Autonomy 2 SE DLC pre-purchase questions
Discussion of Restricted Models by Spyderco.
Doeswhateveraspidercan
Hi Autonomy 2 Owners,
As the title states looking to buy one the black DLC serrated model.
I would like to ask those of you who own this knife if you have experienced any blade play or lock rock when deployed, I really detest lock rock yet tolerate it in many models but not for a $240.00 purchase.
Thank you.
Re: Autonomy 2 SE DLC pre-purchase questions
Post by The Deacon »
Doeswhateveraspidercan wrote:
Sat Dec 21, 2019 8:39 am
Thank you.
Don't have an Autonomy 2, but I do have both a black and an orange original Autonomy and they both lock up tighter than the proverbial duck's poop chute. Neither has a trace of either vertical or horizontal blade play when deployed. Assuming they use the same locking system, the Autonomy 2 should be just as solid.
Larry_Mott
Post by Larry_Mott »
There's only a satin blade plain edge Autonomy 2 in the catalog.. ? You sure you don't mean the Autonomy (1)
Larry_Mott wrote:
Sat Dec 21, 2019 1:29 pm
I thought the Orange was 1 and the black was 2 and the PE one was also a two?
Guess I am wrong.
So yes the DLC serrated H1 with black G10.
Apologies for the confusion.
Larry_Mott
Sat Dec 21, 2019 5:30 pm
Guess I am wrong.
No worries, had to check the catalog because I wasn't 100% sure myself.
The Meat man
Post by The Meat man »
The Deacon wrote:
Sat Dec 21, 2019 1:19 pm
Thank you.
Don't have an Autonomy 2, but I do have both a black and an orange original Autonomy and they both lock up tighter than the proverbial duck's chute. Neither has a trace of either vertical or horizontal blade play when deployed. Assuming they use the same locking system, the Autonomy 2 should be just as solid.
And I'm the opposite: I don't own either H-1 Autonomy's but I do have the Autonomy 2. It is rock solid; no play at all in any direction.
- Connor
bearrowland
Post by bearrowland »
My orange SE is rock solid too.
Barry
Bonne Journey!
MNOSD member 0032
Accutronman
Post by Accutronman »
I have all of the Autonomy models and all are rock solid
The trick with the Plunge Lock is that it opens with so much force that you can actually over tighten the pivot and it'll still fire reliably, so you can easily dial out every bit of blade play without sacrificing the opening action. I really wish Spyderco would expand on the auto lineup and use this lock on more models.
The Meat man
Evil D wrote:
Tue Jan 07, 2020 6:25 am
David have you tried out the Autonomy 2 yet? I have a feeling you'd like it. The design is similar to the Caribbean, but is a bit thicker and more hand filling while having slightly thinner blade stock.
- Connor
The Meat man wrote:
Tue Jan 07, 2020 2:07 pm
I haven't but it's on my list. I was really hoping for a SE version and maybe even a sheepsfoot.
