Used mah FRN Chaparral to open a box from MXG Gear... :)
- PeaceInOurTime
Finished slicing a poorly-sliced pizza with the SE wharncliffe Endura :)
Typical daily cutting tasks, with the exception of helping the skeleton maintenance crew cut up some rubber to use as vibration absorbers for a couple motor bases.
15 's in 10 different steels
Did some light wood carving with the Zoomer!
Found a small old rake head in the woods behind my house, so I decided to revive it for my niece so she can “help” with yard work. :) I took the handle from an old broken kids snow shovel and used the Zoomer to thin the taper a little bit so it will fit completely on the rake head. The ergonomics on this knife are absolutely phenomenal! :spyder:
- Nick
So nice to see a Zoomer in the wild!
- PeaceInOurTime
Hahaha!! Bloke, did you put cameras in my house again???
- kennethsime
Made a grocery run today, the store was running low on bags (I guess they're made in China, go figure) so they asked if I minded them packing my stuff into cardboard boxes instead. "Do I Mind? Do I Mind!?" Little did they know, I had a new Spyderco Para 3 LW in my pocket and I couldn't wait to reduce this mess down into the recycling bin. B-)
- Maximumsmoochy
Praise the boxes, without them we would all just be waving our knives around in the air!kennethsime wrote: ↑Wed Apr 08, 2020 12:03 amMade a grocery run today, the store was running low on bags (I guess they're made in China, go figure) so they asked if I minded them packing my stuff into cardboard boxes instead. "Do I Mind? Do I Mind!?" Little did they know, I had a new Spyderco Para 3 LW in my pocket and I couldn't wait to reduce this mess down into the recycling bin. B-)
Past: Dragonfly, Air, Rhino, Lil' Native, Techno 2, Caly Jr., Brouwer, Chap LW, Para3, N5, Watu, ‘Chef, Mantra 2, SSStretch, PM2, Smock, Shaman, Advocate, GB2, Kapara, Military, Bradley Bowie, Province
Present: P4 K390 FRN
Future: Para3 Cruwear (someday)
Regrets: Most of them
Last time I picked up one of my many Spyderco knives, it was an FRN Endura, and the clip had come slightly loose in my pocket. I'm very detailed and meticulous with precision things like torx 6 screws, but a small turn on a screw, and it stripped.
So, I tried swapping scales from an another endura model I had, only to find out just how fussy these particular models are. When disassembled,but hey, scales are not sold anymore....
No luck, and I'm not wasting time sending them back for work. They're going in the garbage during this covid19 scare, with the rest of my spring cleaning
Rest of my Spyderco knives are probably going up for sale, and they're all shelved.
Been a collector since 97, but no more.
Disappointed in the quality of the Seki models, and Golden models are just too expensive.
:spyder: MEMBRE DE L'ORDRE INTERNATIONALE SPYDEREDGE :spyder:
- PeaceInOurTime
Hawkbill Ladybug opened my new Bluetooth earbuds :)
Well that is sad to hear! Were these older enduras? I've swapped blades btw at least four of my delica 4s and never had an issue, although I have found I needed to swap both the blade and lockbar together.D-Roc wrote: ↑Wed Apr 08, 2020 3:42 pmLast time I picked up one of my many Spyderco knives, it was an FRN Endura, and the clip had come slightly loose in my pocket. I'm very detailed and meticulous with precision things like torx 6 screws, but a small turn on a screw, and it stripped.
Edit to add: there are definitely some tricks to reassembling the seki backlocks - youtube helped me greatly.
- Julia
I was going to remark that that looked like a cigarette your ear....
Then I zoomed in.
Then I zoomed in.
- bbturbodad
Bloking around and getting an early jump on recycling for the week...
-Turbo
- PeaceInOurTime
Ha! I've been Bloked twice in the past couple days. Feels good :cool:
Turbo, that's quite a bit of cardboard!
Trying to teach my kids how to build a fire, so I've been using my Shaman for shavings and what not.
I used two of them for an experiment!
I had put a RGT clip on my P.I.T.S. because I despise wire clips marking up my titanium handles. Also for that reason, I haven’t enjoyed my Mantra 2 yet. So, I moved the RGT clip from the P.I.T.S. to the Mantra 2:
And how delightful a change it is!!
Want: SPY27, K490, Swick 5.
Cardboard cutting with my Delica
Barry
Bonne Journey!
MNOSD member 0032
Bonne Journey!
MNOSD member 0032
- bbturbodad
