Spyderco Hooded Sweatshirt
curlyhairedboy
Re: Spyderco Hooded Sweatshirt
Postby curlyhairedboy » Thu Jan 09, 2020 9:07 am
I also prefer full zip hoodies.
EDC Rotation: PITS, Shaman, CF S90v Shaman, Ikuchi, Amalgam, CruCarta Shaman, DLC Lil Native, Sage 5 LW, 4V Shaman, Watu, Rex 45 Shaman, Rex 45 Lil Native, Caribbean Sheepsfoot CQI, Tanto PM2, Serrated Shaman
Always in Pocket: Hawkbill Dragonfly 2 H1
Fixed Blades: Proficient, Junction, Waterway
Special and Sentimental: Southard, Smallfly G10, Squarehead LW, Ouroboros, Calendar Para 3 LW, 40th Anniversary Native, Calendar Watu
Would like to own again: Currently N/A!
Wishlist: Smallfly 2, CQI SpyderEdge Caribbean Sheepsfoot, Shaman Sprints!
Postby TkoK83Spy » Thu Jan 09, 2020 9:28 am
Same here, I probably have around a dozen hoodies and only 2 of them are pull overs.
20 :spyder:'s in 11 different steels
2 - ZT's - 0460 and 0470
1 - Microtech Ultratech DE OTF
1 - Civivi Elementum
Postby Sharp Guy » Thu Jan 09, 2020 1:14 pm
Cscottsss wrote:
Thu Jan 09, 2020 6:51 am
Does anyone even wear full zip hoodies? Bummer it's not a regular hoodie without a zipper.
I have, wear, and like both.
Postby sal » Thu Jan 09, 2020 1:34 pm
I wear full zipper hoodies quite a bit.
James Y
Postby James Y » Thu Jan 09, 2020 1:37 pm
I prefer hoodies with zippers more than pullovers.
I used to have a red Spyderco T-shirt that had an image of a SE SS Police model on it, but that was many years ago and would probably be considered "too aggressive" today. But it was a cool shirt.
TomAiello
Postby TomAiello » Thu Jan 09, 2020 1:54 pm
Cambertree wrote:
Wed Jan 08, 2020 8:11 am
Another cool mod would be to have a reinforced horizontal slit next to your pocket so the whole knife can be dropped down into it, with just the clip riding outside your clothing.
Would you want the top of the knife "hiding" as well? Assuming it didn't have a low ride clip of some sort?
Larry_Mott
Postby Larry_Mott » Thu Jan 09, 2020 3:23 pm
sal wrote:
Wed Jan 08, 2020 8:23 pm
Hi All,
Sorry, I lied. Talked with Eric this evening and the hoodies did clear QC. Back to the drawing board.
I am assuming a typo and they in fact *didn't* clear QC?
For the record i'd take full zipper over pull over any day of the week! Keep up the good work!
//Eva Mott R.I.P.
Postby sal » Thu Jan 09, 2020 4:38 pm
Thanx larry,
Yes, you are correct. my bad. They did not clear QC and are not available. I corrected the original post.
Rinzler
Postby Rinzler » Thu Jan 09, 2020 9:57 pm
Can I stop by the outlet and pick up a non-QC'd hoodie? There's many uses for subpar sweatshirts... I love to free up your inventory space instead of dropping $12 on another clearance Walmart sweatshirt.
ChrisinHove
Postby ChrisinHove » Fri Jan 10, 2020 1:53 am
TomAiello wrote:
Tue Jan 07, 2020 5:01 pm
Cambertree wrote:
Tue Jan 07, 2020 3:08 pm
For example, extra knife or utility pockets with reinforced stitching.
I think we can all relate to having favourite items of clothing worn out around areas where knives are pocket clipped.
I own a loft full of industrial sewing machines, and I habitually modify my pockets to reinforce them against clip damage. I tend to wrap 1" flat webbing around the edge of my pockets, and then put in slots for the clip so that the 'spoon' sits back down inside my pocket as well. Works great for both knives and flash lights.
