Rivers Edge Cutlery Mystery Exclusive (DLC 10V/Coyote Brown G10 Paramilitary 2)
Re: Rivers Edge Cutlery Mystery Exclusive (DLC 10V/Coyote Brown G10 Paramilitary 2)
Yikes! What were you cutting, or cutting on when you think that may have happened?
15 's in 10 different steels
The only thing I have cut with it is fruits and a beef roast. It must have came out of the box like this. I never noticed the chip until a patina started forming and the chip showed up as a black spot on the edge. Its very small so it was hard to see before.
Hopefully it was just an issue with the factory edge - maybe got banged up before packaging. Fingers crossed it'll sharpen out and never happen again.SpyderGrill wrote: ↑Sat Mar 28, 2020 12:25 pmThe only thing I have cut with it is fruits and a beef roast. It must have came out of the box like this. I never noticed the chip until a patina started forming and the chip showed up as a black spot on the edge. Its very small so it was hard to see before.
- Julia
You are correct. This is the sharpest knife I have ever received from the factory.JMM wrote: ↑Thu Mar 26, 2020 8:36 pmMy Manix2 Rex45 was sharp, but not exceeding sharp, not enough to keep me from sharpening it immediately... but this new PM2 is the sharpest knife, from any factory, from any country, from any company for that matter that I have ever received. I did not sharpen mine, I did strop it, and afterwards was able to get it to snag on a hair, but not quite whittle it... fan-freakin-tastic! :D
- VooDooChild
I said in the hardness thread how much I liked the grind lines. When the light hits it just right it is the best looking satin finish I have seen.
I can also second how scary sharp it is. Already cut my thumb wiping the blade clean.
Sharpened up nicely with 240 and 400 grit Venev bonded diamond stones, finishing with 14 and 3 micron basswood strops.
Hair popping sharp now.
- Connor
Can't wait for these test results! As usual, looks great Connor! You always do a great job on those edges.The Meat man wrote: ↑Mon Mar 30, 2020 7:27 pmSharpened up nicely with 240 and 400 grit Venev bonded diamond stones, finishing with 14 and 3 micron basswood strops.
Thanks! The edge came up pretty nicely. I almost don't want to use it now. :)TkoK83Spy wrote: ↑Mon Mar 30, 2020 8:41 pmCan't wait for these test results! As usual, looks great Connor! You always do a great job on those edges.The Meat man wrote: ↑Mon Mar 30, 2020 7:27 pmSharpened up nicely with 240 and 400 grit Venev bonded diamond stones, finishing with 14 and 3 micron basswood strops.
- Connor
I contacted REC about my chipped scale and they responded politely and promptly offering to replace it with another they hold back for just such occaisions. I thought about it and came to the conclusion I'd just keep the one I have. It has good grind lines, and bushing tolerances and will be a user anyway. I figured I would leave the perfect cosmetic samples to those for whom that matters
Will post further once I sharpen mine and do some cutting with it.
It is finally in my hands :D :D :D
- VooDooChild
Clip
I like how you get your edge angle to be so consistent, without concavity. Do you use a jig system of some kind?The Meat man wrote: ↑Mon Mar 30, 2020 7:27 pmSharpened up nicely with 240 and 400 grit Venev bonded diamond stones, finishing with 14 and 3 micron basswood strops.
Yes I use the Hapstone V7 sharpener. It's like a premium Edge Pro.JohnDoe99 wrote: ↑Wed May 20, 2020 1:51 pmI like how you get your edge angle to be so consistent, without concavity. Do you use a jig system of some kind?The Meat man wrote: ↑Mon Mar 30, 2020 7:27 pmSharpened up nicely with 240 and 400 grit Venev bonded diamond stones, finishing with 14 and 3 micron basswood strops.
- Connor
