K390 PM2 | Testing
EngDevGr3
Re: K390 PM2 | Testing
Post by EngDevGr3 »
Just a FYI for another data point, mine tested at 63.4.
sok
Post by sok »
Deadboxhero wrote:
Sat Nov 16, 2019 7:37 am
Nice man, I'd slap a deep carry clip of your choice on that baby. A lynch or MXG.
Good call. Actually, I had one ordered and it was out for delivery when you suggested this. Just got my hands on it today. ;)
Ankerson
Post by Ankerson »
Deadboxhero wrote:
Sat Nov 16, 2019 7:26 am
Pelagic wrote:
Sat Nov 16, 2019 4:44 am
Good stuff, thanks. Surprised at how uneven the grind was. I don't mind bevels being uneven when freehand sharpening. I just keep the angle as consistent as possible and disregard the bevel. I've never had a spyderco show up as uneven as this one did though. Surprising.
I'm a freehand sharpener so I don't notice with my other knives, like I mentioned above, freehand sharpeners match the bevels more since we focus on matching by eye.
With a fixed angle system it sets the exact angle. With the laser it shows the exact angle.
It seems most production knives should be kept at 20dps on a system like this to avoid funky looking bevels and there some tricks to even out the bevels aesthetically using slightly different angles on each side.
I've noticed the fixed angle boys complain about this but I never understood because I did not use nor own a good fixed angle system like the edge pro until just recently to play with. I have been curious to see what Jim Ankerson was always talking about and also lots of my customers use this system so I traded a Vanax knife for an edgepro apex to see what this was about.
I wanted to test the edge so I just hammered a 14dps on the blade with a disregard to the aesthetics. If I'm not selling it I personally don't care which feels good when your life revolves around stressing about aesthetics for what you do sell.
I am happy to have this knife and I'mma use it a lot. I could regrind it but I'd rather spend that time and money on work I sell so I can keep doing what I do.
Getting the EP was likely the smartest thing you did, will be a large time saver for you in the long run.
Deadboxhero
Post by Deadboxhero »
Took me a few years after our conversation to get one but I understand now. Works nice for testing.
Ankerson wrote:
Mon Nov 18, 2019 8:37 am
Big Brown Bear
Triple B Handmade Knives
Tucson Tom
Post by Tucson Tom »
I just want to say thanks for posting all of this.
I always take particular note of things you post and what you have to say.
And you prodded me into buying one of these. I have avoided BBS because of all the bad press up to now. All I can say thus far is that the purchase itself was smooth as silk. And maybe all the bad press is why they are still available, which works nicely for me in this case.
Ankerson
Post by Ankerson »
Tucson Tom wrote:
Tue Nov 19, 2019 7:09 pm
The only reason and I do mean the only reason they get bad press is because they aren't as cheap as most of the other dealers. ;)
So it's more sour grapes than anything so completely ignore any bad press you hear or read as it's irrelevant.. People complain about almost anything and everything these days.. :rolleyes:
They do however have models that MOST of the other dealers don't have.
And they are a respectable dealer.
They aren't the 1st place I look, but if the others don't have what I want they usually will. Yeah they cost a few bucks more so it's a choice and worth it if you want that model. The aftermarket markup on some models will be a lot higher than BBB will charge and it will be NEW from a dealer. So as I said it is a choice if that's the knife you want.
Albatross
Post by Albatross »
Ankerson wrote:
Tue Nov 19, 2019 9:00 pm
I have seen complaints about their return policy, but unless BBS ships the wrong knife, or the customer develops buyer's remorse, Spyderco's warranty should take care of the rest, making the return policy a non-issue in most cases.
Ankerson
Post by Ankerson »
Albatross wrote:
Tue Nov 19, 2019 11:53 pm
Well they do enforce BUYER responsibility.
A lot of companies have a no return policy and or restocking fees to cut down on return policy abuse.
So it's nothing new or even abnormal.
Tucson Tom
That's what I figure. I have never had to return a knife (except to Amazon, and I have learned my lesson there) of the many I have purchased, so I don't see that as a big concern. If there really is something wrong with the knife, Spyderco will take care of me.
I am enthused about the K390. My first experience with that class of steel was the PM A11 mule, which astounded me that it essentially never needed to be sharpened. Then I picked up the Police 4, which I like for any number of reasons apart from the K390 steel. Given how much I like the PM2, it just makes sense to pick up this knife.
anycal
Post by anycal »
I pretty much subject every new knife to similar cutting tasks. I like to compare their wear resistance (by no means a controlled experiment) of the factory edge. Couple of cardboard boxes, little bit of oak or walnut whittling, some pallet decorating :D . Then take it to a sheet of phone book paper for some wavy cuts. It doesn't take much to dull up a factory edge on most knives.
