Straight Razor from Spyderco
Mike Blue
Re: Straight Razor from Spyderco
Postby Mike Blue » Sat Jan 18, 2020 1:54 pm
I'm enjoying all the feedback. There are a lot of good points.
AEB-L and 12C27 are older under-rated steels, in the same historical period with O-1, with good performance. We all need to consider that humans shaved with razors for generations before stain resistant steels came on the scene. They made do with what was available.
For reference: cutting a human hair of whisker diameter is approximately the same as cutting copper wire of the same diameter. One of my friends Glen, who sharpens razors professionally corrected my shaving techniques long ago. I would get razor burn and thought it was the blade. He told me its rare enough when a face actually dulls a razor so it drags. It's more likely shaving angle and technique. Observing those things afterward made a big difference in post shave results. It's not so different than milling or drilling. Edge angle and pressure make a big difference there too.
The qualities of hardness and toughness of a blade that should perform daily at that level have been discussed. Our conclusion: Any steel used should be at or above being stropped alone for months. Then, if necessary, a simple barber hone to clean up the edge (burr or wire). These blades require a different mindset and some modification of care requirements.
Everyone worries about rust. I have not had a razor rust since I started shaving with a straight in 2004. I have old blades (Sheffield, Solingen, Thiers) that are definitely carbon steel. They have old patina but none new. My method is to use hot water to shave. The blade warms during the process. When I'm done, I dry the blade with a dry towel and put it away and the residual heat evaporates the moisture left. Maybe the steel gods just smile on my foolishness. It's a debatable point. We all have to develop our own ritual so we know what is supposed to be done.
Then, according to my friend Darryl, "you need confidence." Given confidence, educating the shaver may be the most important factor.
I do not advocate EDC or pocket carry, or any kind of un-cased carry, of a straight razor. I make straights. I do not lightly reach into any closed space containing a razor by virtue of hard earned experience. Even when placed in a slip. Reaching blind into a bag or a pocket, you risk the ouch. There are other blades specifically made for pocket carry. Or your first aid kit should have stuff to make a pressure dressing from.
JacksonKnives
Location: Formerly Alberta, now Orange County, California
Postby JacksonKnives » Sat Jan 18, 2020 2:33 pm
Agreed on all points.
If there are advances to be had from PM carbides, great, but if better edge life comes with poor maintenance characteristics, then I don't want it. Carbon steel is tricky enough to hone well for most of us. ;)
The hurdle as I see it (or at least as I've experienced it) is that the benchmark for "shave-ready" is both incredibly high and yet very subjective. I've seen honemeisters rise and fall in the esteem of collectors over the last 20 years, and I doubt they changed their standards much over the years.
What works for some people does not work for others. Is that mostly because of technique? Sure, probably in this case.
Mike, what's your experience with customer satisfaction? Do you ever get customers asking for refunds because they couldn't get a shave with a blade you were happy with?
GarageBoy
Postby GarageBoy » Sat Jan 18, 2020 3:00 pm
A fine grain nitride steel would be good for this purpose, no?
Bloke
Postby Bloke » Sat Jan 18, 2020 11:34 pm
jpm2 wrote:
Fri Jan 17, 2020 7:16 pm
Every once in a while I use one of my knives to shave with
https://m.youtube.com/watch?v=lId5Huti_tQ
jpm2
Postby jpm2 » Sun Jan 19, 2020 1:45 pm
^^ Funny movie Bloke. I like the telling time by the sun scene too. :)
Bloke
Postby Bloke » Sun Jan 19, 2020 2:52 pm
Definitely! :cool:
It’s a very funny movie but I’m sure some of the humour went over the heads of many non Australians. :)
Mike Blue
Postby Mike Blue » Sun Jan 19, 2020 7:48 pm
I definitely think powder metals have a place. Especially if the steel used is to be of a "fine grain" in the parent bar stock. If we add the variable of a forged blade, it will be necessary to thermal cycle the material for grain reduction. That's adding more steps not less.
I've tried to think through this variable. I agree with you. It's pointless to make a razor that doesn't shave. The criteria is a good one. A knife edge is more forgiving. Buyers often sharpen them themselves. How to make sure that a Spyderco razor is shave ready will take planning.
For my own blades I do warranty my work and materials within my control. I have had blades returned, thankfully not many. I have been fortunate that I have been able to replace them to the satisfaction of the customer.
I have never had a razor returned because someone could not shave with it. My expectation is that most buyers have some experience shaving with a straight razor. Unfortunately this is a huge variable when it comes to individual razor performance. Honing only makes a blade ready to shave, the wet computer, talent, time, experience all affect the satisfaction with the shave. Simple things like a poor stropping technique can affect shaveability. These are out of my control. Just examples. I'm sure there are more that haven't been thought of.
Lucabrasi
Postby Lucabrasi » Mon Jan 20, 2020 9:04 pm
I would certainly be interested. I rotate through seven vintage rust belt straights, and a Hellas trans and a couple Sheffield’s. If you brought something in a good steel capable of a serious Japanese natural edge I’d be in. For some reason I think xhp might have a shot but could be way off. Obviously would come down to price too.
