Ikuchi
curlyhairedboy
Re: Ikuchi
#101
Post by curlyhairedboy »
Also, relative finger strength skews detent preferences on flippers a bunch - with flippers you're relying on a biological "spring" in your finger tendons, and that's a variable that can change day to day based on previous loads, repetitive motions, irritations, arthritis, etc.
I've used flippers for years primarily with my dominant hand, and it shows. I can press down with my index finger on that hand about 20 pounds harder than with the index finger on my other hand before causing any discomfort.
Thus, even the CQI detent is perfectly normal for me and I could stand to have it a fair bit tougher before I'd be uncomfortable.
JuPaul
Re: Ikuchi
#102
Post by JuPaul »
curlyhairedboy wrote:
Fri Dec 06, 2019 9:13 pm
I'm sure that's true, and undoubtedly most of the men on here have stronger fingers than I do (as a woman with skinny fingers). I've only tried one other flipper a few years ago that I found this difficult to operate, though. On this one it's a combo of the unique flipper wheel and the super strong detent that got me. I think a corner flipper like the smock would've worked for me. Anyhow, no design can suit every single person, and I'm obviously in the minority of users overall. Glad you guys love it!
- Julia
flasharry
Re: Ikuchi
#103
Post by flasharry »
Well.. Blades Canada just got them back in stock (I missed the original lot by 5 minutes) - Got one inbound, will let y'all know what I think and how I find it..
Cheers
Harold
"You never know what lonesome is, 'til you get to herdin' cows"
Mikelly
Re: Ikuchi
#104
Post by Mikelly »
Just got mine today. Took a couple flicks to break in but was ok after that. You know i have one of the natives with the lc200n and that one is stiff because of the design. I love knives with new designs like this but with new designs comes new tolerances and issues. It's always a gamble...isn't this the knife that the tip was poking people when it was closed cause of the weak detent? . I think it's great that the CS dept at spyderco is so awesome for being good to the customers.
flasharry
Re: Ikuchi
#105
Post by flasharry »
Arrived today!
Thoughts:
- out of the box. wow was that tough to flip open.. Hopefully it will break in a bit.. the flipper disc was not that painful. though..
- Fit and finish are great, blade centered, etc..
- Carbon fibre is nice and looks good, buyt how about polished G10 (like the old Des Horn?)
- that tip is ferocious!! it didn't snag my finger either..
So. all in all. its a keeper, but can someone reassure me it the detent will free up a bit??
Thanks
Harold
Dazen
Re: Ikuchi
#106
Post by Dazen »
flasharry wrote:
Wed Dec 11, 2019 1:33 pm
Yes, it gets noticeably easier the more you use it! Mine is butter smooth now.
Dane
jylong_away
Re: Ikuchi
#107
Post by jylong_away »
Hi all,
A bit late to the CQI party, bit does anyone know how to identify a CQI Ikuchi from the batch number/letter? Am trying to figure out if my usual reseller has a CQI batch or not?
Thanks!
Larry_Mott
Re: Ikuchi
#108
Post by Larry_Mott »
My own CQI :) well visually anyway. Bocote scales made by a instrument maker friend of mine.
Sumdumguy
Re: Ikuchi
#109
Post by Sumdumguy »
Larry_Mott wrote:
Wed Feb 19, 2020 1:02 am
That is gorgeous, Larry! Once I get everytjing settled down here, I've got several scales in Koa ready to be finished and a block of Kamagong waiting to be utilized!
-Thomas Jefferson
ChrisinHove
Re: Ikuchi
#110
Post by ChrisinHove »
Was it a conscious decision to keep the hole? Does it help the ergo’s?
jdw
Re: Ikuchi
#111
Post by jdw »
I am just wondering who purchased both the original version and the CQI version and how the CQI version is holding up to daily use compared to the original? I let go of my original Ikuchi for a variety of reasons but a major one was the tip kept biting me in my pocket and it had a sticky detent that never loosened up. It's a great design and great ergos for a small blade and light weight knife otherwise.
--Wovoka
Larry_Mott
Re: Ikuchi
#112
ChrisinHove wrote:
Wed Feb 19, 2020 7:16 am
I felt it's part of the design, and doesn't bother me at all, in fact i think it's kinda cool. Lanyard hol delete however is another thing, and i'd happily do that on every custom scaled knife i own and will get.
Larry_Mott
Re: Ikuchi
#113
Sumdumguy wrote:
Wed Feb 19, 2020 4:27 am
Can't wait to see the final result! :cool:
JacksonKnives
Re: Ikuchi
#114
Post by JacksonKnives »
jdw wrote:
Wed Feb 19, 2020 7:38 am
My CQI version has just enough play in the detent that I can press on the wheel and get the tip up where I can feel it. It hasn't bitten me in the pocket yet, and I feel OK with the way it is since the tip stays next to the pocket seam, but it did get me while I was trying to close it and slip it into my pocket quickly (I didn't get it all the way closed, I think.)
Definitely considering replacement scales that overlap the tip more. You could make a pommel shape that follows the lines pretty easily, I think.
For reference, I have the same problem with a Burnley Kwaiken, it's inherent to the combination of a flush spine/handle line and a full-acuity tip.
Doeswhateveraspidercan
Re: Ikuchi
#115
Yep I bought two of the originals and they kept biting me as well how that tip was ever allowed to go to production is a black eye for Spyderco.
I wound up selling my user and it’s backup loved the design but one cut too many angered me and they had to go!
Does the CQI version eliminate getting Ikuchi fingered?
curlyhairedboy
Re: Ikuchi
#116
It does, the tip is a few mm lower.
elena86
Re: Ikuchi
#117
Post by elena86 »
Did anyone measure the thickness behind the edge ?
Marius
( Rabindranath Tagore )
avocadobbq
Re: Ikuchi
#118
Post by avocadobbq »
Sat Feb 22, 2020 5:57 am
That's true, mine has never bit me.
Re: Ikuchi
#119
avocadobbq wrote:
Sat Feb 22, 2020 7:30 pm
Looks lower and not as long.
avocadobbq
Re: Ikuchi
#120
I only have the CQI version, but I've never sharpened it so if it's shorter then that's how it is. However it's been long enough for what I need it for. Lovely knife and makes me excited for more Paul Alexander designs.