This K390 has definitely been one of the better ones. Better than my other PM2s, for sure. Even under magnification, the edge looks very clean, stable.
I have been carrying nothing but PM2s since this one dropped. Even in office and places I normally bring a smaller knife to.
I may have found a new favorite PM2! I like tool steel in general, and the ranger green is awesome! Apologies to the other PM2s in my collection.
Would be nice if we could keep the BBS back and forth off of at least one of these threads.
Peter
Agreed on all points, including the last one!
Deadboxhero
#32
Hardness looks inline with what Kurt/Jcoolg19 and EngDevG3r got.
Looks like they ran the PM2 batch 63-64rc
Big Brown Bear
Pelagic
#33
Post by Pelagic »
Good stuff. Thanks for your contributions to the community!
Pancake wrote:
Wed Aug 14, 2019 10:20 pm
Are you a magician? :eek:
Nate wrote:
Thu Apr 04, 2019 4:32 pm
Doeswhateveraspidercan wrote:
Sat Jun 15, 2019 9:17 pm
You are a nobody got it?
Deadboxhero
#34
I appreciate that, Thank you.
Pelagic wrote:
Fri Nov 22, 2019 4:45 am
Big Brown Bear
sok
#35
Post by sok »
^^Nice, just saw your new toy on your YT channel. Appropriately named Grizzly.
Rutger
#36
Post by Rutger »
Good chance that REX45 will outperform this due to the higher hardness...
attila
#37
Post by attila »
wrote:
Fri Nov 22, 2019 6:35 am
I was actually wondering about this and what experienced users of both steels have seen. I don't cut enough to have noticed any difference, and the only K390 I have is a lightly used Urban.
I'm guessing 65-66 hrc Rex 45 would support a fine edge longer, but may be passed up by the higher vanadium+tungsten content of 63-64 hrc K390 in extended cutting scenarios. At the same hardness, I think K390 would win hands down, but I can't be sure.
If K390 at this hardness outperforms the Rex 45 that the PM2 sprint featured, I'll consider buying the former and selling my copy of the latter.
Want: SPY27, K490, Swick 5
#38
Does anyone remember what HRC the K390 Urban was?
The Meat man
#39
Post by The Meat man »
abbazaba wrote:
Fri Nov 22, 2019 8:33 am
62.5, according to ZrowsN1s' HRC database:
viewtopic.php?t=83847
- Connor
Deadboxhero
#40
It doesn't work that simple,
Rex 45 has ~8% total carbide volume in the matrix. It's 2.5% vanadium Carbides plus ~5.5% Softer M6C Tungsten Molybdenum rich Carbides.
K390 has ~16-17% volume Vanadium carbides in the matrix.
So, that k390 edge will resist being worn down and blunted smooth from lots of cutting.
The rex 45 matrix may be harder but the K390 is still more wear resistant and will cut longer.
Rex 45 is fun for how hard it is from a production company. Really enjoy the keen edge holding it offers and can drop angles lower with great stability and how easy it is to shape the apex to a very keen edge since we don't have to cut and shape as many very hard carbides.
It's crazy that we have Hap40/Rex45 in a production folder. Gotta love that "voodoo steel"
Softer K390 still has more edge aggression.
At 63.5rc, the k390 edge has what I call a "Cruwear" effect meaning it's sharpenablity is very high, I've been talking with Michael Christy about his thoughts on the Pm2 k390 edge character, I feel we both agree, it's interesting to see that sticky edge Cruwear effect at 63-64 but with the aggression of k390 it makes for a nice edge character that's fun to play with.
Larrin Thomas was flexing his Heat treatment skills and he Heat treated a K390 test knife at 68rc. I still need to test, it is impressive seeing what the maximum limit is for k390, there isn't any data for that though so no one knows what that edge is like and it is horrendous to grind so not realistic for making knives at high volume.
When the matrix is harder with hard carbides inside at high volume, it's a nightmare to grind and the abrasive cost goes through the roof, that's why it's so neat that Spyderco makes Maxamet so available, they deserve a great deal of respect for that.
About the Cruwear, I run the Cruwear softer in my customs because I like how that edge comes up in Cruwear at 62-63rc. Cruwear is capable of 65rc but it was encroaching on CPM 4v's territory and cruwear doesn't have the firepower of 4v. So, I felt the benifit to Cruwear was the edge character and sharpenablity, so I kept lower for that sticky edge that comes up easy with a variety of different stones.
Big Brown Bear