Current Spyderco: Native 5 LW s35vn; Delica zdp; Caly 3.5 zdp/CF; Chapparel FRN cts xhp; Southard; Kapara s30v; Ikuchi s30v
Passed Spyderco: Endura zdp; Manix s110v; Paramilitary 2 s30v
SalomonA
Postby SalomonA » Mon Jan 20, 2020 11:38 pm
zhyla wrote:
Fri Jan 17, 2020 10:25 pm
SalomonA wrote:
Fri Jan 17, 2020 5:42 pm
Honestly, if I could clamp the straight razer with my wicked edge, I'd be in.
Straight razors have sharpening guides built in. There’s no need for anything but a flat stone to hone them.
Could you elaborate on this. If razer's had a flat grind going all the way to the edge, I would understand, but I was under the impression that razer's had a concave grind to them.
stockliman
Postby stockliman » Tue Jan 21, 2020 1:06 am
I think Spyderco would only be selling them to Spyderco fan's and not users. Better off being a commemorative piece like a 2020 forum "knife". As a seller in any numbers, I think it would be a flop. With fewer shaving these days, the pervasiveness of those horrible 10 blade / $20 for 4 cartridges , the number of S/E and D/E safety razor users and collectors, it leave a few straight razor folks left. Of those, most have their favorites that they will never deviate from.Most love tradition.
The sales would need to be from collectors of folding knives, or the razor being a technical marvel or such a good price, they can't ignore it. I can't see either of the latter happening.
zhyla
Postby zhyla » Tue Jan 21, 2020 6:58 am
Straight razors have sharpening guides built in. There’s no need for anything but a flat stone to hone them. Diagram is about stropping but the only difference is the direction you move the blade.
It’s because of the hollow grind that you can lay the razor flat on a stone to sharpen. See diagram on the right.
Sumdumguy
Postby Sumdumguy » Tue Jan 21, 2020 7:06 am
I don't know how big the market is, bit I know I've been looking at straight razors for several years, but I find it hard to trust a maker I'm not familiar with.
It would put my mind at ease if Spyderco made one!
Also, I'd shave more often and not look like a homeless bum all the time! :p
zhyla
Postby zhyla » Tue Jan 21, 2020 7:17 am
No doubt if Spyderco made one it would be trustworthy. But there are lots of reputable brands out there. And honestly the cheap Chinese stuff has gotten really good. My Gold Dollar model 1996 ($25!) works like a charm. Straight razors are all about sharpening and technique.
Postby sal » Tue Jan 21, 2020 9:17 am
Hi Lucabrasi,
Welcome to our forum.
Sumdumguy
Postby Sumdumguy » Tue Jan 21, 2020 10:54 am
I don't buy from China, if I can help it. I've been looking at a kamisori, just haven't pulled the trigger. Now that this is seriously on the table from Spyderco, my decision will be much easier!
I'll probably get a kamisori in the mean time. It will be fun to compare the different styles.
Lucabrasi
Postby Lucabrasi » Tue Jan 21, 2020 1:39 pm
Thanks for the welcome. Love what you guys do, happy to be apart of this community.
Postby Wartstein » Tue Jan 21, 2020 2:45 pm
I think Spyderco would only be selling them to Spyderco fan's and not users. ...
I am an example for one who'd buy one, actually it, AND is a Spyderco fan... ;)
(But you're right, I am also not sure how well it would sell generally)
SalomonA
Postby SalomonA » Tue Jan 21, 2020 3:54 pm
Thank you for the picture, it helps give me a visual of what you meant. I may have to get that cheap one you recommended to practice with and to get the hang of sharpening with until a possible spydie version comes out. I have done plenty of hand sharpening as well, but if you can lay the blade on a stone like it shows with that strop, then it really should be a breeze. I've got stones and strops other than the wicked edge if it works that easy.
zhyla
Postby zhyla » Tue Jan 21, 2020 4:42 pm
Just make sure your stones are flat. What passes as "shaving sharp" on an EDC blade is laughable on a razor. The flatness of the medium matters. I use sandpaper on glass, but if your stones are properly dressed I hear they work fine. In sandpaper terms I go up to 5k grit. I would say 2k is a minimum.
JacksonKnives
Postby JacksonKnives » Tue Jan 21, 2020 11:30 pm
Gold dollar razors are about as good a place to start as any, though some will caution you to use a razor honed by someone with experience before you try learning, since the feel you're looking for is tricky to define in writing.
Definitely look up the popular methods and pick one you have tools for to try first; stick with a method through the whole honing process before you let some shiny new piece of sharpening gear distract you.
I've spent 20 years now chasing satisfactory edges on straights as an on/off hobby. The disappointing results can be frustrating, but it helps to have a group of fellow enthusiasts here focusing my edge-OCD elsewhere. ;)
Users browsing this forum: abiggs, Bing [Bot], chocolatyshatner, jacala, legOFwhat?, Menipo, pantagana23, PeaceInOurTime, prog_knife, rcwill98, root, Spydergirl88, Theldraskien, toocool006 and 42 guests
