When your first RIT dye job goes bad....
cELLiBAIt
Re: When your first RIT dye job goes bad....
Postby cELLiBAIt » Wed Dec 06, 2017 10:27 pm
Fanks!!
mad german
Postby mad german » Thu Dec 07, 2017 8:25 am
attila wrote:
mad german wrote:
attila wrote:For those who are interested, I dyed my CPM Cruwear Para 3 today. It took roughly 15 minutes to achieve this hue using the Racing Red RIT DyeMore dye. I only used about 1 oz of the 7 oz bottle with just enough water to cover my scales, and the remainder of what I used would be sufficient for dying at least one more item. My first lesson was that a little goes a long way.
Another interesting thing is that the rough surfaces took the dye much better than the smooth surfaces. It came out well, tho, since the smooth surfaces are hidden.
The last thing I noticed was that at first when I didn't boil the solution the dye only penetrated very lightly. Once I simmered the concoction and flipped the item regularly, the dye really took.
I hope this helps someone's decisions as previous discussions helped mine.
That looks great. How close is the final outcome to the color on the bottle of dye? What was your mixture of water/vinegar/dye? Did the scales rest on the bottom of the pot, or were they suspended?
Thanks for any help you can provide.
With regard to the color vs the bottle, here are two pictures to show the difference in artificial light since the sun is hiding at the moment:
Using the synthetic-fabric dye, I aimed to use only about an 1/7th of the bottle (~1 oz) and only added enough Brita filtered water to cover the part while simmering (<2 cups total liquid).
When I dyed the scales, I didn't disassemble the G10 from the stainless liners or lanyard tube because of the flaring of the tube. Coupled with the small liquid volume I chose to use, I simply flipped the scales every 30-60 seconds while simmering to keep the dying even.
I could easily have suspended them if I had used the whole bottle of dye, but then I'd have wasted the vast majority of the dye on one knife. I figured there was a more frugal approach, and it seems to have worked out alright.
I hope this is clear enough to help your project!
Thanks so much. I'm worried about the lanyard tube as well. I hate to mess it up, but I've heard of guys being able to pop it off, it supposedly just takes some work. I'll have to make this a winter project.
How much does the water/vinegar mix affect the quality of the dye job? I've seen all sorts of various mixtures being used.
My collection is ever changing!
attila
Postby attila » Sun Dec 10, 2017 11:42 am
Forget the vinegar. This liquid RIT DyeMore doesn't call for it.
With regard to concentration, i only did one set of scales and the concentration was fine. My ratio of dye to water was roughly 1:10 to 1:15, so a little goes a long way.
Own: Delica, yOld S30V Native, pointy Breeden Rescue, Delica, HAP40 Endura, ZDP DF2, S110V Manix LW,Pakkawood Delica, Cru-wear Para 3, SE H1 DF2, M4 Manix 2, HAP40 Caly 3, S90V Native 5, K390 Urban, Pakkawood DF2, Cruwear PM2, SE Pac Salt, HAP40 Jazzlica, S110V Native, P.I.T.S., DLC Manix 2, REX 45 PM2, Para 3, XHP Manix LW, SB Caly 3, 20CV PM2, Rhino, SB Calypso Jr., B70P, PMA11, K03, ZDP Stretch 2, Kapara, REX 45 Military, 154CM Manix LW, 204p PM2, Swick, SG Delica, BL Lil'Native, AEB-L Urban, HAP40 Stretch, KC Cruwear Manix 2, Cruwear Military, M390 PM2, Cruwear Delica, 4V Lil'Native, Mantra 2, CruCarta Shaman, M390 Para 3 LW, M390 Manix 2, K390 Police 4, RexWood Shaman, DLC Cruwear Shaman, Rex 45 Manix 2, Native 5, Native LW, 204p Para 3, S45VN PM2, S90V Manix LW, 20CV Manix 2, Rex 45 Lil’Native, Shaman, C208GP.
