Request
Pelagic
Request
Postby Pelagic » Fri Nov 08, 2019 8:05 pm
Imagepicupload
Switch back to the pre-CQI squared off pocket clips on the Military. As you can see I saved an older clip and put it on this CQI s110v military. These clips are thicker and stiffer, less likely to get snagged by something and bent. I think they look better too.
Is this possible? Am I the only person that thinks this clip is noticeably better? Did some people not even notice this?
Those who have both pre and post CQI militaries, test the flex on each one and let me know what you think.
The clip is the main reason I lose knives. The stiffer the better. This is honestly the only CQI change I've ever considered a downgrade.
Pancake wrote:
Wed Aug 14, 2019 10:20 pm
Are you a magician? :eek:
Nate wrote:
Thu Apr 04, 2019 4:32 pm
Doeswhateveraspidercan wrote:
Sat Jun 15, 2019 9:17 pm
You are a nobody got it?
ZrowsN1s
Re: Request
Postby ZrowsN1s » Sat Nov 09, 2019 2:25 am
Casey Lynch just announced a titanium deep carry for the Millie. Another option for those that don't like the stock clip.
Carrying 3 knives is perfectly normal :D
-Matt
sok
Re: Request
Postby sok » Sat Nov 09, 2019 6:20 am
I pulled out a non-CQI Military and a CQI variant and could see no difference so far as thickness of steel. I took my fingernail and raised the clips away from the scales and if anything the CQI clip seems stouter. It may be that you need to remove the clip and bend it a bit to regain tension.
Pelagic
Re: Request
Postby Pelagic » Sat Nov 09, 2019 7:11 am
This clip was from a BBS s90v military. I've compared it to at least 5 CQI clips since then. It's thicker and stiffer, all day long. Maybe there was varying thickness of the non-CQI clips.
sok
Re: Request
Postby sok » Sat Nov 09, 2019 7:44 am
I took another look and my old eyes can’t see much difference. Coincidentally, my BBS Smurf Blue Millie is what I used. I took a pic and blew it up. The non-CQI clip does appear to be a little thicker with my examples.
Pelagic
Re: Request
Postby Pelagic » Sat Nov 09, 2019 8:04 am
Yep, that's about what I'm seeing. Nothing groundbreaking, just visually thicker. Never had one get bent outward on me after getting caught on something. With post cqi clips I've had it happen a few times. Perhaps the end is shaped in a way that prevents snags as well? It may not get bend outward quite as much IIRC.
Re: Request
Postby Evil D » Sat Nov 09, 2019 8:07 am
Never noticed a difference. Have you tried taking the clip off and bending it a bit so it clips harder?
Pelagic
Re: Request
Postby Pelagic » Sat Nov 09, 2019 8:17 am
I do that whenever one gets bent after snagging on something, but if there's no problem I just leave it be.
Users browsing this forum: Airlsee, Bing [Bot], Dazen, Google [Bot], JD Spydo, jpm2, Karl_H, ladybug93, Spydergirl88 and 33 guests
