Wharncliffe blade: Delica or Salt 2?
Edward_Scissorhands
Post by Edward_Scissorhands »
Which would you choose? I already have the DF2 Wharn, but looking for a bit larger while still staying lightweight. As far as other brands go, that Cold Steel Tuff Lite looks interesting for the price, but the steel is only AUS-8.
The Meat man
Re: Wharncliffe blade: Delica or Salt 2?
Post by The Meat man »
If you don't want serrations, I'd go with the Delica.
Edit: forgot that the Delica also comes serrated, so unless you need extreme corrosion resistance, I'd recommend the Delica in either case.
- Connor
VooDooChild
Post by VooDooChild »
The tuff lite is great for the money.
I agree with the meat man. Serrations should be the deciding factor.
tonijedi
Post by tonijedi »
Besides the obvious difference in corrosion resistance, in my opinion the deciding factor is blade grind.
Do you want FFG or HG?
Edward_Scissorhands
VooDooChild wrote:
Fri May 01, 2020 7:50 am
Thanks, I was thinking plain edge. I'm gonna give the Tuff Lite a try. Seems like a really solid knife for 30 bucks. I do like my Spydies, but I feel like a lot of them are a bit more $$ than they should be. Of course, Benchmade is even worse in that regard.
Edward_Scissorhands wrote:
Fri May 01, 2020 8:27 am
If you really want PE: HAP40 Delica.
If you still consider SE: VG10 Delica. Serrations in that thin ffg blade must be amazing, and imho VG10 is a great steel for SE.
I'd not go sabre / hollow in a wharnie blade.
James Y
Post by James Y »
I only have the Wharncliffe Salt 2 (serrated). It doesn’t seem to get much if any mention on the forum, but it’s a great knife (at least in SE). If you were looking at PE, I’d recommend the Wharncliffe Delica 4, even though I don’t own one. IMO, the Delica’s FFG combined with PE VG-10 would be better than the PE and hollow saber grind of the H1.
speedseeker
Post by speedseeker »
Unless you need extreme corrosion resistance then Delica.
the yo2 is an excellent wharncliffe... just saying. :)
C253GBBK, C258GFBL, C101GBBK2, C11GYW, C11FWNB20CV, C101GBN15V2, C101GODFDE2, C60GGY, C149G, C189, C101GBN2, MT35, C211TI, C242CF, C217GSSF, C101BN2, C85G2, C91BBK, C142G, C122GBBK, LBK, LYL3HB, C193, C28YL2, C11ZPGYD, C41YL5, C252G, C130G, PLKIT1
CPM 20CV, CPM 15V, CTS 204P, CPM CRUWEAR, CPM S30V, N690Co, M390, CPM MagnaCut, LC200N, CTS XHP, H1, 8Cr13MoV, GIN-1, CTS BD1, VG-10, VG-10/Damascus, 440C
Jazz
Post by Jazz »
The Tuff Lite is harder to open, and the lanyard hole is at the wrong end, and the Delica is superior in every way. I have both, so not just saying.
- best wishes, Jazz.
The Delica will be a far better slicer. I wonder if I can put the Delica blade in a Salt handle?
Igi964
Post by Igi964 »
Yes, You can. Blades are changeble, but with the backlock. Jazz did it and me too. Its my dream EDC. Delica Wharncliffe in Salt 2 thicker and lighter handle.
I would post some pics, if it wasn't such PITA :mad:
Jazz
Post by Jazz »
Mine now has a HAP40 blade in it, but this older pic is the VG10 in the Salt handle.
Igi964 wrote:
Sun May 03, 2020 7:56 am
Try this: viewtopic.php?t=83968 ;)
Jazz wrote:
Sun May 03, 2020 8:12 am
Nice!
Edward_Scissorhands
Sat May 02, 2020 8:43 pm
I have the Yo2. Sweet knife, but it's pretty beefy. I worry I might scare the sheeple if I ever used it in public.
