Slightly bitter that even my washing machine couldn’t remove the cardboard box adhesive I’ve been struggling to get off...
Note to self - only let the GF carry stainless knives...
Because she just put my 940 through the wash. Thank god it’s in 20cv ![😂](//cdn.jsdelivr.net/gh/twitter/twemoji@latest/assets/svg/1f602.svg)
Re: Note to self - only let the GF carry stainless knives...
Some of her fingernail polish remover will likely take it off.
Both my wife an I have accidentally washed knives.
- standy99
I washed the air conditioning remote the other day trying to help our. Bundled the quilt cover and sheets all up, it must have been lying on the bed ![frown :(](./images/smilies/frowning-face.png)
Try goo-be-gone It removes all the sticky stuff
Brake cleaner works pretty well for me.
My EDC rotation: Kapara, Chaparral CF, Mantra, Sage 1, Sage 5, Dice, Domino, Gayle Bradley 2, PakkaDelica, Native CFF
Last girlfriend I let carry a Spyderco lost my Q :mad:
No more girlfriends for me!!!! That and I married one... and she has her own Squeak :cool:
- bearfacedkiller
Any solvent will remove tape glue.
I sometimes deliberately clip a knife to the pocket of my cargo shorts and send it through the wash. They come out squeaky clean. I dont let them go through the dryer though.
I carry my cap lifter clipitool in my watch pocket and it has been through the wash more times than I can count. I always forget to check that little pocket.
There is a lot to be desired in a knife with H1 or LC200n or N680 steel it seems. We all run our knives through the washer and some more often than others. Hahaha! :D
A stone is less harsh than brake cleaner??? I must be missing something??? :confused: The next time I need to sharpen or reprofile a knife i'll try some brake cleaner.
- bearfacedkiller
I wouldn’t use brake cleaner. Toxic stuff. Stick with a light solvent like alcohol, mineral spirits or paint thinner. If that doesn’t work try nail polish remover (acetone). If acetone won’t take it off then nothing will. Just avoid any prolonged contact between acetone and composite materials like G10, CF or micarta.
I use rubbing alcohol
I use brake cleaner to clean the crud off my work knife all the time, brake cleaner is good for everything! The stuff I use is non-chlorinated though and is pretty much plastic safe.
Likes FRN
I've ran my Dragonfly Salt through the wash more times than I care to admit. I think there's something subconscious about that knife where I just don't care if it gets washed because it doesn't effect it. It comes out squeaky clean lol.
- rabbitanarchy14
I have washed my para 3 s a few times. Off topic question. Has anyone had a knife open in the wash?
192.168.0.1 -Para 3 G10 M390 Red, Dice XHP, Lil Native Rex 45 comp, Manix 2 M390 G10 BR, PM2 M390 DLC BL, PM2 k390 RGreen, Cat BD1N, Dragonfly 2 k390
Saving for - Lil Native K390, D'allara 3, UTX-70
Instruments- Kimber EVO, SA Hellcat, SW Shield Plus 9
Lol gave mine a PM2 in S110V!!
Just use rubbing alcohol takes the sticky crap right off.
Honestly this adhesive is on some kind of steroids, rubbing alcohol is my go-to and it hasn’t worked at all for this! Thanks for the suggestions, I’ll give acetone a try.
Lighter fluid (it's the napatha) is my go-to. Instantly dissolves any adhesive.
- legOFwhat?
Rubbing alcohol and a cotton ball works very well. Just lay the blade down flat on a surface so the edge doesn't get you and rub away.
-Larry
MNOSD #0049
MNOSD #0049
