Rivers Edge Cutlery Mystery Exclusive (DLC 10V/Coyote Brown G10 Paramilitary 2)
Re: Rivers Edge Cutlery Mystery Exclusive (DLC 10V/Coyote Brown G10 Paramilitary 2)
#161
Yikes! What were you cutting, or cutting on when you think that may have happened?
SpyderGrill
#162
Post by SpyderGrill »
Sat Mar 28, 2020 6:24 am
The only thing I have cut with it is fruits and a beef roast. It must have came out of the box like this. I never noticed the chip until a patina started forming and the chip showed up as a black spot on the edge. Its very small so it was hard to see before.
JuPaul
#163
Post by JuPaul »
SpyderGrill wrote:
Sat Mar 28, 2020 12:25 pm
Hopefully it was just an issue with the factory edge - maybe got banged up before packaging. Fingers crossed it'll sharpen out and never happen again.
- Julia
EngDevGr3
#164
Post by EngDevGr3 »
JMM wrote:
Thu Mar 26, 2020 8:36 pm
DTPrime wrote:
Thu Mar 26, 2020 8:07 pm
Mm1313 wrote:
Thu Mar 26, 2020 7:44 pm
Missed the first drop but pumped I grabbed a satin on this one... Love the grind lines on these & the rex45 models.
They do both have very distinct grinds- and the 10v PM2 is also the sharpest knife I've received to date with the Rex45 Manix a close second.
My Manix2 Rex45 was sharp, but not exceeding sharp, not enough to keep me from sharpening it immediately... but this new PM2 is the sharpest knife, from any factory, from any country, from any company for that matter that I have ever received. I did not sharpen mine, I did strop it, and afterwards was able to get it to snag on a hair, but not quite whittle it... fan-freakin-tastic! ;) :D
You are correct. This is the sharpest knife I have ever received from the factory.
VooDooChild
#165
Post by VooDooChild »
I said in the hardness thread how much I liked the grind lines. When the light hits it just right it is the best looking satin finish I have seen.
I can also second how scary sharp it is. Already cut my thumb wiping the blade clean.
The Meat man
#166
Post by The Meat man »
Sharpened up nicely with 240 and 400 grit Venev bonded diamond stones, finishing with 14 and 3 micron basswood strops.
Hair popping sharp now.
- Connor
#167
The Meat man wrote:
Mon Mar 30, 2020 7:27 pm
Can't wait for these test results! As usual, looks great Connor! You always do a great job on those edges.
The Meat man
#168
Mon Mar 30, 2020 8:41 pm
Thanks! The edge came up pretty nicely. I almost don't want to use it now. :)
- Connor
Cycletroll
#169
Post by Cycletroll »
I contacted REC about my chipped scale and they responded politely and promptly offering to replace it with another they hold back for just such occaisions. I thought about it and came to the conclusion I'd just keep the one I have. It has good grind lines, and bushing tolerances and will be a user anyway. I figured I would leave the perfect cosmetic samples to those for whom that matters ;)
Will post further once I sharpen mine and do some cutting with it.
kirilpetkov
#170
Post by kirilpetkov »
It is finally in my hands :D :D :D
VooDooChild
#171
Clip
JohnDoe99
#173
Post by JohnDoe99 »
I like how you get your edge angle to be so consistent, without concavity. Do you use a jig system of some kind?
The Meat man
#174
JohnDoe99 wrote:
Wed May 20, 2020 1:51 pm
Yes I use the Hapstone V7 sharpener. It's like a premium Edge Pro.
- Connor