Waiting for: SPY27, K490, Swick 5, and something purple
mad german
Postby mad german » Mon Dec 11, 2017 7:52 am
Thanks again for the help. When I get it done, I'll post up some pics of the results. I'm on hte fence between Navy blue and gray for the Digicam dye job.
Rhix
Postby Rhix » Sun Dec 24, 2017 8:15 am
Thanks to Attila for the instructions and inspiration. I dyed my Cruwear Para 3 racing red last night. Here’s a picture with my M390 PM2. I used a little more dye and left them in the solution for about 30 minutes, but I don’t think the additional 15 minutes made much difference.
M390 PM2-Cruwear P3
:spyder:
Robert
H0bbs
Postby H0bbs » Thu Feb 13, 2020 9:52 pm
Everyone’s success led me to getting it done. Standard green digicam dyed with RIT dyemore Saphire blue. I got it up to around 180F and then dipped the scales in for about 3-4 minutes. Super happy with the end result.
JuPaul
Postby JuPaul » Fri Feb 14, 2020 11:24 am
Nicely done! I like the digicam turned blue.
- Julia
JMM
Postby JMM » Fri Feb 14, 2020 2:41 pm
I can speak from personal experience, you can truly un-rit-dye pretty much anything in two steps, provided you have not used "Rit ColorStay Dye Fixative" to seal-the-deal...
Step 1. Place the scales in 100% acetone -- you can use fingernail polish remover, it doesn't work as well with the scents & colours added, plain, 100% acetone works the best. Depending on how much dye is in the scales, you will want to dump out the acetone rinse the scales in cold water, then repeat, you should do this at least once, possibly up to 3 times, for I'd say 1-2 hours. By then 80-90% of the dye will be gone.
Step 2. This is the key to restoring your scales to factory new. "Rit color remover" essentially, use 1/2 to the whole packet, put into nearly boiling water and throw your scales in. Note: It doesn't smell awesome, turn your stove/range hood/fan on high & crack a window... let it go to work, check them every 5 minutes or so, it usually takes 20-30 minutes. These two steps will remove 97-100% of any colour of rit dye. One time I had to go back and do one more round of fresh acetone, then repeat step two.... but that was unusual, and I did end up with perfect removal at the end. Happy Rit-ing everyone!
Cheers,
John
Haunted House
Postby Haunted House » Fri Feb 14, 2020 5:29 pm
That looks awesome!
Team Wharncliffe
Doeswhateveraspidercan
Postby Doeswhateveraspidercan » Sat Feb 15, 2020 12:30 pm
What was the original color? Looks great btw.
cycleguy
Postby cycleguy » Sat Feb 15, 2020 12:33 pm
Hey Mikey... I like it!!! (Get it ... its Life! :D )
CG
Postby kennethsime » Sat Feb 15, 2020 2:12 pm
Just chiming in that the knife looks great.
Lost to the Ages: C90GRE Stretch 1 ZDP-189 British Racing Green | C28GRE2 Dragonfly 2 ZDP-189 British Racing Green
C12BK2W Matriarch 2 VG-10 Emerson Open | C81G2 Para Military 2 S30V
Currently Rotating: C81GPRGR2 Para Military 2 K390 Ranger Green | C223GPRGR Para 3 K390 Ranger Green
C90FPIV2 Stretch 2 Straight Spine, VG-10 Rit Dye'd Dark Apple Green | C223GP Para 3 S30V Green Canvas Micarta
C41BORE5 Native 5 Lightweight REX 45 Burnt Orange | C223BORE Para 3 Lightweight REX 45 Burnt Orange
C101GY2 Manix 2 Lightweight Maxamet Gray | C28GFG Dragonfly VG-10 Foliage Green
MT27 Mule Team 27 Micro-Melt PD#1 Ranger Green | C36GPGR Military 204p Dark Green
Users browsing this forum: Bing [Bot], blues, FullFlatMind, Google [Bot], Lumpy, RamZar, rhaug, Tgmr05, TkoK83Spy, Woodpuppy and 43 guests
