Military 3 vs delica.
Fright_Fox
I had a delica for a little while but sold it unfortunately. Now I want a smaller knife for edc at work and the military 3 lightweight is around the same price as a delica vg10 here. I think the mili is a different steel, anyway what would be the better buy for just cutting up boxes and also cool factor. Thanks.
Re: Military 3 vs delica.
*Para3
TheGiant80
If the Military 3 is currently a thing, there’s going to be a lot of somewhat confused yet excited people around these parts!
Also, if you had the Delica and sold it, why not try something new? I’d recommend the Lil Native!
For me Delica over Para 3 by a huge margin. Imho the Delica does all the "small folder things" right, but the Para 3 not so much.
Bladestock:
Delica 2.5, Para 3.6 mm. That's over 40 % thicker, and makes the Delica a better slicer (though of course not only blade stock thickness alone is defining how slicey a blade can be!). Still the Delica blade is easily strong enough, that's true also for the tip (due to the slight drop towards the tip).
Handle:
The Delica offers space for a generous four finger grip on the handle, while one can still perfectly choke up on the Ricasso.
The Para 3 has the size, where imho a choil is not the best choice: Shortens the grip area on the actual handle, so larger hands have to choke up for a good four finger grip plus sacrifices usable edge length.
Carriability: The Para 3 does not offer more cutting edge than the Delica, has not a handle that offers a good four finger grip, but still is clearly bulkier in the pocket than the Delica. And the Delica, despite having full liners, is still lighter than even the Para 3 lw.
Lock:
I prefer the backlock, but that's just personal preference.
That all being said: The Para 3 still is a cool little baby PM2, and many, many love it. It's just not for me.
Bladestock:
Handle:
Lock:
Added to my post above: Get a Chap FRN... :D
I'll second the Chaparral, any configuration.
Para 3 will be a slightly larger footprint than the Delica. More handle same edge. Chaparral a little less handle and edge. UKPK close to the same with choil but no lock.
CG
- VooDooChild
Oh. Para 3. Sorry no interest. It doesnt fit my hand.
Para 3 lightweight.
If you can wait a bit get the SPY27 cobalt-blue version.
I also recommend the Rex45. Both were released in reveal 4 a few weeks ago.
They will be awesome.
Sage 5 lightweight should also be a perfect knife. Did not had it in hand.
Lil Native is a tank in a tiny package.
Comes as backlock or compression lock.
Dragonfly lightweight is the PERFECT small knife. Backlock.
A great slicer in a small package is the chaparral.
There a special moon/sun is upcoming.
But I would recommend the FRN.
I couldn’t have said it better.Wartstein wrote: ↑Fri Feb 07, 2020 4:25 pmFor me Delica over Para 3 by a huge margin. Imho the Delica does all the "small folder things" right, but the Para 3 not so much.
Bladestock:
Handle:
Lock:
That all being said: The Para 3 still is a cool little baby PM2, and many, many love it It's just not for me.
spyderwolf
Para if you like choils,Delica if you don't.
Whenever there is any doubt, there is no doubt.
^^ this. Personally I'd choose the Para 3 cause it penetrates better (and has the much better action).
Michael
- bearfacedkiller
Delica = 2.5mm stock
Para3 = 3.7mm stock
The Para3 doesn’t fit my hand very well. I prefer the Native5 or Delica in that size range.
Para3 = 3.7mm stock
I´d say (just my personal opinion of course): If you like choils:
- Sage LW (3mm stock instead of overbuilt 3.7 (Para 3), grip is shaped so that one can get a good four finger grip also behind the choil (not so on the Para 3) - and if you prefer the comp.lock
- Or Chap LW (2mm stock, a bit less actual cutting edge, small enough that a choil really makes sense (cause the handle would be too short anyway, with or without choil) - and if you prefer the backlock
Behind Edge / Spine / Blade Stock
Delica (FFG) - .028 / .096 / .096
Para 3 - .025 / .145 / .145
Sage 5 - .019 / .111 / .116
Chaparral CF - .013 / .077 / .077
Don´t doubt your measurments, but thickness behind the edge is rather easy to modify (make it thinner), overbuilt (for a small folder) general blade stock not so much... So the Delica can at least easily be made a better slicer than the Para 3, if someone feels it isn´t already despite the much thinner stock...
- kennethsime
I like the Delica, but I like the Para 3 a lot more. The compression lock is easier to use with one hand, the ergonomics of the handle feel better to me, I love a good choil, and I like the blade design a little more. Given the choice, I'd go Para 3. That all said, the Delica is still a great knife.
Best advice? Get both, sell off the one you don't end up using so much.
spyderwolf
Can't argue on that point.I'm alergic to 50/50 choils,so any knife with one is a no go for me from the on set.Wartstein wrote: ↑Sat Feb 08, 2020 10:04 am
Of those two I prefer the Para 3 for the ergonomics (finger choil allows fuller grip and better tip control, at least for my hands).
Given a wider selection, I'd take the Chaparral over either one, every time.
I love all of my children equally :-)
