Brown M390 Manix
Re: Brown M390 Manix
I scored one from BladeHQ, just happened to be on at the right time.
Swapped the pocket clip to lefty, oiled it, and my fingers are one the verge of bleeding from flipping it last night trying to get it all broken in. I think this is going to be spending a lot of time in my pocket.
Yep, I got mine. I would say the seller was reliable.
- steelcity16
Wolfy916 wrote: ↑Tue Nov 05, 2019 9:27 amI scored one from BladeHQ, just happened to be on at the right time.
Why not just adjust the pivot screws? A VERY slight turn is all it take to dial it in. No need for flipping.
SteveMidwest
steelcity16 wrote: ↑Tue Nov 05, 2019 11:09 amWolfy916 wrote: ↑Tue Nov 05, 2019 9:27 amI scored one from BladeHQ, just happened to be on at the right time.
Well, 'flipping' (opening and closing), polishes things up nicely. It goes from a little snug, to just right, and you're then holding something with nice shiny washers! :D
If you loosen the screw. You go from just right, to a little loose and sloppy later. Only to have to turn the screw again, back the other way. Plus, once you crack that Loctite, it's not going to hold as well. Keeping everything nice, and right where it should be. :)
Back in stock at GPK
still waiting on dlc
Please do a PM2 run in this combo.
- rabbitanarchy14
any news on the dlc
192.168.0.1 -Para 3 G10 M390 Red, Dice XHP, Lil Native Rex 45 comp, Manix 2 M390 G10 BR, PM2 M390 DLC BL, PM2 k390 RGreen, Cat BD1N, Dragonfly 2 k390
Saving for - Lil Native K390, D'allara 3, UTX-70
Instruments- Kimber EVO, SA Hellcat, SW Shield Plus 9
In stock at Knife Center.
- Julia
^ Thank you. I was able to order one from Knife Center. Now for the 6 day wait :)
These are still in stock at Knifecenter if anyone is looking. I just ordered one.
SteveMidwest
Is anyone else finding their spring on this one, to be a good bit stiffer than most?
koenigsegg
In stock at national knives
SteveMidwest
The first customer generated HRC Test numbers are in, on this Manix 2 Brown/M390 Knife.
Poke #1 = 62.2 HRC
Poke #2 = 62.1 HRC
More to follow, in the coming weeks.
Very good, Sal. Thank you Sir! :spyder:
Poke #1 = 62.2 HRC
Poke #2 = 62.1 HRC
koenigsegg
Wow that's about perfect for m390 seems like maybe oil quenched from 2050f then tempered at 300f is my guess. I'd love to see a relative cut test with these. Really wishing I liked brown about now
koenigsegg
DLC version is on the bay
Looks pretty good
Looks pretty good
Well if the collector number are out we should see em somewhere soon, right?
MNOSD 0006
SteveMidwest
koenigsegg wrote: ↑Fri Nov 22, 2019 12:35 amWow that's about perfect for m390 seems like maybe oil quenched from 2050f then tempered at 300f is my guess. I'd love to see a relative cut test with these. Really wishing I liked brown about now
Yes, this really is unicorn territory, for M390. As far as production knives go. It needs to be in this range, or higher. To get the premium cutting performance we are looking to get, and were sold, by knife manufactures.
Personally, I can hardly wait for this steel to completely go away. It must be a Herculean effort, to get it this well done. It's only the third knife, ever, that we have found. That attained this level of hardness. Out of the 45 or so M390 knives, that have been tested so far. From about a dozen different knife manufacturers. And 90%+ of those knives, have been below 60 HRC.
The only other two knives found, to be done this well. Were also Spyderco knives. They are the BBS PM 2 M390, and the DLT PM 2 M390. :spyder:
koenigsegg
I have one of the dlt ones, seems like they're getting it down. Do you have a page of test results? Also any results for the 20cv Manix or BBS k390 pm2? Wondering about 20cv since I was thinking about the kj 20cv pm2SteveMidwest wrote: ↑Fri Nov 29, 2019 10:15 amkoenigsegg wrote: ↑Fri Nov 22, 2019 12:35 amWow that's about perfect for m390 seems like maybe oil quenched from 2050f then tempered at 300f is my guess. I'd love to see a relative cut test with these. Really wishing I liked brown about now
