If it is run at any reasonable hardness it should perform noticeably better than VG-10. More carbon, more Moly, more vanadium (2% vs 0.1-0.3%, and added 1% Niobium.
CPM SPY27 steel
- thewoodpecker
Re: CPM SPY27 steel
Looking forward to seeing this in other Golden models like the Shaman. :D
Spyderco Caly 3.5 Super Blue user, Astute enthusiast, and geometry advocate.
Re: CPM SPY27 steel
Hello Larrin,Larrin wrote: ↑Fri Jan 17, 2020 5:39 amOk I will get on it right away.pantagana23 wrote: ↑Fri Jan 17, 2020 2:34 amLarrin, just to let you know that we are waiting for article update :D
Did you receive the steel for testing by any chance?
Just excited to see your results.
As I always write in signature of my emails - hope to hear from you soon :D
Re: CPM SPY27 steel
I heard today that it will be shipping Thursday.pantagana23 wrote: ↑Tue Feb 04, 2020 4:37 pmHello Larrin,Larrin wrote: ↑Fri Jan 17, 2020 5:39 amOk I will get on it right away.pantagana23 wrote: ↑Fri Jan 17, 2020 2:34 amLarrin, just to let you know that we are waiting for article update :D
Re: CPM SPY27 steel
I think it is FANTASTIC that Spyderco is doing this! Same goes for the work they've been doing with BBB. Spyderco has already led the way for so much advancement and innovation in the knife industry with regards to blade steel choices, and I think they have the chance to make another huge leap forward.Larrin wrote: ↑Tue Feb 04, 2020 5:02 pmI heard today that it will be shipping Thursday.pantagana23 wrote: ↑Tue Feb 04, 2020 4:37 pmHello Larrin,Larrin wrote: ↑Fri Jan 17, 2020 5:39 amOk I will get on it right away.pantagana23 wrote: ↑Fri Jan 17, 2020 2:34 amLarrin, just to let you know that we are waiting for article update :D
The thing is, the heat treat protocols for different steels as they come suggested from the foundry are not optimized for use as a knife blade steel. Even with steels designed for knife blades, the foundry has not done the extensive testing and experimenting necessary to pin down an optimal heat treat that fully expresses the potential performance of a blade steel.
Up til now, as far as I can tell, a small portion of custom knife makers were the only ones really putting in the work to experiment and test different heat treating procedures to try and find out if there was a better way of heat treating a given steel.
You often hear discussions about the difference in performance, edge retention for example, between a knife steel with a production heat treat and a knife with a custom heat treat. Some of this is due to the limitations inherent to mass heat treating and mass knife production, but I think a lot of it is also because it is a standard practice for companies to heat treat according to the recommendation of the steel foundry. It makes sense. However we are learning that those recommendations are not always the optimal protocols, and custom makers are able to take the time to try different things and figure out what actually yields the best results. Knife companies may not have the time, nor do the foundries, at least not figuring out the optimal heat treats for every possible application.
Spyderco already leads the industry in quality of heat treatment, but if Spyderco is willing to work with some of these custom makers and knife focused metallurgists on actually developing and implementing custom heat treat protocols aside from the foundries suggestions, that could be truly ground breaking for the knife industry, and a monumental benefit to knife consumers and enthusiasts.
Hats off to Spyderco.
Re: CPM SPY27 steel
It’s pretty awesome to get to see behind the curtain sometimes, isn’t it?
Re: CPM SPY27 steel
Hi Baron Mind,
We've been testing 27 with different heat treats as we really have little to go on. Looking forward to hearing from Larrin and Shawn.
- Surfingringo
Re: CPM SPY27 steel
I’m very interested to try this one! I’ll probably give it a go in the LW para 3 platform. I will be happy with edge performance anywhere in the S30V/Elmax range. I am more concerned with how the steel performs in toughness, edge stability, sharpening response and corrosion resistance. If it shows any advantages in any or all of those categories over S30V then it will be a huge winner in my book.
- PeaceInOurTime
Re: CPM SPY27 steel
I have nothing to add, just want to say I think it's really cool that Spyderco will have their own steel.
- Deadboxhero
Re: CPM SPY27 steel
I look forward to adding to the testing Sal.
Hope to see you at the Eugene Oregon Knife Show to present you a knife.
For now, it's time to cut coupons and build hardness curves.
This steel has a lot of potential for high Stability and Apexing, very excited to see a steel like this more focused on things sharpeners like over S30V/s35vn etc.
Shawn.
Shawn.
Re: CPM SPY27 steel
Awesome Shawn!
- Deadboxhero
Re: CPM SPY27 steel
Yes, very excited. :D
Time to go fill up the liquid nitrogen in the dewar. :)
Re: CPM SPY27 steel
"A sharpener's stainless" could be a great way to market this steel. With a heat treat tailored to fit the bill of course.Deadboxhero wrote: ↑Mon Feb 10, 2020 4:08 pmI look forward to adding to the testing Sal.
Shawn.
Re: CPM SPY27 steel
Hi Shawn.
Have fun and keep us posted.
Larrin should have some as well.
I have always said that the only things that are REALLY new are Babies and tomorrow. I guess the birth of a new steel isn't quite so grand as Babies and Tomorrow, but it is fun.
Re: CPM SPY27 steel
Very excited to see some results start rolling in.
It's such a fun time to be a steel junkie!
Re: CPM SPY27 steel
I can't wait thanks for sending those samples sal
- Tucson Tom
Re: CPM SPY27 steel
Reading about Spy27 some more and looking at the steel composition has me more interested. I don't understand the comparison to VG10 and I think it is entirely bogus. It has a lot more vanadium and with the carbides from the niobium, it should be a whole different animal. Even if it was the same composition as VG10 (like M390, CPM 20V, and CTS 204P), we would have the differences from different processes at the different mills and possibly different heat treats. With a significantly different composition (comparing Spy27 and VG10, which people should stop doing) and a heat treat of its own that is yet to be determined, anything is possible. I am a lot more excited than I was formerly.
Re: CPM SPY27 steel
Sorry to nag, but any word on hardness?
Re: CPM SPY27 steel
Tucson Tom wrote: ↑Tue Feb 11, 2020 2:58 pmI don't understand the comparison to VG10 and I think it is entirely bogus........... (comparing Spy27 and VG10, which people should stop doing)
Sal himself said it's a variation of VG10. So comparing them seems very justified to me.
Re: CPM SPY27 steel
I'm quite confused ... SPY27 has 2% Vanadium and 2% Molibden, this alone should put it in a class of it's own ...how could one compare SPY27 to VG10 ?
Marius
( Rabindranath Tagore )
