Does dirt cause rust?
Fright_Fox
Post by Fright_Fox »
Does dirt and dust cause rust on stainless steel?
crazywednesday
Re: Does dirt cause rust?
Post by crazywednesday »
I think it would depend on the composition of the dirt.
Justin
Albatross
Post by Albatross »
Fright_Fox wrote:
Thu Feb 06, 2020 10:25 pm
Soil has measurable ph levels, so it's certainly possible.
VooDooChild
Post by VooDooChild »
In terms of rust being an oxidation reaction (or redox) Im going to argue any non inert substance that reacts with the steel will cause some level of staining or rust. Its just all about the degree of the reaction. So probably if you keep it dirty enough.
JMM
Post by JMM »
I don't think there's an absolute answer to that question, I think it will very largely depend on the composition & moisture of any particular "dirt"
JMM
Post by JMM »
vaisforlovers
Post by vaisforlovers »
Rust is the oxidation of iron. The oxidation is the chemical reaction between oxygen and the iron molecules in the steel. It is accelerated by the presence of water (or water vapor). Soil and dirt act like a sponge and can retain the moisture (water), which can accelerate the rust.
So does dirt cause rust. No. Does the water that dirt may retain have the potential to accelerate rusting, yes. Even more so in those high carbon steels prone to rusting.
Tucson Tom
Post by Tucson Tom »
Moisture is the big issue. Dirt tends to attract moisture and hold it next to things, and that causes rust.
Dirt though is not a well defined substance and one man's dirt may be another man's something or other.
Salty dirt, now that could really cause trouble given a bit of moisture.
I've always imagined that dirt/dust/etc at the least could attract and hold moisture, so even if "dirt" by itself doesn't cause corrosion, it certainly isn't helping.
koenigsegg
Post by koenigsegg »
Yes, though not always, Had rust form on my S30V Silverax because I left tape goo on it
standy99
Post by standy99 »
The red dirt in Australia has that much iron in it it definitely rusts anything and everything. My boat trailer is testimony to it.
