Lil Manix
Doeswhateveraspidercan
Re: Lil Manix
Neat idea but I do not find anything in the Manix line I actually like except for the XL.
aaronkb
Re: Lil Manix
Post by aaronkb »
I’d buy one
Sumdumguy
Re: Lil Manix
Post by Sumdumguy »
I'll put up my blast shield in advance of this idea.
If the CBBL won't work on a small one...
Compression lock?
*ducks*
-Thomas Jefferson
Re: Lil Manix
Sumdumguy wrote:
Thu Mar 12, 2020 6:35 pm
Compression lock?
*ducks*
I support this idea too
Spydergirl88
3 Nats, 1 Chap, 1 Sham, 1 Urb
JuPaul
Re: Lil Manix
Post by JuPaul »
Theldraskien wrote:
Thu Mar 12, 2020 4:42 pm
based on my experience with the Manix XL I think it may also be habituation to the opening method. I found it really difficult to unlock the XL one handed when I first got it, but after a couple of days practicing it was no problem. I don’t think it had anything to do with the spring lightening, I think it was my fingers getting stronger.
I definitely had to get the trick of opening the cbbl. In fact when I first got one I didn't like it for that reason. But once I figured out how to hold it and use the pocket clip for some leverage, I came to love it. I sold my lightweight for that reason, though. With the frcp scales I just couldn't get as good of a grip. I might give it another shot with the rex45 model if I can get one. Not sure, though.
- Julia
JMM
Re: Lil Manix
Post by JMM »
With the CBBL viability question in that small of a platform -- what about using the bolt lock (Sage3)? It's absolutely wonderful for that size of knife. Just a thought..
Re: Lil Manix
I support it! The Manix never really felt great to me; very "locked in" if it fits your hand perfectly, but I always felt my hands were too large for it. At any rate, I'm all about the XL/Mini iterations of already-great knives, because I'm OCD and like things that match.
Speaking of, I'm still looking out for a 3" Straight Spine Stretch and Dragonfly. :-)
Pancake
Re: Lil Manix
Post by Pancake »
Not for me.
Manix is already small for my taste.
rabbitanarchy14
Re: Lil Manix
Post by rabbitanarchy14 »
i have been asking for this for a long time and have started threads asking for this. i want one in 3" or 2.75-2.8".
everyone just told me to grind down a good manix, no. i would like one made that size with the cbbl.
and just to say again this is around the perfect size of accaptable. a normal size knife is 3.125" ish.
and just because there are people who say that it is too small just have compensation issues. if you have a reason for work to use a bigger knife fine but carrying a massive blade makes all knife holders look bad wipping out a huge 3.5 - 4" blade as though its a weapon, no you dont look kool you make us all look bad.
192.168.0.1 -Para 3 G10 M390 Red, Dice XHP, Lil Native Rex 45 comp, Manix 2 M390 G10 BR, PM2 M390 DLC BL, PM2 k390 RGreen, Cat BD1N, Dragonfly 2 k390
Saving for - Lil Native K390, D'allara 3, UTX-70
Instruments- Kimber EVO, SA Hellcat, SW Shield Plus 9
BLJace
Re: Lil Manix
Post by BLJace »
Compression lock?
*ducks*
I love the idea of a mini manix, but if we add in the compression lock aren't we coming close to a mini shaman?
actually... i want a mini in both.
:spyder: I used to collect a lot of knives... I still do, but i used to too. :spyder:
Pancake
Re: Lil Manix
Post by Pancake »
rabbitanarchy14 wrote:
Fri Mar 13, 2020 2:15 am
I could write down a long response, but I am going to write just this: Just because you have a opinion, it is not going to make everyone else with different opinion wrong. That is very childish approach to a discussion.
I wish you could get a Mini Manix.
Re: Lil Manix
#32
For about a year straight I struggled between which I preferred, the Manix 2 or Para 2 and ultimately it came down to ergos and lock differences. What I realized about the M2 is that you need to be able to plant the butt end of the handle into your palm in order to get enough leverage to pull back the lock cage. I suspect this is why we've never seen anything bigger than the XL with a CBBL. So, going the opposite way, I think a smaller Manix 2 handle would make it even easier to operate the lock since it would be easier to palm the handle to get that leverage. This is an area where the compression lock is a significantly easier to operate design.
Sumdumguy
Re: Lil Manix
#33
Post by Sumdumguy »
BLJace wrote:
Fri Mar 13, 2020 3:57 am
Compression lock?
*ducks*
Not even slightly. The Shaman and Manix are wildly different designs, regardless of lock type.
-Thomas Jefferson
curlyhairedboy
Re: Lil Manix
#34
Post by curlyhairedboy »
Based on models such as the lil native and the ikuchi, I think it's apparent that the lock size and packaging concerns for the compression lock are a lot more friendly to smaller knives than perhaps the CBBL. What's interesting is the ceramic BL has seen use on smaller knives before. Maybe there's a way to fit a cage around that so you don't have to dig in a finger?
jdw
Re: Lil Manix
#35
Post by jdw »
curlyhairedboy wrote:
Fri Mar 13, 2020 4:53 am
I wish that we would see some small autos out of Golden.
--Wovoka
Notsurewhy
Re: Lil Manix
#36
Post by Notsurewhy »
Not sure how well the ergos would scale down on the manix design, but I'd love to see some smaller cbbl knives. I prefer the cbbl to the compression lock and think it is seriously underused.
Sumdumguy
Re: Lil Manix
#37
Post by Sumdumguy »
Notsurewhy wrote:
Fri Mar 13, 2020 2:22 pm
I'm Notsurewhy. :P
-Thomas Jefferson
Notsurewhy
Re: Lil Manix
#38
Sumdumguy wrote:
Fri Mar 13, 2020 2:29 pm
I'm Notsurewhy. :P
The first step toward knowledge is admitting ignorance.
Some day I'll make it to step two :D
kodai78
Location: “Beam me up Scotty, there’s no intelligent life down here.”
Re: Lil Manix
#39
Post by kodai78 »
I have 2 Manixes a LW and a second that had the swirly brown and black slabs with a big void in them that I swapped some aluminum scales onto. Neither was especially stiff at any time that I recall. Certainly the scale swap one was never difficult to operate. That said I would love a mini with a wire clip and G10, the LW is a nice knife but I prefer my cutting tools to feel denser in hand.
:spyder: Shaman REX 45, Smock, Baby Jess Horn CE, Spydiechef, Schempp Bowie,Ti Fluted Military, Titanium Military, Native S30 V and G10, PM 2 in S35VN, and S110V, Manix 2 LW BD1 and SPY 27, Sage 5, Positron black CPM S30V, Chaparral w/Raffir Noble scales, SuperLeaf VG 10, Ladybug H1, Dragonfly 2 in ZDP 189 and Superblue/420J1 and H1, Delica in ZDP 189, Clipitool Standard, the Cook’s knife VG10, Santoku, paring and utility knives, all in MBS 26. :spyder:
Re: Lil Manix
#40
If this type of knife ever happened, the ergonomics around the pivot virtually wouldn't change. The primary changes would be to blade length and handle length. It wouldn't be a "scaling down", but more of a "trimming off."
This is how the Para 3 was derived from the PM2 and how the Lil Native was derived from the Native 5. They maintain the same ergonomics in the pivot section and adjust the front end of the blade and the back end of the handle.
-Nick :bug-red
