Native 5 Liners/Washers?
afalcone
Post by afalcone »
Hi all,
I heard that in the G-10 version of the Native 5 they recently made the decision to get rid of the liners? This is news to me I suppose. Anyway, I'm wondering how that's going and what thoughts everyone has? Mostly I was going to buy one because I was under the impression the G-10 version of the knife had bronze washers. But if not then I'm wondering how exactly they're different than the LW versions if at all? Thanks in advance for your time.
afalcone
Re: Native 5 Liners/Washers?
Post by afalcone »
This is mostly regarding the new REX45 sprint runs to be honest.
ugaarguy
Post by ugaarguy »
The G10 REX45 sprint has bronze washers just like the other liner-less G10 N5s. My example of the REX45 G10 N5 is much smoother than my S30V N5 LW, and N5 Salt. I prefer the thread inserts for the clip screws on the liner-less G10 models over threading the clip screws into the liners on the older version. I think the switch to liner-less G10 was a big improvement.
Aside from the Native 5 LW models (which I like) the only linerless models I have are the 40th Anniversary & Fluted Titanium. The action on those are as good as any linered models I've had
afalcone
Post by afalcone »
So I think I'm missing something here. How do the G-10 models have washers but no liners?
NorthShoreBoiBoi
Post by NorthShoreBoiBoi »
The LW natives dont need washers due to the FRN basically having nylon washers built in. The G10 native have bronze washers to buffer the blade from either the g10 or the steel liner
afalcone
Post by afalcone »
How do y'all feel about it? Do the linerless G-10 models feel good the way they are or do you feel they lack something?
bbturbodad
Post by bbturbodad »
I don't have another Native to compare it to, but the Rex 45 G-10 is very smooth. The blade drops nicely to 90° upon unlocking and flicks open nice and crisply. Overall very impressed with the build quality.
-Turbo
JuPaul
Post by JuPaul »
I have no problems with the linerless g10 natives per se. I have the rex45 now, and I had the cruwear/smooth g10. But if you want to swap scales, your choices are pretty limited. Not sure anyone makes aftermarket micarta or terotuf scales for the linerless natives.
The rex45 native I have is very smooth. Much more so than the native salt was when I first got it.
- Julia
NorthShoreBoiBoi
I havent handled a linered g10 version, but between the LW and linerless its mainly just the feel of the material and handle texturing. The g10 feels heftier and maybe shifts the balance back a bit. I would assume having liners would move the balance back more and make it seem even beefier. The scales on the LW and g10 are the same width, so if the linered version has the same size scales it may be a little wider.
As for smoothness, the only the Native Salt gave me an issue. My most used native and by far the longest to break in for some reason
afalcone wrote:
Wed Apr 08, 2020 7:54 pm
If both the previous linered and the current linerless G10 Natives do have bronce washers, I don't see why they should feel differently in that regard:
In both cases on the "inside" of the washers is the blade, and just on the "outside" of the washers either metal or G10... that should make no real differences concerning the action of the blade...?!
anycal
Post by anycal »
G10 vs FRN, other than the texture of the handles, they feel very similar when closed. There is a bigger balance difference is when they are open, as the G10 is heavier, and the G10 model has a metal back spacer.
I have couple of each, and like others noted, there is no difference in the action between them, washwers or the lack of.
I prefer the G10 model. I like the denser feel of this particular knife in the G10 configuration.
Peter
ugaarguy
Post by ugaarguy »
anycal wrote:
Thu Apr 09, 2020 9:23 am
I'm pretty surprised to read that. I've found the lightweights to be significantly stiffer than the liner-less G10 with bronze washers. How much break in have your LWs had?
anycal
Post by anycal »
ugaarguy wrote:
Thu Apr 09, 2020 4:22 pm
Although I am sure it works, I don't believe in break in. I have experienced all kinds of action levels, across all knifes, from all manufacturing facilities. If a knife is stiff or gritty, it will get at minimum pivot adjustment and/or a drop of oil. Next step is to completely take it appart.
That said, both my LW S110V and REX 45 came free droping on day one.
I guess the point of the highlighted comment was more to both version of Native, with or without bronze washers, broken in or adjusted, can be equally smooth.
Peter
anycal wrote:
Thu Apr 09, 2020 4:48 pm
Same here. My REX 45 N5 LW was noticeably stiffer than my other Natives LW. I loosened the pivot screws a 1/8 turn (at most) and a drop of Go Juice (oil) to the tang where the lock bar rides. It's now much better. IIRC my Maxamet Native 5 was the same when I first got it.
bbturbodad
As an update to my previous post, I received a LW today and surprisingly the action is even smoother than it is on my G10 model. Neither have had any adjustments to the pivot although both have had a couple drops of oil added.
Comparing the 2 I like the weight and action of the LW better but the G10 feels better in hand. I'm not a big fan of the FRN that Golden uses, it feels plasticy and cheaper to me than the FRN from the other factories.
-Turbo
ugaarguy
Post by ugaarguy »
Okay, what lube are you using? I've just tried two different lubes, after cleaning the internals with isopropyl alcohol each time before applying each lubricant. I tried loosing the pivot a bit off of finger tight. My N5 Salt is still much stiffer than my REX45 G10.
anycal
Post by anycal »
ugaarguy wrote:
Thu Apr 09, 2020 7:17 pm
BM blue.
At some point, maybe it is the knife. Something maybe off a bit, a burr in the plastic, or handle alignment.
Peter
bbturbodad wrote:
Thu Apr 09, 2020 5:53 pm
I took mine apart to dial it in better the other night. Alcohol wipes and a little lube, dialed in the pivot and it doesn't drop shut but is a lot less stiff upon opening now.
I hear ya on the FRN, I was hoping this knife would change my mind but...I just cant. I like my knives to have a little heft to them, and FRN just feels like slick plastic to me, like holding a cheap toy. I'm going to force myself to carry it one of these coming weeks, but I don't see it hanging around long.
bbturbodad
Sat Apr 11, 2020 9:14 am
Make sure you're pushing the lock all the way in, at first mine would only drop freely about 50% of the time...then I realized I wasn't always pushing the lock fully flush.
-Turbo
