K390 Hawkbill Dragonfly?
ZrowsN1s
Post by ZrowsN1s »
For my work in IT removal/installation, besides opening tons of boxes and packaging... cutting zip ties off of bundles of wire and removing tape from bundles of wires without cutting the wires is one of my most common tasks. Small hawkbills are almost the only suitable tool for the job.
It's also worth mentioning a lot of job sites I work at frown on, or do not allow, large knives. A delica would be too big. Making a Dragonfly the ideal work knife.
Even opening the boxes and packaging. Being able to make shallow pull cuts makes the job easier, and insurers you won't cut any of the package or box contents. For boxes, packaging, and zipties there is nothing better in my opinion.
A K390 Hawkbill Dragonfly, plain edge with liners would be a dream work knife for me. G-10, Carbon Fiber, Micarta, heck wood... that doesn't matter to me, I just want it to have liners and PE K390.
So how about it? Any takers?
TomAiello
Re: K390 Hawkbill Dragonfly?
Post by TomAiello »
Any Dragonfly in K390 would be an instant buy for me. In multiples. If it came both standard and HB, I'd buy both for sure.
steelcity16
Post by steelcity16 »
So you are suggesting a Denim Micarta K390 Dragonfly Hawkbill?? Sign me up!! :)
I assume they couud just use the G10 Dragonfly platform and slap Micarta scales on it.
steelcity16
Not sure if you get to wear jeans for your job, but denim micarta would be nice to blend into your jeans.
prndltech
Post by prndltech »
I want it in SE but yeah, I’m in. Love my d-fly hawkbill.
- Shannon
MNOSD 0006
bbturbodad
Post by bbturbodad »
steelcity16 wrote:
Tue Nov 12, 2019 5:15 pm
Add me to the list!
-Turbo
jpm2
Post by jpm2 »
I'd take a few K390 PE dragonfly hawkbills.
Linerless frn would be fine with me.
I have the g10 linered dragonfly and find no benefit over the frn version, so it's unnecessarily heavy to me.
prndltech
Post by prndltech »
jpm2 wrote:
Tue Nov 12, 2019 7:44 pm
I'd take a few K390 SEdragonfly hawkbills.
I fixed it for you :D
I agree on the liners. On a dragonfly I prefer the liner less FRN. I sold the g10 d-fly for this reason.
- Shannon
MNOSD 0006
curlyhairedboy
Post by curlyhairedboy »
This would be very appealing!
Post by JD Spydo »
Why Stop at the DragonFly HAWK ???? It's about time for a Harpy or Spyderhawk with a supersteel blade. Actually it's past due in my opinion.
I've got to admit that I am still surprised at how well that the Little Hawkbills have taken off. But I'm sure that trend will trickle up to the bigger Hawkbills before too long.
prndltech
Post by prndltech »
JD Spydo wrote:
Tue Nov 12, 2019 10:03 pm
... It's about time for a Harpy or Spyderhawk with a supersteel blade. Actually it's past due in my opinion.....
What “super steel” would possibly do better in the SpyderHawk (or any other hawk for that matter) than SE H1?
I’m also in the camp of what would you want a PE hawkbill for?
I ask because I’ve seen your threads here, as well as BladeForums over the years asking the same question ;)
- Shannon
MNOSD 0006
steelcity16
prndltech wrote:
Tue Nov 12, 2019 10:10 pm
My H1 SE Spyderhawk is one I will never get rid of. I'm thinking a PE would better for those precision pull cuts through the tape of bundled wires, or even the outer sheathing of romex house wiring. I'm also thinking it would work better than SE on zip ties. I've never had a PE though. A K390 one sound good in theory, but I would be slightly concerned about the tip breaking off due to the high hardness. :confused:
prndltech
Post by prndltech »
steelcity16 wrote:
Tue Nov 12, 2019 10:32 pm
No way plastics would be stronger than a steel knife blade.
SE works fine for precision cuts. It’s a common misconception... the teeth aren’t angled outward like they are on a saw, where you have to account for the removal of material.
SE H1 is hard to beat period. And sounds about perfect for your uses.
I do similar things with mine in the automotive industry. Zip ties and getting into wire harnesses without damaging things is a necessity
- Shannon
MNOSD 0006
crazywednesday
Post by crazywednesday »
I think its a great idea. I would prefer SE, but would also buy a PE. Spyderco takes lots of risks, but I wish they would make Hawkbills and and SE Hwakbills with exotic metals more.
Justin
Post by JD Spydo »
First off I've been saying for about the past two years that PE Hawkbills just don't have the usefulness of SE Hawkbills. But if anyone can tell me any advantages that PE hawkbills have I'm all ears at this point. I have some Spyderco PE Hawkbills but rarely ever use any of them for anything. I would like one of the higher performing steels in a Hawkbill for two reasons. Because many of the jobs I end up using them for are rough jobs. Also in an SE Hawkbill you may not have to sharpen them nearly as much. As far as H-1 goes I'll take the LC200N over that steel any day of the week. Also I might give PE Hawkbills another chance if I could get one in like M390 or S110V. I'm thinking they would hold an edge better and might be more aggressive.
But what the heck I guess you would go to supersteels for many of the same reasons you would with any of Spyderco's models.
prndltech
Post by prndltech »
JD Spydo wrote:
Wed Nov 13, 2019 6:08 am
Good point... I’m liking the idea more now that I think about it
- Shannon
MNOSD 0006
steelcity16
prndltech wrote:
Tue Nov 12, 2019 10:49 pm
Zip ties can do some edge damage, especially the thicker ones. And If you are doing pull cuts on thick zip ties with a high hardness blade, the outward pressure you are putting on the tip as you finish your cut could be enough to shear the tip off. Maybe not with H1, but K390 being a harder steel i would be a little concerned.
sok
Post by sok »
Would be my first Hawkbill.
kerrcobra
Post by kerrcobra »
I'd be in for one.
--Jeremy
prndltech
Post by prndltech »
steelcity16 wrote:
Wed Nov 13, 2019 8:26 am
Not gonna say it can’t happen, but I haven’t experienced it... I also don’t have a lot of experience with super high hardness steels. I sure would be dissatisfied and disappointed if my knife couldn’t cut a zip tie.
- Shannon
MNOSD 0006
