2020 1:47 pmThanks, just wanted to congrat you on your great PM2 pic above too... :p
/ Yes, I am happy to have a Manix once more! And funny, all that contemplating about the G10 Rex 45 Manix and what I really want in a knife, made clear for me that still the LW platform is the way to go for me personally. At least as long as I have already several linered knives like Endura, Stretch, Endela, Delica and Chap.
/ How do you like your orange S90V Manix LW meanwhile?
Btw, I have tried closing it as you suggested, but it's very awkward for me. Feels like my hands are too small to grip the lock in that position. But I'll keep trying. :)
- Julia
- JonLeBlanc
That's a totally legit reason to buy any Spyderco! I think a big S90V blade like that makes for a perfect yard work folder :cool:
- toxophilus
Tools for the week; CTS-XHP/CTS-204P/ZDP-189; liking these (new to me) Tero-tuff scales :spyder:
- RadioactiveSpyder
Very nice. :cool: :spyder: I don't usually go for blacked out knives, but it looks great with the smooth scales. Are those from the KC Cruwear Native or...?
- RadioactiveSpyder
Thank you, yes it’s a blade swap between the KC smooth G10 Cruwear exclusive and the BHQ DLC M4 exclusive. :)
- Crazy Canuck
- Mike
Singing along with the voices in my head
Yes, the LW is a great summer-shorts-knife! :) Light weight in larger size actually "feels lighter" than the same light weight in smaller size, and as a matter of fact light weight in large size is less "bouncy" in light-garment-pockets than light weight in small size.JuPaul wrote: ↑Sat May 16, 2020 2:43 pmWell, the lynch clip arrived, but sadly it's too short to help with my grip when closing the knife. If they made a longer one, I think it'd make a big difference. Luckily I like the lynch clip a lot on the para3 lw, so it won't go to waste. As it is, I like the manix lw enough to keep it around and see how much I carry it this summer. It definitely fills a niche in my collection for a bigger lightweight knife, and I do want to give s90v a fair go.
/ On different closing methods of the CBBL: There are several more I use (for me the CBBL is the second most versatile lock in use, just the backlock is better). Maybe I´ll start a thread on this and try to post some vids.
Perhaps your hands are too small for the one I described, but perhaps I just did not explain it properly?
The basic idea is:
You still pull the CBBL with thumb and index finger,but don´t put the other three fingers on the clip, but like in a "regular grip" around the handle (so middlefinger, ringfinger, pinky on the downside of the handle) - for me that is even easier to do than with the fingers on the clip - ?! (And the knife is more secure in my hand) . but it might not be for your hands of course
Then you just let the blade drop (or give it a little shake if it is not free dropping) like many do with a backlock
From there on you just do whatever you´d do when you´re closing a backlock.
I don´t know if you can pull the CBBL with just the thumb on one tab (instead of two fingers and using both tabs), but if you can here is another method:
- Index finger in the opening hole, thumb on the lock tab, other fingers in the downside of the handle
- Pull the lock with the thumb
- Guide the blade to closed with the index finger while moving the other fingers out of the way in the process
For me both the above methods work as fast/easy or even faster/easier than the usual CBBL closing method ("swing" the blade to close with all fingers out of the way) when I start from a realistic grip you´d use for cutting stuff
- bearfacedkiller
Slo-mo fire and the Rex Military!
Su-weet! My millie doesn’t work like that
To remove lateral blade wiggle, I’ve got to tighten the pivot to the point the blade doesn’t move under its own weight. I can “spydie-drop” it but mostly just thumb it open. Need new pivot washers I guess. Not that I mind; it makes for a very controlled one-hand close.
So I think the washer are too thick, given the interference fit I’m getting. Maybe I could lay them on a white ceramic stone and home them a bit?
W, I'm starting a new thread on this so I don't derail this one...Wartstein wrote: ↑Sat May 16, 2020 11:34 pmYes, the LW is a great summer-shorts-knife! :) Light weight in larger size actually "feels lighter" than the same light weight in smaller size, and as a matter of fact light weight in large size is less "bouncy" in light-garment-pockets than light weight in small size.JuPaul wrote: ↑Sat May 16, 2020 2:43 pmWell, the lynch clip arrived, but sadly it's too short to help with my grip when closing the knife. If they made a longer one, I think it'd make a big difference. Luckily I like the lynch clip a lot on the para3 lw, so it won't go to waste. As it is, I like the manix lw enough to keep it around and see how much I carry it this summer. It definitely fills a niche in my collection for a bigger lightweight knife, and I do want to give s90v a fair go.
The basic idea is:
- Julia
- PeaceInOurTime
- Crazy Canuck
UKPK today
- Mike
What model is that? Don't ever remember seeing it before.
- Connor
This is the Chubby by Michael Burch. Definitely lives up to its name at 2.3" blade length and .175" blade thickness. :)The Meat man wrote: ↑Sun May 17, 2020 3:00 pmWhat model is that? Don't ever remember seeing it before.Mushroom wrote: ↑Sun May 17, 2020 1:58 pmReady for a Bombshell to drop!
[mg] https://i.imgur.com/4zVJQST.jpg [mg]
-Nick
