Brouwer Clip Placement - 2020 Catalog
hovan2yourknives
Post by hovan2yourknives »
I just noticed in the new catalog that it seems like the pocket clip placement has been adjusted to provide a deeper carry. However, it is only adjusted on the lock-bar side for right-hand carry which is a little curious (if the photo is accurate). If these images are accurate...I will finally get one!
Can anyone confirm or deny that this is a CQI adjustment?
Yes, I can confirm the Brouwer clip placement definitely went through a CQI change.
When I was in the SFO this past November I directly compared both versions and in my opinion, the clip placement after CQI is definitely an improvement.
-Nick :bug-red
hovan2yourknives
Re:
Mushroom wrote:
Fri Jan 03, 2020 3:18 pm
Thanks!
ABX2011
Re: Brouwer Clip Placement - 2020 Catalog
Post by ABX2011 »
Good eye! That's a welcome change.
Larry_Mott
Post by Larry_Mott »
I don't have a problem with the clip as is.. Oh well :)
On a side note - how do you pronounce Brouwer? Brow, like eyebrow or Brew, like coffee?
The Meat man
Post by The Meat man »
Larry_Mott wrote:
Sat Jan 04, 2020 3:41 am
I've always heard it pronounced the former. (Brow as in eyebrow)
- Connor
Marulaghost
Post by Marulaghost »
Brouwer is a Dutch designer.
So Brou would be like eyebrow.
But the W should be a sharp F like Field
So it would be "Browfer"
Larry_Mott
Marulaghost wrote:
Sat Jan 04, 2020 10:07 am
I thought it was the 'V' that was pronounced 'F', not the W oh well :)
G_shark
Post by G_shark »
Larry_Mott wrote:
Sat Jan 04, 2020 11:42 am
You are correct.
Source: me, born and raised speaking Dutch.
Larry_Mott
G_shark wrote:
Sat Jan 04, 2020 1:40 pm
You are correct.
I have vague memories of someone telling me how to pronounce Cornelis Vreeswijk's name right decades ago :)
Surfingringo
Post by Surfingringo »
You are correct.
I would assume that the W is pronounced as V as in German?
Larry_Mott
Surfingringo wrote:
Sat Jan 04, 2020 4:39 pm
You are correct.
Volkswagen is pronounced Folkswagen. (In Germany and Sweden at least :) )
Larry_Mott wrote:
Sat Jan 04, 2020 5:01 pm
You are correct.
Same in Austria ;)
Marulaghost
You guys are completely correct. I had a brain fart
G_shark
Post by G_shark »
You are correct.
Well, no 😁
gull wing
Post by gull wing »
The clip movement is an improvement, but the MXG short clip is better. The standard clip is still too long.
SCARAMOUCHE! :bug-red-white
gull wing wrote:
Sun Jan 05, 2020 3:56 pm
[img] https://i.imgur.com/tvLc36F.jpg [img]
As part of the CQI, the standard clip was also downsized on the new version of the Brouwer. Just something I forgot to mention in my other post. :spyder:
-Nick :bug-red
Notsurewhy
Post by Notsurewhy »
Which clip hole pattern does the browser have? Didn't see it in the clip thread.
Cscottsss
Post by Cscottsss »
I want to get one of these but I really just can't get past the green scale color.
soulspy
Post by soulspy »
Cscottsss wrote:
Mon Jan 06, 2020 7:32 am
There is a flytanium copper and a Ti scale that replaces the green side.