I also frequently put elastic loops inside my cargo pockets, but that's for my other gear.
Fantastic ideas! I’ve bought trousers with reinforced pocket edges, but the clip spoon recess and storage loops .... brilliant!
Mini2white
Postby Mini2white » Fri Jan 10, 2020 1:06 pm
I can't wait for the new Hoodie. I was lucky to get one of the new shirts. I did notice it is a lot thinner than the last lot of shirts. Not a big deal for me really as it is hot here at the moment, so it gets worn a lot.
Postby JD Spydo » Fri Jan 10, 2020 3:52 pm
This is very timely. I'm getting close to getting me a new Carhartt Hoodie. I like the heavy duty grade Carhartt Hooded Sweatshirts with insulation and front zipper. I'm wondering if Spyderco is going to offer a really cold weather grade unit like I just described?
I usually hate to buy any clothing items or shoes online or mail order because I always like to try them on for size before I buy them. I do like any of the clothes with the Spyderco name and/or logo on them.
SpyderNut
Postby SpyderNut » Sat Jan 11, 2020 10:49 am
I am really looking forward to getting one of these too. I prefer full-zip over pullover, so this should work nicely.
:spyder: -Michael
Cambertree
Postby Cambertree » Sat Jan 11, 2020 8:09 pm
Tom, all my knives except my Lefty Millie are fitted with either aftermarket deep carry clips or low riding wire clips - so yes, the whole knife would pretty much be hidden inside your clothing.
I suppose a small square of fabric sewed inside the pants/jeans would be a good way of also reinforcing the slit. If you had two slits, one above the other, similar to what you described earlier, you could also have most of the bottom of the pocket clip tucked away and hidden as well, if that was something you wanted.
I kind of stumbled across this idea when a favourite pair of hiking pants developed a small tear just above my left pocket. Sometimes when going to replace my knife in my pocket, it would instead go into the hole and clip onto the top of the tear. I realised it was a pretty cool way of actually having your pocket completely clear for other things, yet still having the same accessibility to your pocket knife.
Postby Wartstein » Sat Jan 11, 2020 11:33 pm
Hope the Sweatshirt (and also the T-Shirts) will make it to European dealers too eventually.
FullScaler
Postby FullScaler » Sun Jan 12, 2020 12:54 am
Man, I want one of these. I like the full zip option too.
Https://BladeProtection.com
Cowboyfromhell
Postby Cowboyfromhell » Sun Jan 12, 2020 7:56 am
I prefer full zip as well....how bout a knit cap to match for the winter?
Postby kennethsime » Sun Jan 12, 2020 10:47 am
Slightly off-topic, just wanted to say how much I love the mint green Knife Anatomy shirts featuring the Native; got one with my SS Stretch. Stoked on nice soft shirts that fit well and feature my favorite knife brand!
Lost to the Ages: C90GRE Stretch 1 ZDP-189 British Racing Green | C28GRE2 Dragonfly 2 ZDP-189 British Racing Green
C12BK2W Matriarch 2 VG-10 Emerson Open | C81G2 Para Military 2 S30V
Currently Rotating: C81GPRGR2 Para Military 2 K390 Ranger Green | C223GPRGR Para 3 K390 Ranger Green
C90FPIV2 Stretch 2 Straight Spine, VG-10 Rit Dye'd Dark Apple Green | C223GP Para 3 S30V Green Canvas Micarta
C41BORE5 Native 5 Lightweight REX 45 Burnt Orange | C223BORE Para 3 Lightweight REX 45 Burnt Orange
C101GY2 Manix 2 Lightweight Maxamet Gray | C28GFG Dragonfly VG-10 Foliage Green
MT27 Mule Team 27 Micro-Melt PD#1 Ranger Green | C36GPGR Military 204p Dark Green
curlyhairedboy
Postby curlyhairedboy » Wed Feb 05, 2020 3:49 pm
Any word on these? :)
Postby sal » Wed Feb 05, 2020 4:07 pm
Management is re-looking at potential vendors.
